Question about Sewing Machines
Bobbin not picking up thread
It was all going fine until I changed to a zig zag stitch. Then the threads started to get bunched up. Now the thread is not being picked up by the bobbin. I have changed the needle, it is the right way round, etc. Cannot see any obvious problem such as debris. Help!
  • Sewing Machines Master
  • 7,365 Answers
Here are some suggestions
make sure the needle is the right one for the fabric being sewed
make sure the needle is all the way up into the needle holder
check to see if the top thread has come off the thread take up lever
try a different bobbin
if the machine is a front or side loading bobbin make sure the bobbin
is inserted correctly into the bobbin case and that the bobbin case
is inserted correctly into the machine
turn the bobbin the opposite way in the bobbin case
also clean under the needle plate and in the bobbin area for lint
it's a possibility that the machine could have a timing problem and
needs to be checked
Posted on Dec 10, 2012
SewExpress
  • 41 Answers
SOURCE: Picking up the bobbin thread
A few suggestions:
  1. Rethread top of machine from scratch with the presser foot raised, i.e. remove thread completely from all thread guides & paths and start from scratch, making sure thread is securely seated between tension disks. Once the needle is re-threaded, lower the presser foot and give the tail end of the thread a tug to make sure there's tension on it.
  2. Make sure the bobbin is turning the correct direction for your machine - and that the thread tail is under the tension plate or bobbin tension guide (depending on machine).
  3. Blow out any fuzz.
  4. Insert a new needle, making sure needle is pushed all the way up.
  5. Oil machine (in locations recommended in your owner's manual).
If the basic cleaning and re-threading (above) don't help, your machine(s) may be out of time or have another mechanical issue that will require a repair technician. We recommend a tech trained on your specific brands - they'll be better trained and able to get any repair parts that may be needed.
Hope this helps narrow down your stitching problems.
Happy sewing,
Kim & Linnette
Posted on Jun 27, 2008
  • 18 Answers
SOURCE: Singer 457 Zig Zag Sewing Machine not catching bobbin thread.
There are manuals avilable online to purchase for the singer machines, SOrry I was not able to locate a site that has them for free.
.... http://sewingonline.co.uk/singer-manuals.html
Posted on Aug 16, 2009
Michaelle
  • 65 Answers
SOURCE: No "Zig" to my "Zag"
I Love the support Brother gives!
Here's what Brother says about the Zig zag issue.
http://welcome.solutions.brother.com/BSC/public/us/ca/en/faq/faqh/000000/000000/000018/faqh000018_000.html?reg=us&lang=en&c=ca&prod=hf_xl5130eus&page=FaqEndPage
your manual (download)
http://welcome.solutions.brother.com/BSC/public/us/ca/en/model_top/HomeSewingMachine/hf_xl5130eus.html?reg=us&c=ca&lang=en&prod=hf_xl5130eus
Posted on Jan 27, 2009
Zenqi
  • 208 Answers
SOURCE: I have a Singer Special Zig Zag Model 418. I can
More than likely you have a broken vertical shaft gear.
When you turn the handwheel you should see the sewing hook moving under the bobbin case.
If not, take it to a sewing repair person and it should cost somewhere around $100 to repair.
Posted on Aug 21, 2009
  • 1788 Answers
SOURCE: I rethreaded a bobbin and
make sure that your needle is a good, sometimes there is a slight bend or burr and you do not notice. Replace it and make sure that the flat side of the needle faces the rear of the machine, then hold you top thread end and lower your needle and watch it hook the bobbin thread (when you put your bobbin make sure you have it in your tension slot and there is at least 6 inches) then gently pull your top thread and pull your threads to the back (have at least 6inches or else the needle can unthread.
Posted on Aug 31, 2010
Why isbobbin stitch on top weird how do i fix
sorry but the bottom stitch does not move but the top one does . if you want straight stitch the machine setting has to be changed to straight .
May 22, 2015 | Sewing Machines
I have dv9117, whenever I use the special stitches or even just the zigzag, it just keep doing straight stitch. Did all the cleaning, re-threading, taking out the bobbin and rewound bobbin thread. Nothing...
aside from cleaning, with a thread bunching problem it's always good to change the needle and make sure the top thread has not come off the thread take up lever and make sure the bobbin is turned the correct way in the bobbin case.
as for the zig zag stitches, it sounds like a gear or cam could be damaged or worn.
if someone brought me a sewing machine with the same problem, the first thing I would check for is a damaged or worn gear..
Oct 01, 2013 | Singer Sewing Machines
Bernina activa 210 won't zigzag and has bobbin issues on straight stitch
it's very possible that the machine is slightly out of time & needs to be service at a sewing machine shop
is the fabric & thread & needle compatable with each other?
did you use every thread guide when threading the machine?
is the bobbin in correctly?
is the bobbin warped?
Mar 20, 2012 | Bernina Sewing Machines
I have been using the zig zag stitch for appliques and all of a sudden the bottom thread which is a different color is showing on the top. I have rethreaded top and bottom threads, changed needles, cleaned...
it sounds like no bobbin thread tension. there should be some resistance when you pull on the bobbin thread. if there is none or too little you may have some lint or thread caught behind the bobbin case tension spring.
very carefully try and push the tip of a thin pin into the bobbin case tension spring and pick any accumulated thread or lint out.
if the bobbin case spring is clean, try tightening the bobbin tension a little at a time until your zig zag looks ok.
of-course all this is done after checking needle threading and needle for damage.
scott.
Jul 29, 2009 | Janome Sewing Machines
The bobbin thread is bunching on the under side of the fabric,. Decorative designs are close together, not like the pattern and when I use the more intricate decorative designs, they just sit in a quarter...
Make sure that you use the F foot when using decorative stitches.
The stitch balance my be off. Remove the accessory bin and you will see a large plastic screw with a + and a - and an arrow. Using a coin, turn the arrow to the center and test. Turn the arrow towards the + to stretch the pattern out.
If this doesn't work, it must me calibrated internally and requires an experience hand.
Jul 07, 2009 | Janome Memory Craft 9000 Computerized...
Brother LS-2125 Upper Thread Snapping
I had the same problem and it was so frustrating! It was happening to me because I wasn't using the right size needle. Go up a couple of needle sizes and see if that helps.
Feb 12, 2009 | Brother LS-2125 Mechanical Sewing Machine
Zig zag stitches are not holding
When ever a machine is jamming up the bobbin thread, it is a result of your top tension. It is either set to low (under 4), or the thread has come out of the take-up lever. Check your threading, fromt he spool pin, down to 2 and up to 3. Three is the take up lever. From the take-up lever down to 4. Set the thread behind the thread guide and thread the needle form front to back. Low quailtu thread 9dual duty or all purpose) can also create this problem.
thanks,
Bonnie
Aug 24, 2008 | Kenmore 15516 Mechanical Sewing Machine
Suddenly zig zag stitch not working?
Because it is almost a straight stitch but the needle continues to move in a zig zag fashion is reason to believe it is in a long stitch. By changing the number of stitches per inch there will be a very noticeable looking zig zag stitch.
Mar 25, 2017 | Brother XL-2610
Sewing Machines Logo
116 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
