Question about Exercise & Fitness
Suddenly quit running
Quit running while I was using it. Just stopped deat at exactly 5 minutes
    Top Expert:
  • 12,223 Answers
1)LUBE the deck belt with 100% silicon or wax see the instr. manual, probably the deck beck is worn by lack of maintenance schedule.
2)LUBE the rollers bearing use the wd-40
3)Test the drive belt motor.
4)Test the input voltage motor, if there are the motor need repair, see my personal TIPS for motor help
5)Test the output voltage board,for input voltage motor, if there are NOT the board is faulty.
see the block diagram
God bless you
Posted on Dec 10, 2012
Why does motor quit running after 5 to 10 minutes
Check that the vent in the fuel cap is not plugged. Can create a vacuum preventing fuel getting to carburetor,
If not sure leave cap a little loose and see if stall repeats>
Mar 11, 2016 | Ariens Garden
My 2004 Honda shadow vt600 vlx quits running after approximately 10 minutes of riding. It just shuts off and won't start. Has a new battery, plugs and changed oil & filter. What will fix this prob
How does it quit? Just suddenly stops, or coughs and sputters (probably gas), or gets jerky (ignition). Does it run just fine and then just stops, or does it run crappy and then stop? How long do you have to wait until it starts again? Is there a choke? Do you turn it off?
Sep 27, 2014 | Motorcycles
I have a 1989 S10Pick up with a 2.8L, won't stay running. I can pull the ecm b fuse it will run about a min then quit, I've changed the fuel pump relay and checked crounds still has this problem?
if it runs for about 5- 10 minutes before it stops, when it stops remove the gas filler cap, do you hear a suck inrush of air when you remove the cap?
Dec 15, 2013 | Twister Auto Parts 89-93 Chevrolet S-10...
Dewalt DPD3800 pressure washer starts and runs fine. After 5-10 minutes of washing the engine quits. It will not start until it cools. The engine will start after a 10 minute cool down. It will run and...
I have the exact same pressure washer and have had the same issues with it. The cure for me was to simply run the washer with the gas cap loose. For some reason the fuel gets vacuume locked and stops flowing into the carb. The fuller the tank is it seems the shorter the time is between the time it starts and the time it shuts off. Or you might find a way to vent the cap. Hope this helps.
Jun 06, 2011 | Dewalt 3800 PSI Pressure Washer
My 1999 Diesel Atv has suddenly stopped running. It will crank and run for 5 or 10 minutes and then quit without any warning. After a brief respite, you can crank it and again, it will run 5 to 10 minutes...
Change the fuel filter if you haven't done so. If problem persists after changing fuel fi;ter and bleeding the system, you may hvve an injection problem
Feb 07, 2010 | Polaris ATV
I have a 1999 Polaris Diesel 4x4. It will run for
I would say you may either have water in your fuel or a filter that should be replaced, or even a blocked air filter.
Please let me know what you find
My poulan riding mower goes dead whether cutting or idling..already checked the gas tank,lines,filter,and carb for trash..all clean...what could be the problem?
Could be bad ignition system. Check for spark when it quits using a new spark plug. Why do you suspect the fuel system? Does the engine quit suddenly or sputter to a stop? Does the engine have to get hot before it will quit? Sudden stop is usually ignition loss whereas sputtering could be either fuel or spark loss. Safety switches--'rider present'--could possibly be a problem and cause ignition loss.
Jun 20, 2009 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Exercise & Fitness Logo
60 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
