Question about SmartDisk 250GB SMARTDISK CROSSFIRE EXT Hard Drive
Cable to connect to win 7 laptop
My lap top does not have a socket that suits the cable from my 250gb crossfire external drive. Is there any sort of adapter
  • SmartDisk Master
  • 27,725 Answers
  • Edward Walker Dec 15, 2012
    I received the adapter from amazon and sadly it does not work. the drive is still invisible to the laptop so I guess it means a new drive which seems a wicked shame. I will look into getting it modified but that will proberly cost more than a new drive. Thanks for the advice and I know where to come in future. Edward
3 Suggested Answers
  • 125 Answers
SOURCE: SmartDisk Crossfire Desktop Drive
Usually this is a problem with the usb port not being able to supply enough power to the drive. Often, units like this will come with two usb plugs on one cable to increase the current supplied to the drive. If the drive has an input for external power (some do, some don't), then using external power would help.
Posted on Apr 23, 2008
  • 10406 Answers
SOURCE: The 5v power pin on the AC adapter of my
Take your SmartDisk to any computer-store.
They can open the case, remove the disk-drive,
and mount the disk-drive in a new "empty" external casing,
with a new power-supply.
See: http://www.canadaram.com/3_5_sata_enclosures.htm
for a sample of various "empty" cases, for about $30.
Posted on Oct 06, 2010
My computer will not recognize the drive. Does it have to be connect to a power supply? I have it connected to a usb port
Windows 7 does not recognize SimpleTech 250GB external USB drive ...
answers.microsoft.com/...does-not-recognize-simpletech-250gb/f7ceccd0...
Just bought a new computer, running Win 7. Drive worked fine on Win XP. ... Windows 7 does not recognize SimpleTech 250GB external USB drive ... I find it hard to believe that a external USB 2.0 drive can't work with Win 7. There must be ...
SimpleTech dvi hdmi pc Hard Drives Questions & Answers ...
www.fixya.com > Forum > Tags > dvi hdmi pc > Hard Drives
Question about SimpleDrive 160 GB External USB 2.0 Hard Drive ... Question about250GB USB2.0 7200 RPM External 250 GB IDE Hard Drive ... my PC does not recognize the external drive 96300-40001-001 Driver Problem: Check whether ..
Dec 18, 2015 | SimpleTech SimpleDrive 250 GB External USB...
USB DEVICE NOT RECOGNISED - MALFUNCTION
Problem may simply be with USB cable used. Try another cable, preferably a known good cable.
Problem may be with the socket on the device itself where the USB cable fits in. Try (with known good cable) on a flat surface with the both the device and the cable resting on the surface - i.e cable should not hang down and put weight on the socket.
Hope that fixes it.
Further advice. Even if problem seems fixed, immediately back up the drive if you can!
Dec 16, 2013 | Hitachi SimpleDrive Mini 250GB USB 20...
Missing dvd/cd rom drive letter hp win 7
First I would check the data cable is properly connecting the drive. If it is connected, make sure the power cable is also conencted to the drive. Then I would check the Device Manager on the computer to see if the driver is installed. It must be one of these three problems.
Dec 18, 2011 | Acer Computers & Internet
How do i use it?????
This hard drive come with a cable. The cable is a USB Cable Its simple to use!
Connect the hard drive to USB Cable and other end connect to your computer's USB port.
If you have Laptop computer these USB ports are on the side or back of the computer and if you have desktop computer the USB ports are mainly in the back!
Sep 08, 2011 | SimpleTech 250GB USB2.0 7200 RPM External...
I am not getting power to the external hard drive. when i plug in the ac adapter, i get a flashing green light on the adapter but no power to the disk. could the ac adapter be bad?
It's probably _NOT_ the AC adapter, given that the lamp is "green".
Disassemble the casing, and temporarily connect the disk-drive as a "slave" disk-drive in some desktop computer, to see if the disk itself is still functioning & its files can be read.
Mar 03, 2010 | SmartDisk 250GB SMARTDISK CROSSFIRE EXT...
Trying to connect a lap top to the 450C designjet but don't have the proper connection to hook up
I believe this plotter has both the old centronics and a 25 pin serial connection. Your laptop MAY have a 7 pin serial connection which you can get a 7 pin to 25 pin serial cable. If your laptop does not have a serial port, you MIGHT find a USB to serial adapter cable.
Make sure you are not on Vista or Win 7 operating systems as they likely do NOT have compatible drivers for this plotter.
Jan 13, 2010 | HP DesignJet 450c InkJet Printer
WD My Passport Essential 250GB USB2.0 is not working in WIn 98SE
Try using a Usb 2 cable "The one that came with the WD My Passport " And put it directly to the PC...
In some cases, Like mine, I used an extended cable + the cable that came with the "WD My Passport" and i got the same problem ..
So i simply removed the extended cable and put the put "WD My Passport " directly to the PC with its own cable and the problem was solved to me ..
Samer.F
Dec 26, 2008 | Western Digital WD Passport 250GB Portable...
Maxtor OneTouch 4 Mini 250GB External Drive Does not show up on my computer
Are you connecting Drive via a USB hub or direct into two separate USB sockets on PC?
May 05, 2008 | Maxtor OneTouch 4 Mini 160GB External USB...
Apr 23, 2008 | SmartDisk Crossfire Desktop (xf160f) 160...
SmartDisk 250GB SMARTDISK CROSSFIRE EXT Hard Drive Logo
179 people viewed this question
Top SmartDisk Computers & Internet Experts
Sunday Ojelabi
Sunday Ojelabi
 Ian Kayhan
Ian Kayhan
Are you a SmartDisk Computer and Internet Expert? Answer questions, earn points and help others
