Toshiba satellite a110-160 goes off while am working
  • 5,660 Answers
Toshiba Satellite A110-160 Notebook PC is dirty inside, then.
ALL power removed. Remove the AC adapter (Charger), and Battery.
Use a $3 to $6 ESD wrist strap, with it's alligator clip attached to a good ground source; and disassemble the laptop for cleaning.
Also suggest removing the old Thermal Paste, and/or Thermal Pad; and replace after THOROUGHLY cleaning the area.
Thermal Paste could have dried up.
You're in there for cleaning, now is the time to replace.
Besides the stuff is cheap, and it is cheap insurance.
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-A105/remove-motherboard-1.htm
http://www.radioshack.com/product/index.jsp?productId=2103245
Disassemble the laptop to clean. Use air first, then suggest use a small fine soft brush, (Make-up brush?), and Q-tips; to dislodge the heavy 'junk'. Kind of slightly stir the junk around.
Breaks the 'crust', and is easier for the compressed air to remove.
Now use the compressed air again.
The Fan Assembly draws air up from the Bottom of the laptop. Then it pushes air through the Tall, Thin fins of the Heatsink, and out the Exhaust port,
http://www.youtube.com/watch?v=AkAeE5I5E_A
In the above video stop it at 0:06, or so.
The curved copper looking objects are Cooling Tubes.
They end on the Left side, AT the finned black rectangular Heatsink.
The Fan Assembly has been removed. (The X shape sits on top of the Processor)
See the 'belt' of compressed dust on the Heatsink. Watch further as he removes it.
Blo-wing air through the Air Intake Duct, the bottom port; will just cram that stuff in deeper.
Blo-wing air in from the exhaust side will also.
SOMETIMES IT IS a temporary fix, but that is it ->
T-E-M-P-O-R-A-R-Y
DO NOT use a vacuum cleaner either!
They create Static electricity.
(All you 'techs' that use a vacuum cleaner, go ahead, and post.
We will 'wax philosophical' on using a vacuum cleaner, on a computer )
Regards,
joecoolvette
Posted on Dec 10, 2012
  • 1 more comment
  • joecoolvette
    joecoolvette Dec 10, 2012
    Dell XPS cooling assembly operates on the same principle as the Toshiba Satellite A110 series of Notebook PC
  • lang Dibba Dec 12, 2012
    Thank you all very much. i am done cus it work for me
  • joecoolvette
    joecoolvette Dec 12, 2012
    Glad you got it fixed Lang Dibba, and appreciate the rating!
Toshiba satellite L305D
That's just the way Windows works when power is cut off. You should set your Control Panel/Power settings to put the PC into hibernation if it's left alone for too long.
Oct 22, 2009 | Toshiba Satellite L305D-S5874 Laptop
Satellite M45-S169 - will not POST or power on. Power light comes ON for a few seconds then goes OFF. Power ight cycles ON/OFF six times then stops.
Hi rich caller i had this problem also with my laptop toshiba satellite M45-S169 and i find solution for this problem..
Just replaced ram memory and now my laptop works fine hope yours will work too
please respond if my msg helped you..
regards
Bess
Apr 03, 2009 | Toshiba Satellite M45-S169 Notebook
Laptop monitor goes black
If you're working on the computer when that happens, it's not probably a power setting. Try to update your BIOS to the most current version at the toshiba support website (support.toshiba.com) & see what happens. Fixes the issue most of the time
I hope this helps.
Aug 25, 2008 | Toshiba Satellite A100-S8111TD Notebook
Keyboard inoperative
press and hold fn and press f11.it sounds like you activated the sticky keys
Nov 22, 2007 | Toshiba Satellite A135 Notebook
LCD display problem
My Toshiba Satellite does a similar thing, It goes gray while I am working on it. The only way to continue to work on it is to complete shut it down manually and reboot. I took it to Toshiba they said nothing was wrong.
Oct 19, 2007 | Toshiba Satellite A105-S4004 Notebook
Toshiba satellite goes dead
Assuming this is not hibernating and your harddrive is not set to shutdown after a certain idle time, it could be this is an overheating problem. Check that the extraction vents are'nt blocked and that the fan area is well ventillated. If necassary gently hoover around all ventillation slats. Some laptops have the ability for the user to turn off the fan for certain usage, just check in your management settings that it's turned on, unless you know it is on' and it cuts in or stays on.
Jan 10, 2007 | Toshiba Satellite 4300 Notebook
Computers & Internet Logo
193 people viewed this question
David Payne
David Payne
