Question about Whirlpool 25 Cu. Ft. Counter Depth Side-by-Side Refrigerator - GSC25C6EYY
Whirlpool side by side counter depth refrigerator freezer blower runs all the time
  • Whirlpool Master
  • 4,655 Answers
Sounds like a relay on the motherboard or the high voltage board is fused together or broken causing the fan to remain on=> W10356039 Relay Board If you need one on one help just let me know. Which fan is remaining on? Condenser or evaporator? Here are a couple of parts list=>
  • GSC25C6EYY01.pdf (2800.72 KB)
  • GSC25C6EYY02.pdf (2798.31 KB)
  • I am ready to help so if you would like my assistance please respond, Thanks Sea Breeze
    Posted on Dec 10, 2012
      Top Expert:
    • Whirlpool Master
    • 9,472 Answers
    Check to be sure the coils on the back are lint free.
    peyton32034
    • 410 Answers
    SOURCE: WHIRLPOOL GS6SHEXNL00 SIDE BY SIDE REFRIGERATOR LIGHT
    funny you asked this question i just had this same problem this week at a customers home. you need the electronic control board located in the compressor compartment behind the refrig. it is mounted in the white box on the left hand rear corner. the whirlpool part number is 2304095 and it is around 175.00 i'm not sure who a local part supplier around you would be if all else fails you could get thru sears..
    Posted on Jan 07, 2008
    • 27 Answers
    SOURCE: WHIRLPOOL CONTROL PANEL
    Hi. Your temperature control board display is bad. You may also have a power convertor board located next to the compressor. Normally you would replace the temperature control board first. I have a temperature control board listed on Ebay as item number 250211412492. Good luck, Mack
    Posted on Feb 02, 2008
    catriver
    • 878 Answers
    SOURCE: Whirlpool Refrigerator - Model# ED22LF
    Tom, I would start with the overload and relay that is on the compressor, If it is white it's a good possibility that it has failed. The fact that both sides are not cooling leaves me to believe the compressor is not operating. Take the overload and relay off. If they are both contained in a white cover shake it. If it rattles, I believe that is your problem. Let me know what you find...Catriver.
    Posted on Jun 28, 2008
    mikedurland
    • 481 Answers
    SOURCE: whirlpool conquest 2001 GS6SHAXKQ01 refrigerator side by side top part is not cooling
    the first one sounds like it is slowly leaking freon.
    •  the second Sounds like a defrost problem. Check to see if there is any frost buildup in the back wall of the freezer. If so, it is not defrosting as it should.
    • possible causes:
    1. bad defrost timer/control board
    2. bad defrost heater (in freezer)
    3. bad thermo switch in freezer
    If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items. If it still has a problem then it might be the compressor and you should probably replace the machine.
    Posted on Jun 29, 2008
    buddymcl777
    • 67 Answers
    SOURCE: Whirlpool ED5PHAXSB side by side refrigerator not cooling...
    There are a lot of possibilitys. You'll have to use the process of elimination.
    But it could be the thermostat (make sure your setting is midway) The milk spoiling indicates it is too warm so bacteria is breeding
    Get a refrigerator / freezer stand alone thermostat (about $5) That will give you accurate readings. The fridge shoud be between 35 and 40 F and the freezer 0 plus or minus 3 when set correctly
    It could be your condensor fan is clogged or just that your coils need cleaning (underneath or behind) Use a vacuum with the brush end or chisel point. Dust can cut you efficiency by 20 or 30% by itself.
    Assuming this is frost free model the defrost timer may be acting up in the freezer.
    Forgive me for not knowing where the coils are and if it is frost free but I can't find a manual for this particular model. However the principles apply in any case.
    Posted on May 09, 2009
    Leak under freezer portion
    Check out these tips...they can help you figure out what is going wrong with your refrigerato
    Refrigerator not Cooling or Fridge not Cooling
    How to Defrost Refrigerator
    Defrost Timer Problem
    Water Running in refrigerator from Freezer
    Refrigerator or Freezer not Cooling or Getting Cold
    heatman101
    Feb 14, 2011 | GE Profile 23.3 Cu. Ft. Counter-Depth...
    Tip
    New Refrigerator and Refrigerator Depth
    When buying a new refrigerator many people like the look of a built-in refrigerator but find that they are very expensive and will require extensive remodeling to make them work for their kitchen. The answer becomes the counter depth refrigerator. These refrigerators depth can vary in the depth between 23 and 27 inches. This will keep the front of the refrigerator back about six inches more than a normal refrigerator which often run between 30 to 34 inches in depth. While the front of the counter depth refrigerator may still have to stick out beyond the cabinets so that the door can be opened, it does not require that it stick out way beyond the cabinets, as many normal depth refrigerators do.
    The configuration of many counter depth refrigerators is the double side by side door model with a freezer the full length on one side and the fridge on the other side. They also come with the freezer in a drawer on the bottom and a double door fridge on the top.
    Because of the depth limitation many of the counter depth refrigerators are wider and/ or taller then the standard depth models. This gives the room for the refrigerator cu ft or refrigerator cubic feet (internal size or capacity) to be larger with less depth. If you are considering one of these models, make sure that you measure the space available to make sure that you can fit the refrigerator into the hole that you have for it.
    The price of the counter depth refrigerator will also be a bit more then the standard depth refrigerator. While this cost may be more, they are still much less then a true built-in refrigerator. If you check you can also find counter depth refrigerators that will allow you to customize the front panels with wood, just like true built-in refrigerators.
    What refrigerator best meets your needs can only be decided by you. A new refrigerator will often last about 15 years. Take the time to check carefully into what type and size will be the best for you.
    http://www.fixya.com/support/r4326839-refrigerator_maintenance_tips
    http://www.fixya.com/support/r4327013-refrigerator_efficiency
    http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
    http://www.fixya.com/support/r4326731-new_refrigerator_size_or_refrigerator
    http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
    http://www.fixya.com/support/r4020581-moving_refrigerator_best_way
    http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
    http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
    http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
    on Mar 13, 2010 | Refrigerators
    Refridgerator runs continully
    Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
    If you are hearing a clicking or buzzing then check out the last two tips.
    If your refrigerator is running but warm, then...
    Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
    Refrigerator
    Condenser Coil Cleaning Refrigerator Repair
    Refrigerator Troubleshooting Refrigerator Compressor
    Refrigerator Compressor Start Capacitor and Start Relay
    heatman101
    Jan 16, 2011 | Frigidaire 22.5 Cu. Ft. Counter-Depth...
    Freezer not working
    Refrigerator
    heatman101
    Dec 10, 2010 | Maytag 21.6 Cu. Ft. Counter-Depth...
    Doesnot get cold both freezer and fridge
    Refrigerator Condenser Coil Cleaning Refrigerator Repair
    heatman101
    Oct 21, 2010 | Maytag 21.6 Cu. Ft. Counter-Depth...
    GE profile counter depth side by side stopped
    Is the compressor coming on at all? If not a capacitor may be bad .
    Jul 05, 2009 | GE GSH22JFR Side by Side Refrigerator
    The freezer is not cooling and refrigerator is not remaining cool
    Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
    Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
    heatman101
    sfgmjfmkxf
    Jun 25, 2009 | GE Profile 23.3 Cu. Ft. Counter-Depth...
    Whirlpool 25 Cu. Ft. Counter Depth Side-by-Side Refrigerator - GSC25C6EYY Logo
    106 people viewed this question
    Top Whirlpool Refrigerators Experts
    John Tripp
    John Tripp
    Charles T Nevin
    Charles T Nevin
    Dan Webster
    Dan Webster
    Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
