Question about Cisco UNIFIED IP PHONE 6921 CHARCOAL STD HANDSET CP6921CK9 CP6921CK9
I cannot make external calls - Cisco UNIFIED IP PHONE 6921 CHARCOAL STD HANDSET CP6921CK9 CP6921CK9
  • 26 Answers
What type of phone system are you using? Cisco Callamanager, UC500, etc...
You may have a NAT or firewall issue which is blocking outbound calls, need more info to try to help.
<a rel='nofollow' href="http://www.ciscopowercube.com">Cisco CP-PWR-CUBE3</a>
Posted on Dec 13, 2012
My phone only works on speaker, even when it have a volume level of seven, it won't work on a regular phone call. Also any icons that use to beep no longer have any sound
Notifications sounds from either external speaker or headphones, but never from the ear piece volume. Your question suggest that the external speaker is damage but it only works on external speaker. Try using a headphone or a bluetooth to make calls, if they work, then you need to fix the external speaker.
Jun 26, 2017 | Computers & Internet
Transfer calls to External Number and Hangup
have you tried staying on till the other arty answers then hang up
Mar 18, 2015 | Panasonic KXDT343 Phone
I would like to know how to transfer a call from one phone to the other on a cordless versatis p100
During an external call:
1. Press <MENU> and <UP/DOWN> to select INTERCOM.
2. Press <OK> to select the desired handset to intercom with.
3. The external call is put on hold automatically and the called handset
rings.
4. Press <TALK ON> on the called handset to establish an internal call.
5. Press <TALK OFF> on the calling handset or put the calling handset on the charging cradle to end the current call with the external party.
6. The external call is transferred to the called handset.
Jul 14, 2014 | Uniden Cordless Phone
Stop external calls ringing allow internal calls
The lines must be programmed to Appear Only instead of Appear and Ring.
This is done under Config/Sets/LineAccess/LineAssignment.
If unsure of Config password, programming navigation then call in a tech/vendor....1 hour min service call unlell your vendor has remote access via RAD or IRAD.
Sep 21, 2012 | NorStar T7316 Corded Phone
How do i forward my phone calls
HOPE THIS HELPS:
Call Forward • The first handset (HS1) can forward an external call to another handset (HS2, HS3, or HS4) by pressing and holding the INTERCOM key. After entering the handset number to which you want to forward the call, HS1 will display CALL FORWARDED. • To answer the call, another system handset can press PHONE, SPEAKER or any dial pad keys.
NOTE: If the other HS2 does not respond within 30 seconds, the external call will be returned to HS1 and its display will show CALL BACK. If the returned call is not answered within 30 seconds, the external call will end automatically
THE MANUAL CAN BE FOUND HERE: http://dl.owneriq.net/c/c72cee7d-bd52-42c1-b9fa-2ee5ccc500af.pdf
Jun 27, 2011 | AT&T E5630 Cordless Phone
How to remove FWD/DND FROM A PANASONIC KX-T7030X PHONE
Press intercom button
dial *71
choose the call forwarding type to cancel as follows
dial 0 for internal and external calls
dial 1 for external calls only
dial 2 for internal calls only
dial 0 to cancel call forwarding
press speaker to end
Jan 18, 2011 | Panasonic KX-T7730 Corded Phone
Ring tone for internal and external calls
this is a change your system administrator will need to handle, (or your phone tech). There is an option in the under "system options" called internal ring cadence for external callers; this is where you can have the system do a double ring for External and a single ring for internal or vice versa.
Jun 25, 2009 | Mitel 5212 IP Phone
How return an unanswered call in the external display in motorola v8
If you get a call and you don't answer - it's basically a missed call. Ut displays on your external screen for a while, till the backlight goes off. While it's still displayed on your outer screen, you can use softkey on the side of the phone to acknowledge the missed call, but you can't view the details, or bring it back to the external screen once you select 'okay' or open the phone.
Nov 10, 2008 | Motorola Mobility RAZR2 V8 Cellular Phone
Call forwarding to outside line
To send a call to another telephone within your system, or to an external
telephone. You may not be able to transfer a call on an external line
to an external telephone, depending on the capabilities of the lines.
1. Make or answer a call.
2. Press the feature button then press 70.
3. Call the person you want to transfer the call to.
4. Stay on the line if you wish to speak to the person first.
5. Press the Release button to complete the transfer.
If an external call is transferred to a busy internal or network
extension, or is not answered after a few rings, the call automatically
rings you back.
Sep 24, 2008 | Nortel T7316E 2-Line Corded Phone
Cisco UNIFIED IP PHONE 6921 CHARCOAL STD HANDSET  CP6921CK9 CP6921CK9 Logo
114 people viewed this question
Top Cisco Computers & Internet Experts
Prashant M
Prashant M
Gareth Tomlinson
Gareth Tomlinson
Are you a Cisco Computer and Internet Expert? Answer questions, earn points and help others
