I still cannot print
Printer (HP Laserjet 1015) itself is ok I did a test page message is "Print spooler service os not running: It will not allow me to re-install printer I need to print documents so urgently
  • 2,878 Answers
Reboot the computer if the printer is local. Or, type services.msc in run / search. Scroll down to Print Spooler and start by right clicking. You have a bigger problem if this fails to start. Like you may not be an Administrator.
Starting the Print Spooler on a networked printer (at work) is the same, only it must be done by an IT admin on the Print Server.
Posted on Dec 10, 2012
kikoksky
  • 119 Answers
SOURCE: unable to print using samsung print on Windows XP
To resolve this issue, follow these steps: 1. If you do not have a Lexmark printer installed, go to step 4. If you do have a Lexmark printer installed, go to step 2.
2. If the Lexmark print service is installed on your computer, turn off the LexBce Server service. To do this, follow these steps: a. Click Start, right-click My Computer, and then click Manage.
b. Expand Services and Applications, and then click Services.
c. In the details pane, right-click LexBce Server, and then click Properties.
d. On the General tab, in the Startup type list, click Disabled.
e. Under Service status, click Stop, and then click OK.
f. Right-click the Print Spooler service, and then click Start (if it is stopped).
g. Exit Computer Management.
3. Test whether the issue is resolved. If the issue is resolved, you do not have to follow the remaining steps. If the issue is not resolved, go to step 4, and then follow the remaining steps.
4. Start the computer in safe mode. To do this, follow these steps:a. Restart your computer and start pressing the F8 key on your keyboard. On a computer that is configured to start multiple operating systems, you can press the F8 key when the Boot menu appears.
b. Select an option when the Windows Advanced Options menu appears, and then press ENTER.
c. When the Boot menu appears again, and the words "Safe Mode" appear in blue at the bottom, select the installation that you want to start, and then press ENTER.
Note For more information about how to start your computer in safe mode, click Start, click Help and Support, type safe mode in the Search box, press the ENTER key, and then click the Start Windows in safe mode topic.
5. Start Microsoft Windows Explorer, and then delete all the files and the folders in the following two folders (where C: is the drive where you have Windows XP installed): • C:\Windows\System32\Spool\Printers
• C:\Windows\System32\Spool\Drivers\w32x86
6. Start Registry Editor. To do this, click Start, click Run, type regedit in the Open box, and then click OK.
7. Locate and expand the following registry key:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Print\Environments\Windows NT x86
View the list of subkeys. There should only be the following subkeys: • Drivers
• Print Processors
8. If there are any subkeys other than the subkeys that are listed in step 7, follow these steps: a. On the File menu, click Export.
b. In the File Name box, type the name that you want to use for this key, such as WindowsNTx86regkey, and then click Save.
You can use this backup of the HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Print\Environments\Windows NT x86 registry key to restore the key if you experience any issues after you complete this procedure.
c. Delete all the subkeys other than the subkeys that are listed in step 6. To do this, right-click each subkey that is not on the list, and then click Delete. Click Yes when you are prompted to confirm the deletion.
9. Locate and then expand the following registry key:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Print\Environments\Windows NT x86\Drivers
The registry entries for the printer drivers that are installed on the computer are stored in the Version-x subkey or subkeys, where x is a number (typically 2 or 3).
10. Export the Version-x subkey or subkeys. To do this, follow these steps:a. On the File menu, click Export.
b. In the File Name box, type the name that you want to use for this key, such as print driver, and then click Save.
11. Expand the Version-x subkey or subkeys, and then delete the printer driver entries. To do this, right-click each printer driver subkey, and then click Delete. Click Yes when you are prompted to confirm the deletion.
12. Locate and then expand the following registry key:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Print\Monitors
View the list of subkeys. There should only be the following subkeys for the default print monitors: • BJ Language Monitor
• Local Port
• PJL Language Monitor
• Standard TCP/IP Port
• USB Monitor
13. If there are any subkeys other than the subkeys that are listed in step 12, follow these steps: a. On the File menu, click Export.
b. In the File Name box, type the name that you want to use for this key, such as MonitorsRegkey, and then click Save.
You can use this backup of the HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Print\Monitors registry key to restore the key if you experience any issues after you complete this procedure.
c. Delete all the subkeys other than the subkeys that are listed in step 10. To do this, right-click each subkey that is not on the list, and then click Delete. Click Yes when you are prompted to confirm the deletion.
