Question about Microwave Ovens
Water coming out of Microwave during use?
While I'm using my Defy Microwave water comes out the back and accumulates underneath it on the counter - Manufacturer tells me it's normal. Is it?
    Top Expert:
  • Microwave Ovens Master
  • 14,553 Answers
L would think water and an appliance that uses electrical power are not normal--especially if the water should get to the wrong place....
Posted on Dec 10, 2012
  •  Martha Tesnaar
    Martha Tesnaar Dec 11, 2012
    That's what I thought. I'm fighting with them now to do something.
SOURCE: Water leaks out during making coffee
Sorry for the typo..it should say Cracked..
Posted on Feb 21, 2008
  • 234 Answers
SOURCE: no heating or power to microwave oven
You have a fuse in the back that's problem is blown
Posted on Mar 13, 2009
MicrowaveSvc
  • 9098 Answers
SOURCE: Loss of power during use
You didn't mention your brand or model, but I'd bet it's a GE/Hotpoint or other Samsung-made oven.
This problem is almost always due to a defective or loose magnetron causing electrical interference and disruption in the control circuit board.
Details covering some previous models are in GE's bulletin here. Even if your model is not on the list, the same problem can occur.
If your magnetron was recently replaced, it may have loose mounting nuts or bolts or maybe the wire mesh RF gasket was not installed or got pinched.
NOISY MAGNETRON TEST (c) 2009 William E. Miller prototech@usa.net (permission granted by poster-author to FixYa to keep this document on their site intact)
One way to test it is to do the following:
1. Unplug the microwave or turn off its breaker.
2. Open the door, then detach the control panel as shown in the video at http://www.microwavedisplay.com and swing it down, but without disconnecting the wires. )If you have any trouble getting the grille off once the screws are removed, slide the hood vent grille to the left about 1/4", then then pull it forward. On some models there are L-shaped clips that fit into a slot to hold bottom of the vent.)
3. Plug the microwave back in.
4. Make sure neither you nor anyone else reaches in behind the control panel. There will exposed high-voltage connections.
5. Put a few cups worth of water in a microwave-safe container and place it inside the microwave.
6. Shut the door.
7. Run the microwave for about 1 minute or so on full power. (Time Cook > 1 > 0 > 0 > Start, e.g.)
8. If it does not fail, try it several more times.
9. When the water boils, change the water and try again.
NOTE:
If your model does not have a door handle, you will need to unplug the oven and reattach the control panel to be able to open the door.
If it still does not fail, I would recommend that you put it all back together and keep using it until it fails more consistently, then repeat this test.
While a microwave should never be left running unattended under any circumstances (as your owner's manual will tell you) it's even more important when one is exhibiting a failure or any odd behavior. So play it safe and stay with it while it's running!
If you or someone you know want to replace the magnetron yourself, you will need to remove the oven from the wall.
If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
You can download GE owner's manuals and installation instructions
here.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can find links to helpful exploded view diagrams and part ordering help
here. I'd recommend that your bookmark this link to your favorites.
If it's within the magnetron portion of the warranty (usually 5-9 years) but out of the original full warranty (usually 1 year), then your manufacturer will cover the part cost, but not the cost to visit you or the labor charge to do the work.
If it's under magnetron warranty, GE will send you the magnetron to do it yourself. Call them at 888-239-6832.
If it is not within the magnetron warranty, you can find links to helpful exploded view diagrams and part ordering help here.
If you prefer to arrange service by an authorized service center, GE Customer Service is here.
Posted on Dec 25, 2009
  • 119 Answers
SOURCE: why does my microwave oven leak water underneath.
After heavy use, ie jacket spuds or defrosting a lot water moisture will develop, cure for this is to wipe down after use
Posted on Feb 13, 2010
heatman101
  • 43501 Answers
SOURCE: Was heating water in a Sharp Carousel Microwave
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
sghg
Posted on Sep 30, 2010
The turntable doesn't turn.Will using the microwave until I can replace the motor harm anything?
If the turntable platform has wheels sometimes they accumulated grease or other material that gums them up. This will cause the turntable to lurch and/or jump during rotation.
Remove the platform and soak it in hot soapy water taking care to clean each wheel.
Rinse, dry and re-install the platform.
Jan 20, 2015 | GE Spacemaker JVM1750 Microwave Oven
Unable to eliminate odour from previous cooking despite the fact that I wipe the microwave with a soapy cloth & then with a clean cloth each time to Microwave is used
  1. Fill a plastic bowl with 1 qt. of warm water. Add 2 tbsp. of liquid dish soap and 1/4 cup of chlorine bleach to the water. Thoroughly mix the solution.
  2. Dampen a clean cotton rag in the solution. Wipe all inside surfaces of the microwave with the soapy rag to remove food debris and stains. Scrub stubborn residue with a nylon scrub brush.
  3. Moisten another cotton rag with warm water. Wipe the microwave surfaces with the rag to wash away soap and loose food debris. Thoroughly rinse the inside of the microwave.
