Question about Baumatic F60 Stainless Steel Kitchen Hood
My Baumatic QF9CSS cooker hood motor works intermitently is it the switch or the motor
Motor is quiet and turns easily but does not always spin when the switch is turned on
5 Suggested Answers
  • 203 Answers
SOURCE: baumatic cooker hood lights not working
take the bulb out and bring it with you to store and see if you can find one the same . DIY stores have tons of types.Joe
Posted on Nov 22, 2008
  • 491 Answers
SOURCE: where can i buy new Baumatic 7.3 GL cooker hood
FIRST TURN OFF THE POWER TO THE HOOD UNIT THEN LOCATE THE BULBS AND REMOVE TAKE THEM TO THE LOCAL DIY STORE TO FIND REPLACEMENTS IF NOT FOUND THERE YOU CAN GO TO AN ELECTRICAL AND PLUMMERS SUPPLY STORE , GOOD HUNTING.
Posted on Nov 17, 2009
Treefrog15
  • 127 Answers
SOURCE: put new bulb in baumatic kichen hood turned it on,
It was probably a defective bulb that tripped a circuit breaker in your house panel. Check the breakers and replace the bulb.
Posted on Feb 25, 2010
blueextc3221
  • 15935 Answers
SOURCE: Cooker hood turning off
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Posted on Sep 05, 2010
Have a Neff D9610 cooker hood. Has 3 separate speed switches. Slowest speed switch does not work other ok. No noise from motor when slow switch on. Is the problem with the switch or the motor?
When on high speed the motor is running at it's normal speed.
When a slower speed is selected (mostly) there is external circuitry to reduce the current to the motor so it runs at a slower speed, though in some cases the motor could be specially wound for multiple speeds. The latter way is unlikely to be found in a cooker hood or extractor fan or other small appliance.
The fault with your appliance could be the switch or the current reducing circitry. It is only by delving inside and testing that the fault could be found.
Oct 02, 2016 | Cars & Trucks
How do I fix the downlighters on my cooker hood?
sounds more the the switch has failed you
Mar 06, 2016 | Baumatic Kitchen Ranges
HJA2540 cooker hood fan not working. Lights work and little red light comes on when switches for fan speeds are pressed so has the fan gone or is it the capacitor? Many thanks Steve
Unless that's a much bigger range hood than I imagine, there won't be any capacitor - the motor will be of a shaded-pole design. If you have a multimeter, you could measure for voltage on the motor wires when the motor should be running - if reasonable voltage is there but the motor isn't spinning, then the motor's dirty or unlubricated or dead. If no reasonable voltage is present, the electronic controller has failed.
Aug 03, 2014 | Kitchen Ranges
Fan not turning in baumatic cooker
is the element hot?
>> check fan motor
> replace fan motor
Oct 14, 2013 | Ovens
Where can i buy new Baumatic 7.3 GL cooker hood halogen lights at a good price
Nov 17, 2009 | Baumatic F60 Stainless Steel Kitchen Hood
Baumatic cooker hood lights not working
Nov 16, 2008 | Baumatic F60 Stainless Steel Kitchen Hood
F90 st.steel hood fan problem
kerry, does it make any difference if you hold that button or not? If so, the switch set could be bad. Any odd noise from the motor? The motor might be bad. Power off. Then, remove the filter and try to turn the motor by hand. If it turns hard, it's the motor. Easy, then replace the switch. Check the electrical connections to the unit. There should be a box somewhere inside the housing. It is possible that wires have come loose. Again, do this part with the power off.
Nov 25, 2007 | Baumatic F60 Stainless Steel Kitchen Hood
Unit will sometimes not turn on
NASCAR...I'm thinking more like the switch. If you can, with the power off gain access to the switch wiring. find the lead that goes to the power and the motor. Connect them directly (you might need a paper clip). Tape it all up securely and fire up the power. If it works...you will know about the switch...if not, you might look at the motor. By the way...check that motor rotation...it should turn easily when you give it a spin. Motors of the type used in fans generally don't degrade in performance unless they get gummed up with kitchen grease. Clean the grease off with WD 40.
Nov 21, 2007 | Frigidaire HV2736B Kitchen Hood
Baumatic F60 Stainless Steel Kitchen Hood Logo
60 people viewed this question
Top Baumatic Kitchen Ranges Experts
Vitaliy Gins
Vitaliy Gins
ray gallant
Jay Plesset
Are you a Baumatic Kitchen Range Expert? Answer questions, earn points and help others
