Question about Acer Aspire Z5700 PC Desktop
Acer Aspire is locked up and has a red box in lower left corner
The mouse and keyboard won't work but the monitor is fully on and asking for a password but with keyboard locked can't type it in
  • Acer Master
  • 27,725 Answers
Make sure the batteries are inserted correctly and have charge if applicable
usually located on the underside of the mouse there might be small plastic sticker with a phillips head screw under it rub your fingernail over the top to see if it has a screw or make sure the usb device is properly inserted for wireless the usb or Ps2 connection are secure with a dust free connection
or it might be the usb for wireless mouse or lead connecting to the usb port or even a faulty mouse if this does not fix the problem Restart you computer tap the f8 key repeatedly to enter safe mode where the only things working will be your keyboard and mouse allowing you an attempt to repair your computer If done properly the user should get to a screen similar to the below screen. Select the option for Safe mode command prompt only Windows Advanced Options Menu
Please select an option: Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode Start Windows Normally
Reboot
Return to OS Choices Menu Use the up and down arrow keys to move the highlight to your choice. select safe mode click start control panel administrative tools computer management device manager scroll to mice and other pointing devices you might see a yellow exclamation mark ! or question mark ? or a red x right click you will need to update the driver cCick start control panel mouse you should see 4 tabs buttons pointers pointer options and hardware under hardware you have options to troubleshoot also you can select properties under driver you will have options to update driver rollback driver or uninstall also I have found that the best way to adjust your mouse settings is to create a control panel in your bottom toolbar scroll to the bottom of your screen right click you will see an array of options select the toolbar option then select desktop then you will see the desktop in the bottom toolbar select the 2 arrows >> then all control panel items then select mouse this is in WINDOWS 7 in XP you will have to select the new toolbar option once you have that a browse option select my computer then control panel then a control panel option will be in the bottom toolbar Click start control panel keyboard hardware make sure you have the right keyboard selected or you might have uninstall the keyboard then restart your computer then reinstall it and its drivers click start control panel administrive tools computer management device manager scroll to keyboard you might see a yellow question /exclamation mark ? ! or a red X right click update driver
http://www.microsoft.com/hardware/download/download.aspx?category=MK complete range of drivers Hope this helps.
Posted on Dec 10, 2012
vcmichael
  • 115 Answers
SOURCE: My Acer Aspire T310 won't go past the Acer screen and the Keyboard and Mouse don't work
Yours may be a little old computer and the cmos battery (on the mother board)is drained out. Replace this battery. You need a working keyboard.
Posted on Dec 17, 2008
byteguy
  • 2229 Answers
SOURCE: Acer desktop mouse,keyboard not functioning, monitor also not wor
If there is no display on the monitor, then your computer is not sending a video signal to the monitor.
This could be caused by a bad video card or some other hardware problem. I would open the case and disconnect all the devices (hard drive, CD, etc. Leave only the CPU, memory, and video connected. You could leave the keyboard and mouse connected too.
If your computer then starts, you can start to add devices (after turning the computer off) one at a time.
If this doesn't work, then you are looking at replacing the motherboard or just the video card if that is possible.
Posted on Nov 05, 2009
computerdeb
  • 323 Answers
SOURCE: Wireless keyboard & mouse will not connect
Would try going into the device manager in the control panel and make sure that the usb dongle is being identified correctly by windows. Also, would unplug any other usb devices so that they are not interfering.
Posted on Jan 02, 2010
tvrookietech
  • 66 Answers
Then your problem is most likely driver-related. The chances are nill that both mouse AND keyboard are defective. Looks like it is down to one of two scenarios. Either the driver is incorrect or corrupt, or the dongle itself is malfunctioning. The driver would be first choice since it would be a free fix to rule out.
try uninstalling the driver first, then reboot. Next go to mfg website for the keyboard/mouse/dongle and download a fresh driver. Then reboot. Note that preferably, the correct protocol would be to install the driver first, before plugging in the dongle. Hope this helps. One question I can think of regarding the dongle is whether or not the dongle lights up when plugged in - some do. If yours is supposed to but does not, it could be the dongle itself. The bottom line now is between the dongle and a driver really. I'd be willing to bet the mouse and keyboard are just fine they just can't interface because the dongle is the gateway and you know the rest...good luck.
SOURCE: My acer aspire M1201 completely froze up
Perhaps you can try pulling the battery, waiting a couple of minutes and then putting it back in/retrying the boot.
jobst consulting
Posted on Feb 05, 2010
Acer aspire not working
You can try to open your computer then remove the RAM then use a pencil with eraser to clean the gold teeth and then put the RAM back and test it out.
Dec 31, 2012 | Computers & Internet
My Acer Aspire Z5600 at booting not reading the wireless keyboard and mouse, it's booting but as keyboard is not connecting, I am unable to type my password and get stuck at password screen. Have
try resetting the BIOS to defaults. Also, make sure the wireless KB and Mouse works by testing it in another PC. Acer might be aware of this issue, so try calling them if those ideas do not help.
