My cd player is skipping
Only skips when used for more than an hour and never skips in the same place.
  • Audio Player... Master
  • 1,258 Answers
You can have degraded operation due to a foggy laser lens and there have been some models that have been known to have problems due to defective large filter capacitors going bad in the power supply. This can also be the result of a thermal break in a solder joint. Wave soldering that I have seen over 40 years is a reason for a lot of failures on all types of equipment.
Posted on Dec 11, 2012
  • graham Dec 11, 2012
    Thanks Sam. Can this be fixed/cleaned easily ?
  • Sam Palermo
    Sam Palermo Dec 11, 2012
    Add a CommentDepending on the construction of the model. Some units have easy access to the lens and other are hidden and you have to take parts off to get to it. Also the cleaning is maybe not the only thing needed. Give it a try, I use a sparing amoun of Windex on a cotton swab that is not touched by fingers- as in no finger oil on it. The lens must look clear and clean of residue when you are done.
petraman7
  • 1175 Answers
SOURCE: cd player skipping
The DVD transport rides on chrome rails. These get dust and stuff on them and wont allow the optics to track.
If you dare, open the unit UNPLUGGED from the AC.
See if you can get at those rails easily. clean with WD40 on a swab. clean with a new swab . then a couple drops of mystery oil on a swab and run down the rails over and under.
You must be VERY gentle if you clean the lens with isopropyl
Posted on Feb 24, 2008
StuartB
  • 807 Answers
SOURCE: New laserunit won't work
You seem confident enought to take it apart, have you tried cleaning the runners that the laser runs backward and forward on.
Some times they collect dirt/dust and the laser can't move smoothly so it jerks and skips.
Posted on Mar 14, 2008
SOURCE: numark cdn95 left player skip even with new cds
CDN95 uses the same CD transport as a CDX, aka....junk. Its mostly likely defective, replace left CD drive.
Posted on Oct 17, 2008
mikeymiddles
  • 58 Answers
SOURCE: CD SKIPS
  OK.  I think I can help.  There are two very simple solutions to a skipping CD player.  You have tried one already, that is, clean the laser-reading eye.  Lets assume you did that correctly and that is not the problem.         So, to continue, the machine must be opened. Equipment required: Jewellers screwdrivers, small number one screwdrivers, cottonswabs or Q-tips, Petroleum jelly, 100% isopropyl alchohol is ok but if you can use Denatured alchohol that is the best.        Using a set of fine jewelers screwdrivers or just a small #1 Regular or Philips screwdriver to remove the top cover of the CD player.  Don't force anything and place the screws in a cup so they are not lost or misplaced. I work in a plastic cafeteria tray to contain any dropped screws    The problem here usually occurs in trusty old CD players that have always worked fine and the problem (skipping) starts out small and gradually progresses to always skipping.  The problem and solution are mechanical in nature.    First locate the laser eye and check it physically for any optical obstructions (dust, dust-bunnies, lint, feathers, hair, lumber, etc.)    When you are sure the laser-eye is clean find two parallel small (usually 1/8" or about 3mm wide by about 3 to 6 inches long ) chrome metal bars that the laser eye rides back and forth on.  The eye assembly has a small contact-lens looking clear plastic lens mounted on a plastic carriage that moves from the center of the disc toward the outside as it tracks the disc.  It will have a small ribbon wire harness that can expand and retract with the travel of the laser-eye carriage.  Now look at the two-parallel shiny metal bars the carriage should slide on. The lubricant on these bars lets the eye assembly move smoothly without vibration (or skips) over the length of the two steel bars and your CD plays perfectly when they are clean and lubricated.  This skipping problem can occur if something sticky is spilled into the unit. Soda or beer dries out and if it gets on these steel bars the laser-eye assembly can vibrate and chatter as it tries to track over the CD's info causing skips.      So the solution involves carefully testing the unit with the lid off to see what is going on inside when the unit plays (or attempts to play) a CD.  If the obstruction to the path of the eye assembly is severe, the tiny drive gears can be damaged, broken, or stripped and the eye will not move smoothly without new parts (Factory Authorized Service Personnel are recommended in that case)   Use the Denatured Alchohol and swabs to completely clean and dry the steel track rods that the laser - eye slide on, take care to clean any built up old grease (manufacturer lubricant) that may build up on the holes on the sides of the Laser-eye assembly where the steel track rods go through it.  After cleaning the rods use a new swab to apply a TINY amount of petrolatum evenly to each rod.  I cannot stress enough how important it is to use as little lubricant as possible ONLY on the rods and NOWHERE ELSE!  It is very easy to get the petrolatum somewhere you don't want it.  Be Careful!  One mistake here could cost you the entire unit!  after application, physically slide the eye assembly over the bars to smooth out the petrolatum lubricant evenly. (in the event the eye-assembly doesn't manually slide, don't force anything and go to the next step). make sure you did not get any petrolatum where you did not want it, if you did clean it with cotton and good old, denatured alcohol and put a CD in and before playing it, advance the tracks from track 1 to the highest numbered track and back several times to smooth the lube more.  Play the CD and replace the lid and screws in the order you removed them.      Good Luck!
