Question about Drills
HI i need schmatics to de9118 charger, to find out what size the siz of D23
The d23 diod on my charger as burnt out that much i cannot get the size from it to get replacement to replace it. my charger being DeWalt DE9118
5 Suggested Answers
  • 313 Answers
SOURCE: de walt de9118 charger
when charger is plug in to ac it will blink once.normal voltage out for the unit in between 36v to 55 volt. the reading u have is normal.
Posted on Aug 08, 2008
  • 420 Answers
SOURCE: CHARGER PROBLEMS
The flashing light indicates the charger is charging the battery (or attempting it) and if it never finishes charging you should try to charge a different battery, if the charger charges that one ok then the battery is bad.
Posted on Jun 18, 2010
stug_57u
  • 99 Answers
SOURCE: When the DeWALT DE9118 charger
It sounds like you need a new charger I'm afraid. If you want to double check though, take the housing apart (4x security torx screws in the underside corners) and check the little glass fuse on the pcb. If either main fuse or glass one is blown you have a problem with the board and it's not worth repairing. If both fuses are ok I would suggest you might have a dry solder or broken leg on one of the pcb components. You could possibly resolder it if you can find it and it has enough contact left.
Posted on Aug 22, 2010
puertobori
  • 7733 Answers
SOURCE: I think diode D23 is
Go to this LINK and find the part/diagram that can help you.
Please thumbs or post back,thanks
Posted on Nov 04, 2010
D23 on the board is blown up.I do not know what to order at the store.on the schematic I found it shows D23 with an E51A below it.Help. thanks
The prefix D would usually suggest a diode of some sort but I have no idea what E would denote.
The circuit diagram provides insufficient information and so either the component(s) must be ordered from the manufacturer as spare parts, the exact type and value of them must be discovered from a manufacturer's service sheet or component list or an experienced electronics engineer must be consulted to calculate the values from the circuit or even to make an educated guess.
Jan 23, 2016 | Drills
Diode D23 in De9116 charger
D23 is a transient voltage suppressor. Code: 1.5KE51A
Jul 09, 2014 | Dewalt 7.2-18.0 Volt One Hour Charger
Charger for dewalt 18volt drill burned out a diode need to know what to replace it with to burned out to tell ??
I had to replace that on one of mine. It is not a regular diode. P6KE51A Transient Voltage Suppression (TVS) Diode. That is the part # on the USA model. A European model may use different #. 8645a6dd-c755-4fe7-a00b-699ca51bc6af.jpg
Jul 07, 2014 | Dewalt 7.2-18.0 Volt One Hour Charger
I think diode D23 is defect, but I cannot see any number on it. Please advise
Nov 03, 2010 | Dewalt 7.2-18.0 Volt One Hour Charger
Where is the connection for the camera charger, on the camera and where can i get a manuel for my sc-d23?
You can download the manual from the manufacturer's web site at
http://downloadcenter.samsung.com/content/UM/200312/20031211083545640_SCD23-USA_FRA.pdf
Jul 29, 2010 | Samsung SC-D23 Mini DV Digital Camcorder
I have power going to the cb but can not get it to come on !! looked at all the diods and wires can't seam to fing the problem I have checked and I do have power going in
Change D23. It doesn't need to be burnt to be bad. If that doesn't fix it, it could be something more serious.
Perhaps the on off knob is no good. open it and hot wire it on. if it comes on then you know its the on off.
Oct 25, 2009 | Cobra 29 LTD CB Radio
Im a trucker so when i plug my power wire the fuse blow why
You probably plug it in backwards at some point. When you do that you blow the polarity protection diodes. They are so you do not blow the radio.
Get a N14003 diode from radio shack.
Open the radio's bottom cover where the speaker is. Watch the speaker wires.
Near the back right of the board where the power cord plugs in left of the transformer, look for D23. Its the same diode as the one you bought from radio shack. It is most likely burnt.
Remove that one and replace with a new one.
The radio should work fine now. Be careful when plugging that thing in.
Oct 11, 2009 | Cobra 29 LTD CB Radio
Blowing fuse
Your polarity protection diode has been blown. If you tried hooking up your CB and accidentally pushed the plug in backwards. Inside the radio, there are 2 big black diodes near the transformers, D8 and D23. Replace these with the same or bigger. You can the burnt one out and the radio will work, but if you hook it up wrong again, it will fry the radio.
May 02, 2009 | Cobra 29 WX NW ST 40-Channels Base CB...
Cobra 29ltd classic : no rx / tx
D23 is the reverse protection diode and it shorting is the primary reason your fuse blew. As you posted, power was applied in reverse, hence other components would also fail. Pls check:
1. D22 - 9.1V Zener Diode
2. TR23 (2SC1096) 9 Volts regulator
3. D19 - 5.1 Zener Diode
4. IC4 (TA7222) - Audio Amp
5. TR14 (2SC2029B/10) - Finals
6. TR15 (2SC2028B/20) - Driver
7. Most capacitors over 220uF (like C123, C114 & C112)
Hope that this be of help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Feb 04, 2008 | Radio Communications
Drills Logo
46 people viewed this question
Top Drills Experts
Are you a Drill Expert? Answer questions, earn points and help others
