Question about Epson Stylus CX5400 All-In-One InkJet Printer
Just stopped printing black!
Black Ink cartridge has 50% content remaining and just faded to nothing. Read other posts here and on other forums. Purge tube appears to be working with bubbles travelling down it at a rate. Anyhow, if it were the purge tube at fault I think that this would affect all the colours??? wouldn't it??? For the moment I'll go get a head cleaning kit and a replacement cartridge. I'll post my results. But would appreciate any tips.
  • David Hamer Jun 12, 2007
    Used a cleaning cartridge to clean black nozzle. Replaced old black cartridge. Problem remained. Cleaned again - just to ensure old black cartridge wasn't depositing cr*p in the nozzle and replaced with new black (non OEM)cartridge. BINGO! Problem solved - Faulty blank ink cartridge. Anyhow. Then cleaned all colour nozzles and replaced cartridges. What a difference.
    Printing is like new.
    This is the first time that I've cleaned using specific cleaning cartridges. They will last for several cleans and cost about £10 for all 4. I now plan to perform a clean using the cartridges on every cartridge change. Seems like good preventative maintenance AND it should improve the quality of printing.
  • Epson Master
  • 691 Answers
Hey Johnny, Your dead right. The purge tube would affect all the colours. If you are using refilled carts, try just changing the cart. Approx 10% of all refilled carts fail - so it is entirely possible you have hit on a bad one. If you are using the good stuff, I would suggest getting the cleaning kit and doing the manual clean to clear any blocked nozzles. What does the nozzle check pattern show? If there are a few lines visible, I would guess cleaning will sort it for you. Let us know how you get on...
Posted on Jun 11, 2007
Black stopped printing out. Dell 922 all-in-one ink jet.
Did you already run the head cleaning cycle from the utility?
Apr 23, 2008 | Dell 922 All-In-One InkJet Printer
Large ink spill. Printer no longer recognized new black cartridge.
You can perform the Tap 41 Cartridge Health Diagnostics Test: [applies to HP Deskjet 6800/6900/9800]
http://inkjet411.com/?page_id=1741 (refer to 2nd video to understand how to read the printed pattern)
1. With printer power on, press and hold the POWER button.
2. Press the Cancel (X) button four (4) times.
3. Press the RESUME button (Down Arrow) once.
4. Release the POWER button.
5. The Diagnostic Test Report should print.
--- A good HP 93/95/97/99 color cartridge should display 600 good nozzles, while a good HP 92/94/96/98 black ink cartridge should show 672 good nozzles. If the results yield anything different then the ink cartridge is likely damaged and will need to be replaced. Refer to 2nd video on how to read the printout: http://inkjet411.com/?page_id=1741
---- If the printer attempts to print the diagnostic test pattern (1 page) then the printer is generally considered operational and functional, if nothing is printed, but the printer attempts to print the pattern, then the tri-color ink cartridge is either empty, clogged or severely electrically damaged (black ink cartridge is not used). You can remove the tri-color cartridge, reactivate the tap 41 test and the printer will print the diagnostic test print in black ink (special "ink back-up mode").
For information on North American ink refill services at a major retailer near you (should you wish to save ~50% on ink costs), general printing problem resolutions or advanced HP printer diagnosis procedures (advanced cartridge diagnostic tests/cartridge error bypass & printer reset methods, etc.), please visit Inkjet411: http://www.inkjet411.com
Aug 27, 2013 | HP Deskjet 6988 Inkjet Printer - Color -...
I have a canon multifunction MX700. Suddenly, my black ink stopped printing. Printer prints in other colors. I have turned the power to both printer and computer on and off, have checked the USB cable,...
Dear Adrienne,First make sure that the black ink is not empty. If you are sure the black ink is full enough you need to check the print head condition. The print head may be clogged or faulty.
To fix the clogged print head,please perform the following step:
  • Print the nozzle check pattern, access the following menu on LCD: Menu>Maintenance>Nozzle Check. The good nozzle pattern should like below sample image.
  • If the print head nozzle missing some color (i.e Black) the perform print head cleaning: Menu>Maintenance>Cleaning. Then print the nozzle check pattern again. Note: you may repeat this step up to 3 times.
  • If the problem still remain,then you should perform Deep Cleaning: Menu>Maintenance>Deep Cleaning.
If you have perform the above steps but the problem still the same,please check whether the black nozzle missing partially or totally. The faulty Purge Unit (ink pump) may cause the same problem. I mean the purge unit does not work properly so the ink cannot flow. Good luck :)
Regards,Xanda
Oct 05, 2011 | Office Equipment & Supplies
No black ink. Cartridges good. Just started fading away. Did reset=no. Color is fine. Trying to get apart to to take a look/clean head. Unit is 10 yrs old & like new. No probs until now. Already bought...
Black printer ink in HP Printer may fail to be recognized by the printer. Most times an error message will be sent indicating that something is wrong with the black print cartridge. Sometimes the printer may accept to print with the black ink, but the printouts may have horizontal lines and very illegible letters. In such a case a manual cleaning of the print head should be carried out. In doing the manual cleaning, one should spray Windex heavily on paper towel and wipe off the surface of the print head.
http://en.kioskea.net/forum/affich-40171-printer-not-printing-black
Nov 08, 2010 | HP Photosmart 3310 Printer
Wrong ink in slot
my brother mfc 6490 has stopped printing yellow, i've done number cleans and changed cartridges with no luck. has anyone out there got a fix for this?
Sep 13, 2009 | Brother MFC 6490CW InkJet Printer
HP 5610 - printing fades down the page
the printer carriage might be wearing out, it happens on the 5610's, may be time for a new printer. The fading issue sounds like a cartridge issue. Try a oem?
Nov 14, 2008 | HP Officejet 5610 All-In-One InkJet...
Printing onto clear film for screen printing film positives from R2400
midwest screen and supply will have the printers and the films for screen printing, it's the company i go through and i've had no problems in the past 14 years of ordering from them
Apr 18, 2008 | Epson Office Equipment & Supplies
clean contacts on back of blk cart and printhead with alcohol on micrfiber towel
Oct 14, 2007 | Dell 922 All-In-One InkJet Printer
Printing problem
The black cartridge printhead needs to be cleaned or replaced. Follow your printer manual instructions.
Mar 18, 2007 | Canon PIXMA MP780 All-In-One InkJet...
Epson Stylus CX5400 All-In-One InkJet Printer Logo
101 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
