1996 Audi A4 Logo
Posted on Jan 13, 2009
When I switch gear in reverse my car won't move why?
I just had a rebuilt transmission in my car just a year ago. I got stuck in the snow and try to get out and my reverse gear went out.
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Jan 17, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
798
Points
My 1996 audi a4 2.8 awd reverse gear works for a couple of second then stops moving....
I have a 1981 ford f150 4x4 with a 302 engine An automatic transmission that works fine shifts properly going forward But when I put it in reverse I hear a clunk and sometimes it goes into gear and...
If the transmission was rebuilt 2 years ago the fluid and filter did not need to be changed. In a 1981 there are no trouble codes to retrieve so whoever suggested that is out to lunch, Unfortunatley you need to get the transmission rebuilt again, hopefully it gets done better this time. Using the dexron oil in Ford transmissions is something transmission shops do because they don't want to stock different fluids. While it's not likely that using dexron oil lead to the failure it would be better to use mercon or type F oil.
Transmission won t shift out first gear
Clogged transmission coolant line. Use air to blow out and replace filters and fluid.
RX 300 Transmission will not change gears nor engage reverse
check transmission fluid levelif you see metal shaving in oil pan time for rebuilt if you see more than a table spoon full of shavings but i would change transmission fluid and filter.if engine running higher rpm on acceleration transmission is slipping.
95 mustang v6 auto no forward gears but works in reverse had ****** rebuilt and same thing
Maybe your differential is shot and will only allow reverse spin or the transmission was not really rebuilt professionally. Was the transmission checked outside of your car after rebuild? Does your vehicle have a Powertrain Control Module (PCM)? Maybe the module went bad or faulty.
Slight hiccup going into second gear. rebuilt trans.
code p 0442 is the code for faults concerning the EVAP system
and will not show up in transmission changing gears
indications from your statement is problems in the TR sensor, VSS or TCM units
check for problem wires and connections
as for the problem of getting to park from reverse , check the adjustment of the park and neutral switch as one may have moved or be loose
2004 nissan altima 2.5s will start but won't move in any gears
You have a failed automatic transmission. You will need to remove and replace it or have it rebuilt.
I got my 99 jeep grand cherokee stuck in the snow. I called a tow ing company which dragged my jeep backwards out of the snow. Now my car will not drive in reverse. when I put the gear in reverse I can...
sounds like when you got it stuck you tryed to get it out and got the clutches hot and they stuck / welded when you put it in revurse does it pul the engine speed down like it is in gear but you give it gas and wont move trying to go forward and back at the same time sounds like trans rebuld time
9helpful
Transmission - no reverse
i had to put a new trans in my 2000 jimmy about a year ago there is something inside called a "reverse hub" its made from aluminum and not very hard to break..when mine broke i was stuck trying to move in reverse and it heard a pop then a winding down noise and sure enough its the reverse hub to fix it i just had the trans rebuilt
Top Audi Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you an Audi Expert? Answer questions, earn points and help others
