Question about Cell Phones
How to unlock a Bush SN100-1 handset
Handset is locked
I can't unlock my vteck 15300 dect6.0 cordless pH handset help
I guess you mean the Keypad Lock/Unlock!
You can turn on the keypad lock of a handset.
In idle mode, press * button and then LOCK to turn on the keypad lock. "PRESS UNLOCK TO USE KEYS" is displayed on the LCD.
In keypad lock mode, press UNLOCK to turn off the keypad lock.
Aug 27, 2016 | Lands Phones
Bush tablet with key board
The TV is locked. You should unlock it with its remote control. If you wish to get some details; check the site linked here. Pull up older posts.
Unlock procedure and to override the password lock to many popular brand TVs and other devices are given. Search the site by type in this key phrase "How to unlock television"; in the search box at the top left of the display window, to get gathered related posts.
Jul 05, 2016 | Bush Televison & Video
I have RCA Dect 6.0 two handset keys locked on one. How do I unlock keys
Keypad lock To lock the cordless handset?s keypad: Press and hold [*] button for 2 seconds until you hear a beep tone, when the keypad lock is activated, shows on the display. To unlock the keypad: Press and hold [*] button for 2 seconds until you hear a beep tone. Or simply replace the handset on the charger cradle.
I'd put it back on the charger and see if that unlocks it.
Feb 23, 2016 | RCA Lands Phones
Handset locked
What make and model phone?
May 29, 2013 | Lands Phones
How to unlock BUSH 11 AK08 tv
Press UP & DOWN buttons together on tv's
local control and then switch on. You will see
SERVICE MODE. Do not press any button,
just power off the set, then on.
Mar 28, 2012 | Televison & Video
My E63 has been blocked by the Optus network...how do i un block it
Your handset can become fully locked due to exceeding the number of attempts to enter the correct unlock code. The type of handset you have will determine what process to follow to see if the handset can be unlocked.If your handset appears with a Code Error or does not unlock with the first or second attempt, you will need to call Customer Service to confirm the code. Once the handset is fully locked it will require manually unlocking from Optus and your handset will need to be sent away.
1 Insert SIM
N.B. Can be unlocked with SIM removed from handset however there is a 5 second time limit 2 Power phone on 3 Type: #pw+15 digit code+1 (where '15 digit code' is the unlock code) 4 Press Hash (#) - SIM Restriction OFF will display on screen for one second
Troubleshooting:
  • If the unlock code is incorrect the phone will display the message 'Code Error'
  • If the user tries to unlock a phone which does not have SIM Lock activated the phone will display the message 'SIM was not restricted'
  • If the syntax (#pw+) is incorrect when entering the unlock code - nothing will happen.
Jun 07, 2011 | Nokia E63 Cell Phone
HANDSET LOCKED
To Unlock it ...You can get the Unlock code here http://www.mobileunlocksolutions.com/motorola-motokrzr-k1/rs1wp9/
and Unlock the Mobile..........
Jun 08, 2010 | Motorola Mobility MOTOKRZR K1 Cellular...
Can't get "handset lock" to turn off.
try last 4 numbers of your number
Dec 02, 2009 | Sky Toys
Locked my lcd bush
!st-Try this...... Unplug the unit for about 3-4 hours, it shoul go back to nornal_DEFAULT...
Hopethatworks.
Nov 20, 2007 | Bush DVD142RC 14 in. TV/DVD Combo
Cell Phones Logo
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
