Question about Honeywell Heating & Cooling
MY HEATER THERMOSTAT WONT GO ANY HIGHER THAN 72 DEGREES DO I NEED A NEW THERMOSTAT
  • 4 Answers
SOURCE: Edgestar 12000 heating problem
bad thermostat. the stat can be as must as 5 degrees off. try, if possible testing the unit in a differeent location
Posted on Dec 29, 2007
  • 1073 Answers
SOURCE: I am being told that
contact the manufacturer of the thermastat for setting instructions
Posted on Apr 23, 2008
rayname
  • 70 Answers
SOURCE: Goes to 60 degrees
check the back up heat coil or emergency heat available heat pumps have a defrost which need backup heat the three way valve outside will change position indoor coil will warm up to thaw ice
Posted on Jan 04, 2009
dabeckham
  • 22 Answers
SOURCE: I bought my home about 6 years ago. New built. DR
If you don't have gauges you will need to contact an AC repairman.
Posted on Jun 15, 2010
EMSRSERVICEG
  • 426 Answers
SOURCE: Thermostat only register to 72
look at wear the thermostat is then change the unit that will work
Posted on Dec 09, 2010
How to reset the thermostat to shut off after 2 degrees/CT87B-4008?
on these thermostats remove the outer ring cover and in the lower right side you will see a slide adjustment. move it i believe left for closer cycles and right for longer cycles. it should be 2* on either side of set point. remember that the fan is not furnace shut off.and turning back and forth will not tell you anything. just set it and see how it works then change it again if you need to
Oct 13, 2014 | Honeywell CT87B ROUND HEATING&COOLING...
Have a 1004fa model to heat a room. temp on
You may have a bad circuit board. Depending upon the age of the heater it may still be under warranty. Contact Rinnai (in US) 800-621-9419 with your serial number and installation date. Ask if they can offer a solution. Good Luck!
Jan 13, 2010 | Rinnai Heating & Cooling
When this thermostat is in the HOLD position, which cancels the programmed feature, I set the temperature to 72 degrees and the furnace runs until that 72 degree temperature is obtained. Now the thermostat...
If you still have the instructions for the thermostat, then it will show you how to get into the menu and set the swing on the temps. I would try to explain off the top of my head, but its actually quite a bit off numbers to remember. Hope it helps somehow.
Dec 29, 2009 | Honeywell Focus 6300B 5-2 Days...
Honeywell RTH230B a/c problem
if you set the thermostat on 70 and your house won't get ant cooler than 72, there is a problem with your system,not your stat. I'm thinking you are low on refrigerant if it is somewhat working. when the unit is running, if you can get your hand on the larger refrigerant line under the black insulation, it should be cold, about 55 degrees.
Jun 19, 2009 | Honeywell Programmable Thermostat Heater
Dec 24, 2007 | EdgeStar Portable Air Conditioner Heater
Heating & Cooling Logo
83 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
