No disk error, how do i fix it? - Televison & Video
    Top Expert:
  • Televison & ... Master
  • 14,553 Answers
Usually this means either a dirty Optical Pick up in the unit or a BAD one.
Posted on Dec 10, 2012
Tip
Fix all your PS3 Problems
Send Your Console to Sony = $150
You need a PS3 Repair Guide = less than $35
THE NUMBER 1 GUIDE IS YLOD REPAIR WIZARD
This guide has proven permanent fixes for the following errors:
In order of the most common:
1.YLOD (Yellow light of death)
2.Green/Red/Blue Flashing errors
3.Disk Read Error/Blue ray Drive Error
4.Hard Disk Corruption
5.No Display Error
6.Red Screen Error
7.Freeze ups
8.Fix All error codes (8001050F)
9.Sync error
10.Blank Screen error
Need More Info On PS3 Repair guides and the YLOD repair wizard
on Aug 25, 2010 | Sony Playstation 3 (PS3) Console
How do I fix currupt data
I believe you mean "corrupt data". When we have message corrupt data means that something wrongs with hard disk. You can try correct problem running full disk check.
Check your hard disk for errors
You can help solve some computer problems and improve the performance of your computer by verifying that your hard disk has no errors .
Open Computer by clicking the button " Start " and then click Computer.
Right-click the hard drive you want to check, and then click Properties.
Click the Tools tab , and then , under Error-checking , click Check . Administrator permission required If you are prompted for an administrator password or confirmation , type the password or provide confirmation .
To automatically fix problems with files and folders that the scan detects , select Automatically fix file system errors . Otherwise , the disk check will report problems but not solve .
To run a full disk check , select Scan for and attempt recovery of bad sectors . This scan attempts to find and repair physical errors on the same hard disk and may need more time to complete .
To check for errors in both files and for physical errors , select both check boxes AutoCorrect file system errors and Scan for and attempt recovery of bad sectors .
Click the Start button .
Depending on the size of your hard disk , this process may take several minutes . For best results, do not use your computer for other tasks while it lasts error checking .
note
If you select the Automatically fix file system errors for a disk that currently in use (for example , the partition that contains Windows), you will be prompted to reschedule the disk check for the next time you restart your computer your .
Jan 29, 2014 | Toshiba Computers & Internet
Hard disk cyclic redundancy check
A cyclic redundancy check error on a hard disk means that part of a file read from the hard disk doesn't match the expected value.
A cyclic redundancy check error, in other words, means that files on your hard drive are corrupted.
Repair a cyclic redundancy check error on a hard disk using the Check Disk tool in Windows.
Click "Start" and click "Computer."
Right-click the hard disk with the cyclic redundancy check error under "Hard Disk Drives" and click "Properties."
Click the "Tools" tab at the top of the hard disk "Properties" window.
Click "Check Now" under "Error Checking."
Select "Automatically Fix File System Errors" and "Scan for and Attempt Recovery of Bad Sectors" in the "Check Disk" window by clicking each option if it isn't already selected.
Start a disk check and repair by clicking "Start" in the "Check Disk" window.
Click "Yes" if the "Do you want to schedule the disk check to occur the next time you restart the computer?" prompt appears.
A disk can't be checked if it's in use, so you'll need to restart Windows to check it.
Restart your computer by clicking "Start," clicking the arrow icon to the right of "Shut Down" and clicking "Restart."
Fix a Cycle Redundancy Check Error
The "Cyclic Redundancy Check" error is a Windows error message telling you there's a problem reading data you're trying to access.
The root of this problem could either be a damaged storage device or a corrupt file.
Windows has built-in tools to attempt to fix to this problem, and avoid further errors.
Click on the "Start" menu in the bottom left-hand corner and click "Run."
Type in "cmd" and press "Enter" on your keyboard.
This will open a black command prompt box.
Type in "chkdsk /f" and press "Enter."
If you receive a message saying the disk will be checked the next time the system starts, press "Y" and then "Enter."
Restart your computer by closing the command prompt box and selecting "Shut Down" from the Start menu.
Wait for the disk scan to reach 100 per cent.
This may take awhile.
When it completes, your drive errors may be fixed.
Avoid future problems with this type of error by replacing the file that caused the problem.
For example, if you got the error when using a text document, open the document and copy all the text (press "Ctrl" and "A" at the same time and then "Ctrl" and "C" at the same time).
Create a new text document and paste the text in by pressing "Ctrl" and "V" simultaneously. Save the new file, and delete the old document.
Hope this heps
Nov 02, 2012 | Ultra 0471 Seagate St3500418as 500gb Sata...