  4. Dry the microwave's interior surfaces with paper towels. If odors remain in the microwave, fill a microwave-safe bowl with 1 cup of cool water. Add to the water 2 tbsp. of baking soda, half of a chopped lemon (including pulp and rind) and four whole cloves.
  5. Place a microwave-safe plate on the microwave turntable. Set the bowl on the plate.
  6. Heat the microwave on high for three minutes. Operate the microwave according to the manufacturer's directions. Keep the bowl in the microwave for 15 minutes.7
  7. Remove the bowl from the microwave. Wipe the microwave's interior surfaces with clean paper towels to remove steam moisture.
  8. Leave the microwave door open overnight to completely air out any remaining odors.
  • Sep 05, 2012 | LG LTM9000 Microwave Oven
    Iv'e purchased a 5 cup homemaker rice cooker but your leaflet dosen't explain how much rice or water ratio
    I am sure that there is some official rice water ratio, but my method works for me.
    1. Rinse the rice until no more "white" comes off of it and the water runs clear.
    2. Let sit for one hour in water.
    3. Drain water.
    4. Add water to 1" over the top of rice and start in cooker.
    5. Add 1 cup of water per day until rice is used up.
    Jun 25, 2011 | Microwave Ovens
    Kenmore microwave model #565.60502990..........the microwave comes on when the door is opened!
    First you need to determine when that happens if it's actually heating, or if it's just the fan and turntable coming on. (I suspect the latter).
    You can test it by putting in a cup of cold water and letting it run (with yourself standing to the side of the microwave) for about 30 seconds.
    Then unplug the microwave and check the water for warmth.
    If it IS heating, then you probably have a control board issue and we can help you here.
    If it is NOT heating, as I suspect, then I think it is a door switch or switch mount issue.
    See these files:
    http://031d26d.namesecurehost.com/mwd/safety.txt
    http://031d26d.namesecurehost.com/mwd/disassembly.txt
    http://031d26d.namesecurehost.com/mwd/doorsw.txt
    May 25, 2011 | Kenmore 60502 Microwave Oven
    Hi hope you can help, I have a 2 door fridge with a bottom draw freezer purchased new 2008 and I have lost the instructions.The prolem I need diagnosed is water leaking from the freezer draw. thanks.
    Sounds to me like you have a leak, probably from an ice maker tubing connection or vinyl water supply tube itself. Have someone get a good flashlight and get a good closeup look at where the water is coming from. The water supply to the fridge's icemaker comes from the house wall, floor, or cabinet area of sink. Often they are connected to fridge, then someone moves the fridge to clean and the line gets run-over or tugged on too hard causing a leak. If that is cause, install a new line (hardware stores have these specific to ice makers, 1/4" vinyl or copper tubing) and it should be coiled several times in mid air near the wall, so if fridge is moved out it just uncoils not incurrs damage from un-noticed tension (full amount of water pressure in that little line).
    2nd possibility for newer type fridge. All frost free fridges have a pan underneath that catches condensation from coils, from the pan the water evaporates into the air where balance is achieved and pan is never full. On rare occasions, like during moving, on some the pan isn't fastened down and can fall out of place, then condensation water from the coils falls to floor (not any great amount but some).
    Jan 15, 2011 | Microwave Ovens
    My microwave does not vent out moisture well and leaves a lot of moisture accumulating into water at the bottom of the oven and on the door and sides. The vent is not blocked. It just doesn't clear...
    The fan that cools the magnetron also helps exhaust water vapor. Does the fan sound as strong as it used to? Is the vent at the back of the microwave clean? Sometimes lubing fan motor bearings with light machine oil will speed up the fan. You would have t remove the cover to gain access.
    Jun 20, 2010 | Panasonic NN-H504WF Microwave Oven
    Why does my microwave oven leak water underneath? Happens overnight and has been located to the oven.
    Feb 12, 2010 | Microwave Ovens
    No heating or power to microwave oven
    Mar 13, 2009 | Microwave Ovens
    We just bought the microwave 2 days ago. Was cooking bacon & when I went to put more in it won't come on. The light is out & nothing will work. Checked the house fuse & unplugged the microwave...
    I would guess that the magnetron overheated since bacon is a low-moisture food.
    (Does your manual suggest putting a half-cup of water in the unit when cooking bacon or popcorn?)
    If it didn't come back on (even after resetting the unit by unplugging it for a few minutes then trying again) then I would say the magnetron thermal cutout blew.
    But since it's under warranty, GE will fix it for you free.
    GE Customer Service is at http://www.geappliances.com/service_and_support/contact/
    We're happy to help and we appreciate your thoughtful rating of our answer.
    May 26, 2008 | GE Microwave Ovens
    Microwave Ovens Logo
    250 people viewed this question
    Top Microwave Ovens Experts
    William Miller
    William Miller
    Are you a Microwave Oven Expert? Answer questions, earn points and help others