Posted on Dec 11, 2008
  • 35 Answers
SOURCE: my cd player skips
Unplug the unit, remove the cover and clean the laser lens glass with a Q-tip. Spray a bit of window cleaner on one end of the Q-tip (over a sink), then use that end to clean the objective lens of the laser. Then dry it with the other end. Wipe Carefully!
Do not apply pressure while cleaning, wipe slowly and then reassemble the unit and test. This is a common problem on many laser-based products, dust and smog get inside the unit and cloud the lens, causing it to skip or not read at all.
Posted on Mar 02, 2009
CD player skips even though the same cd does not skip in other cd players
The laser in the cd player is most likely faulty or dirty. Buy a cd laser cleaner.
Aug 02, 2014 | Coby Cxcd248 Portable Cd/Cassette Player...
My pioneer cd player PD- m501 skips tracks and cds sometimes!!! why?
it could be lots of things, how many hours of use your player has? (laser opticals have a life time) are you using cheap recorded CD's? ar the speakers too close to the player (loud base could make it skip) the laser optical could be dirty try a cleaning disk.
Jan 04, 2011 | Pioneer Audio Players & Recorders
Does the TEAC CD x60i with ipod capabilities include an alarm system that wake u up with music from the the ipod that u have pre select?
The unit doesn't have an alarm, but it does have a timer that allows you to set it turn on at a certain time and off at a certain time. Not exactly the same as an alarm clock.
Press the timer button until "timer" indicator and "on" appear in the display. Hour will flash. Press the skip button to change the hour then press the time button. Press skip to change the minutes, then timer button. You now change the off time the same way. The next push of the timer button has set the time. But, now use the skip button to select the source. Pressing the timer button this time will advance to the volume setting and again advance by the skip button. Timer is now set. Make sure your source is ready to play (station on tuner, CD has a disc or iPod is connected).
May 06, 2010 | Teac CD-X6 CD Player
3 disc Phillips cd player sometimes skips. It is
At some time in its life, the laser that reads the CD starts to get too weak to operate reliably. That's probably what's happening here. Unlike mechanical parts that can be inspected for wear, electronic parts tend to work fine one day, then the next, poof. The laser assembly is replaceable if you can locate the part and find someone to install it. An electronic service shop could give an estimate for repair. If you can provide the full model number, I'll see if I can find the part number.
Mar 08, 2010 | Teac AD-600 3-Disc CD Changer
Durabrand model cd-968 mp3 anti-skip cd player Does skip...
I understand what you are saying. The Durabrand is very cheaply made and the ani-skip actually does not work near as long as stated by company. I would buy more expensive player or a different brand.
Look for 60 Second Anti-Skip if you want a good one.
May 13, 2009 | Durabrand CD-968 Personal CD Player
Sony RX66
Optical pick-up lens may be dusty or the pick-up is out of focus.
Have serviced
Apr 27, 2008 | Audio Players & Recorders
Skipping yamaha 765
I have a very similar type unit, a Nakamichi CDC-3 that had the same problem. I found this link....
http://repairfaq.ece.drexel.edu/REPAIR/F_cdfaq6.html#CDFAQ_001
I spent about two hours fixing mine. The sled mechanism was binding somehow, causing random skipping. The first 10 minutes was getting it apart and figuring what was wrong, the remainder was spent getting all those tiny parts back in the proper place.
Look up the exact symptom before going at it (probably long skips). Set aside a long slow lazy day with nothing to do. DO NOT drink too much coffee, you will be handling tiny parts that go in tedious locations, so you don't need caffeine jitters adding to your misery. Take your time and be careful. It's well worth it. Mine plays like a new one.
Nov 26, 2007 | Yamaha CDC-585 5-Disc CD Changer
Sony MHC-GX450 CD's Skip
Try using a laser lens cleaner. I have the Maxell Thunderon one thats on a Gold CD that you can get at best buy for like $20 or so, seems to work good here on the computer disc drives
Nov 17, 2007 | Sony MHC-GX450 CD Shelf System
Radomly clips or skips
I have exactly the same thing. I am on my second one too.
Mine is an australian model purchased in Sydney.
Oct 27, 2007 | Cambridge Audio 640C
 Grubhead
Grubhead