The file or directory is corrupted and unreadable
The file or folder could get corrupted due to improper turning off the PC like abrupt power cut
without an UPS backup and various other reasons.Unfortunately there is no guaranteed way to fix the
corrupted file/folder,but there are few things you could try that fixes the issue sometimes.
1) You can ask windows to check for errors and fix them.This may fixe the corrupted files or folders in some cases.Follow the steps below to run the error checking process.
  1. Double-click My Computer, and then right-click the hard disk that you want to check.
  2. Click Properties, and then click Tools.
  3. Under Error-checking, click Check Now. A dialog box that shows the Check disk options is displayed,
  4. Use one of the following procedures:
    • To run Chkdsk in read-only mode, click Start.
    • To repair errors without scanning the volume for bad sectors, select the Automatically fix file system errors check box, and then click Start.
    • To repair errors, locate bad sectors, and recover readable information, select the Scan for and attempt recovery of bad sectors check box, and then click Start.
    Note If one or more of the files on the hard disk are open, you will receive the following message: The disk check could not be performed because the disk check utility needs exclusive access to some Windows files on the disk. These files can be accessed by restarting Windows. Do you want to schedule the disk check to occur the next time you restart the computer? Click Yes to schedule the disk check, and then restart your computer to start the disk check.
Like I said there is no guarantee this would fix the issue but its worth the try.The only way to keep the folders or files safe is to make backup copies on another hard drive or CD/DVD.Do let me know if it helped.
Thanks for using Fixya!
Dec 11, 2010 | Seagate (ST980811AS) 80 GB IDE Hard Drive
The system detected a disk volume error which is indicated avery time I boot the notebook. And the system indicates that it can not open some files to do the automatic repair. In additon indicates that...
HI, here are the easy steps in doing the check disk on your computer to fix the error:
  1. Click on the pearl
  2. Click on Computer
  3. Right-Click on Local disk c:
  4. click on the tools tab
  5. click on the button for check disk
  6. it will ask you an option to fix disk error during the scan
  7. the it will ask you to reboot the computer after clicking on start
  8. when you restart your computer check disk will run before going to the desktop
  9. it should detect for any errors and fix it for you.
Cheers!!
Sep 01, 2010 | Computers & Internet
Instructions For Fixing Hard Disk Errors:
Reply to :- Instructions For Fixing Hard Disk ErrorsThe same problem is my window 7 is showing on my hard disk Disk Name: WDC WD2500BEVT-75ZCT2 ATA...
I can still access to my data but my laptop hangs a lot..
my laptop is Dell Inspiron 1525.
Is my hard Disk got failed?
I am very much worried...please someone help me.
Aug 11, 2009 | Samsung SpinPoint P80 SP0802N 80 GB Hard...
Maxtor 160gb External Hard disk stoped working
You're probablly SOL but-
You can help solve some computer problems and improve the performance of your computer by making sure that your hard disk has no errors.
  1. Click on start, then computer (or my computer)
  2. Right-click the hard disk drive that you want to check, and then click Properties.
  3. Click the Tools tab, and then, under Error-checking, click Check Now. getcontent.aspx?assetid=18abb370-ac1e-4b6b-b663-e028a75bf05b&documentset=en-us&renderkey=signed1 If you are prompted for an administrator password or confirmation, type the password or provide confirmation.
    To automatically repair problems with files and folders that the scan detects, select Automatically fix file system errors. Otherwise, the disk check will simply report problems but not fix them.
    To perform a thorough disk check, select Scan for and attempt recovery of bad sectors. This scan attempts to find and repair physical errors on the hard disk itself, and it can take much longer to complete.
    To check for both file errors and physical errors, select both Automatically fix file system errors and Scan for and attempt recovery of bad sectors.
  4. Click Start.
Depending upon the size of your hard disk, this may take several minutes. For best results, don't use your computer for any other tasks while it's checking for errors.
Note
  • If you select Automatically fix file system errors for a disk that is in use (for example, the partition that contains Windows), you'll be prompted to reschedule the disk check for the next time you restart your computer.
Mar 11, 2009 | Maxtor Hard Drive
My ps2 has an error reading disk with gta san andreas
Hi!
Please see this video on how to solve the disk read error on your ps2---
Also see this link on how to troubleshoot these type of errors--
PS2 Disk read error troubleshooting
Please rate this solution as FixYa if found useful.
Thanks
Rylee
Feb 26, 2009 | Rockstar Games Grand Theft Auto: San...
Disk Error
You can not fix this problem because the player does not read dvd recordable disks
Sorry!
Dec 18, 2008 | Toshiba SD-2700 DVD Player
Televison & Video Logo
16 people viewed this question
Top Televison & Video Experts
