Tishoba vcr v-231 tape counter does not come on, no picture from vcr
No numbers come up on the tape counter. just dashes going round in a rectangular shape. auto flashes a few times ,then goea off. no picture or sound when tape is running.
    Top Expert:
  • Televison & ... Master
  • 14,553 Answers
Someone would have to look inside to see if the tape is not moving, no movement will cause it to shut down--have to look inside first.
Posted on Dec 10, 2012
4 Suggested Answers
  • 275 Answers
SOURCE: Sony SLV-940HF VCR Will not accept tape
Dear Rob, There can be two reasons for your problem.Let us consider the simpler and most likely cause.....Belts!!! Unplug the Plug from the Power socket. Open up the top and bottom Panels.Check the belts. Most likely you will find a belt has snapped ( a 80% possibility) or become very very loose. Also check the Tape Loading mechanism,there is a small belt which connects from the Loading motor to the Loading Mechanism. Replace the belts as a entire set. Let me know if this worked out. Good Luck.
Posted on Jan 27, 2007
SOURCE: JVC HR-S9500U
OK, found the problem. Another website had the same question on the HR-S9600U, the 9500's replacement:
http://www.cippico.com/bbs/viewtopic.php?p=528&sid=ce3dfc944e4539181195720b836021f4
I checked my vcr, and, sure enough, there was a sort of clicking sound coming from the drum area immediately before the unit would go into "Auto" mode. I removed the complete drum assembly, and tore into the little gearbox, and found the two black, plastic gears with inside pinions that drive the metal screws to change the video head position had each cracked and were slipping on the shafts. This caused the gearbox to bind up.
Using a jeweler's screwdriver, I roughed up the metal shaft and the inside of the gears where they slip onto the shafts, and glued them on using a two-part epoxy. I then re-assembled it all, sorta setting the screws about two turns after their contact with the base of the upper drum. Now, upon power-up, the drum adjusting motor toggles one direction, then the other, and the unit stays on. Playback seems OK.
So, there you go. Yay me....
Posted on Dec 28, 2008
dvdcdlaser
  • 1285 Answers
SOURCE: I was trying to view so vcr tapes I had video some
yes, this is what happens to analog tape...it gets corroded because it was not stored in a cool spot...your vcr heads are cleaned that is why u still hear the audio...(video will go first all the time)...but if you play it all the way through once a twice (see if you can save it ...dvd)
Posted on Jun 27, 2010
Vcr tape counter does not work
Try to remove power from the unit for a while and power back to see if that clears it or not----If a on screen counter display repair will usually cost too much or with this brand parts will not be available.
Dec 09, 2012 | Samsung DVD-V6800 DVD Recorder/VCR
Vcr has sound but no picture
You will need to clean the heads on the vcr. Find a good tape cleaner. Or you may use a cotton cloth with some rubbing alcoho,l and wipe the round cylinder that spins around the vcr tape. This is a common problem on all vcrs and vcr combos. Thanks for asking and show all hands of support!
Sep 08, 2011 | Zenith TVBR1922 19 in. Combo
Hello! I have a Sanyo VHR 120E video recorder. The trouble is that the tape remains and it does not add up! How can you make out of it?
Tape remain counters are never accurate. For one thing VCR tapes are made by different makers and some like to give you extra. Some counters allow around 5 minutes extra at the end of the tape. Treat all times as approx, then you can't go wrong.
Nov 19, 2010 | Sanyo Televison & Video
Intermittent loss of video (mimicking dirty heads symptoms)
Control head dirty. That is where the tape counter picks up the frame pulses.
Jan 18, 2018 | Sony SLV-N750 VHS/S-VHS playback VCR
Playback problem on SP Tapes - Top 1/3 of screen wavy lines
there are guide posts that the tape goes around, they need to be adjusted if your good at that stuff take off cover and while playing tape be careful you could damage video head.with flat srew drive . adjust right post buy turning clockwise or counter clockwise. this could be hard i hope i helped , When i first started ny video shop 1987 we started doing only vcrs.
The video head also could be bad. thanks doctor video
May 04, 2008 | Sony SLV-D350P DVD Player/VCR
No picture or counter
Are you sure the tape is still moving?...accordianman
Feb 10, 2008 | Sony SLV-640HF VHS VCR
VHS Tape
Possibly the tape is wound too tight and is not actually playing when in play mode.
Also, tapes can be accidentally erased. If it is placed on a speaker or other magnetized surface it will erase itsself. The magnet draws something out of it.
I'm not sure exactly how it works but I know it happens.
Don't give up just yet. Check with your local video rental store... maybe they know a trick that will help you.
Good Luck :)
Jan 02, 2008 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Video tape gets eaten on rewind
Does the machine play tapes well? Clear steady picture and all? No tracking bars? wavering sound? Tape chewing is generally a problem with a bad Capstan Pinch Roller, Associated symptoms are as above. Please do recheck or confirm if any of the above problems are also present.
Aug 30, 2006 | JVC HR-VP650 VHS VCR
VCR WILL NOT PLAY
The problem is the tape mechanism is malfuctioning. It trys eather to load or play a tape and a sensor inside tells the microprocessor to shut down this mechanism before damage is done to the tape. BUT sometimes a malfunction causes a damaged tape too. this unit has NO user serviseable parts inside itself, so its time to take this puppy into a repair shop to see if its worth the repair , Unless this units more then a few years old?? then its time to buy a shiny new unit. Good luck
Jul 09, 2006 | Emerson EWD2203 DVD Player/VCR
Televison & Video Logo
Top Televison & Video Experts