Sep 21, 2012 | Acer Aspire Z5600 PC Desktop
Aspire as3810TZ touchpad stopped working.
Press the mouse lock button. Most times you toggle the touchpad by a button at the top in the middle of the touchpad.
Some systems will have you to tap twice in the upper left hand corner of the touchpad to toggle the touchpad.
I've also seen some systems where you would have to Press and Hold the ALT or the FN key located at the lower left portion of the keyboard then hit the key that toggles the touchpad. The key that toggles the touchpad will have the icon of a finger pointing at a square which represents the touchpad.
if all fails Click Start/Control Panel and look for mouse or touchpad. Go in and set the settings back to default.
You could try reinstalling the touchpad drivers.
Get onlineand got to www.google.com In the google search box type: "AcerSupport" (without the quotes and put your manufacturer name before Support). Look for downloads and drivers. Enter your model number and operatingsystem when requested. Download and install the Touchpad rivers.
May 03, 2012 | Acer Timeline AS3810TZ Notebook
How to restart my acer aspire laptop
Go to he start menu in the bottom left hand corner, then choose restart if it is there. If it isn't, put your mouse over the arrow to the right of shutdown and select restart when the dialogue box pops up. If that doesn't work, try posting which operating system you are using.
Mar 02, 2012 | Acer Aspire One PC Notebook
Hi my wireless keyboard & mouse do not work at all on my Acer Aspire M3970, but both a cable keyboard & mouse do?
There is a USB receiver underneath the battery panel of the mouse, although it looks like part of the workings of the mouse. It's only a very small thing with a USB plug on it but it is there. The instructions don't show a picture of it, so it's very easy to think you haven't got one until you look closely
Unclip it and put it in your USB port and it should come up.
Nov 10, 2011 | Computers & Internet
Where is the WLAN switch on the Acer EXTENSA 52325
i Found this on product manual..hope this helps.
ACER
Acer (General) - FN+F5
Aspire 1000/1640Z/1690/2012 - Launch Keys above the keyboard
Aspire 16xx (General) the satellite-like launch button above the keyboard
Aspire 2000 Series (less Aspire 2012, See Above) - Button on the Front of the Laptop
Aspire 3005 on the lower right-hand side of your laptop
Aspire 3500 -
Aspire 5612 sliding button on the side of the laptop
Aspire 9302 the blue button on the left-hand side of the laptop
Aspire 94xx (General) the key found below the Lock key
Aspire One, in the lower right corner of the palm rest is a small strip with a picture of an antenna on it. An LED to the right of the strip lights to indicate the wireless is turned on.
Aspire One Series ZG5 -
Extensa 2000/2500 Series - Far Right launch button above the keyboard
Ferrari 3000/3020/3400/4000 - Button on Front of Laptop
Travelmate C Series - Far Left hot key and then choose WLAN from menu that appears
Sep 09, 2011 | Acer Aspire 5100 Notebook
My mouse and think pad do not work
There are 2 possible answers to this common issue, the first is that the aspire has a mouse lock. check your keyboard on the function buttons for a picture of a mouse with a line though it, hit function and at the same time press the mouse with the line through it and if its locked off this will turn if back on. The second answer is driver issues, if the first suggestion dont work I would go to the Acer website click on downloads and drivers and enter your model number. Then download and install your think-pad and mouse pad drivers and install.
Sep 04, 2011 | Acer Aspire 5500 5570-2609 Laptop
Have deactivated mouse on acer5520G how do i reactivate it
Support Solutions from Acer:
Product
Notebook Acer Aspire 5520 G
Issue
Mouse / Touchpad not working
Solution
If the mouse/touchpad is not working, ensure that it is turned on. Press and hold the blue "Fn" key located in the lower left hand corner of the keyboard. and tap the "F7" key one time.
Fn-F7
A message should flash across the bottom center of the screen stating "touchpad enabled".
If this does not address the issue, the notebook may need service.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
May 17, 2009 | Acer Aspire 5520-5579 Notebook
Acer aspire one touchpad mouse does not work. USB mouse works. Also FN F5 stopped working
Aspire D250.....
Hold down function key fn (lower left on keyboard) and tap F7 key once..
May 02, 2009 | Acer Aspire One PC Notebook
My mouse pad itsnt working.. wondering if there is a lock on it!
On some laptops, there is a button that is used to disable the mousepad.  Sometimes it is a small button just above the mouse pad that has a light next to it.  Normally when it is off, the light is either red or amber colored.  There is almost sometimes a function button to toggle the mouse pad on and off.  It is normally one of the "f" keys above the numbers on the keyboard, and should have a picture on it of a mouse.  Then there is usually a FN key in the lower left corner of the keyboard.  You have to hold that down, and press the "f" key at the top of the keyboard that has a picture of a mouse on it at the same time.
Mar 30, 2009 | Acer Aspire 5610 Notebook
Acer Aspire Z5700 PC Desktop Logo
61 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