14. If you have a printer attached, disconnect the printer cable from the computer, and then restart the computer.
15. Verify that the Print Spooler service is running. To do this, follow these steps: a. Click Start, right-click My Computer, and then click Manage.
c. In the details pane, right-click the Print Spooler service, and then click Start (if it is stopped).
d. Exit Computer Management.
Note If you cannot start the Print Spooler service, follow the steps in the following Microsoft Knowledge Base article to start the Print Spooler service:
919750 (http://support.microsoft.com/kb/919750/) You experience problems printing, viewing printer icons, and adding printers, the Print Spooler service does not function correctly, and you receive print-related error messages on a Windows XP-based computer
16. If you have a printer attached, reconnect the printer cable to the computer, add the printer that you want, and then try to print a test page. To add your printer, follow these steps: a. Click Start, and then click Printers and Faxes.
b. Click Add a printer.
The Add Printer Wizard starts.
c. Follow the instructions in the Add Printer Wizard to install the printer that you want
Posted on Jun 24, 2008
  • 116 Answers
SOURCE: Printer driver installation
just click the link below and enter the approtiate model number of ur printer and download drivers.
www.lostmydrivers.com
Posted on Oct 06, 2008
PABLOCSA
  • 1124 Answers
SOURCE: Print Spooler service not running
Go to Start, Control Panels, Administrative Tools, Services.
Windows 2000: Go to Start, Settings, Control Panel, Administrative Tools, Services.
Right click on the print spooler and select Properties.
Click on Dependencies to view a list of all the system components that the print spooler depends on.
Under Services, go to each of these dependencies and check the properties. In each case, ensure that the Startup type is set to Automatic, and that the Service status is set to Started.
Posted on Nov 19, 2008
PABLOCSA
  • 1124 Answers
SOURCE: print spooler error during printer installation windows vista
Posted on Nov 23, 2008
PegBox60965
  • 51 Answers
SOURCE: print spooler service not running on Windows XP
Spooler depends on the RPC service being running. But you really need to get into event viewer and check for anything related to either RPC or Print Spooler. If you're trying to print to a network printer you could have firewall issues either within Windows or your router. Think about what changed on your system around the time this problem began.
Posted on Jan 01, 2009
Hello, i have a problem. i can't print any documents from HP PSC 1410. i have already tried to print at Notepad and it says " operation could not be completed. the print spooler service is not...
Remove USB cable, restart the system after uninstalled the drivers in the system, connect the printer if its if its new hard ware found run the rivers,finish it up, sytem not recognizing the printer replace formatter assm, then try..
Sep 10, 2011 | HP PSC 1410v All-in-One Printer
I have an HP 1020 printer. I cannot undertake any operation as the words " printer spooler not running " continues to appear on the screen. I tried to delete the printer and reinstall , without...
Print spooler not running is not the printer error, it happens when the print spooler service starts working in windows, For making it enable you dont have to reinstall the drivers for the printer, as print spooler service is for every printer, even if you put another printer the result will be the same
To Enable Print Spooler Open Control Panel
Go to administrative Tools>Services (For Windows XP Users)
Control Panel\System and Security\Administrative Tools( for windows 7 users)
Open Services Find Print Spooler in the list
Right click the service and make it stop, if its already stop set it to Start and then again give prints
Double click on the service and set "Startup type to AUTOMATIC". You should now be able to get prints from your printer
Now restart your desktop/laptop and check if the service is still working by giving any test print.
Hope it will solve your issue
If you require more assistance, regarding this topic feel free to reply
Regards, BA
Jan 14, 2011 | HP LaserJet 1020 Printer
Print spooler error
reinstal the driver with print spooler running, good luck
Apr 06, 2010 | HP LaserJet 1020 Printer
Getting error message 1018 with the print spool for my HP 1018 printer. HP support will not correct the problem since the print spool is a Microsoft problem.
please check the below........
1. goto start....>run...>type sevices.msc...>enter....>goto print spooler...>double click over there....>select automaticaly....>click start....>ok
Restart the Print Spooler service. To do this, follow these steps:
o Click Start, click Run, type net stop spooler in the Open box, and then click OK.
o Click Start, click Run, type net start spooler in the Open box, and then click OK.
if its not working please post your full error massage u are getting .or you can send your details to me at anantakumarjena0@gmail.com
Oct 26, 2009 | HP LaserJet 1018 Printer
The printing spooler service is not running.
Go to the control panel. Select printers and right click on your printer. Select properties and turn print spooling on.
Aug 08, 2009 | HP Hewlett Packard LaserJet 1022 Printer
HP Laserjet 2200dn print spooler unable to connect
Have you tried a different driver eg. rpcs or another version of pcl?Have you checked your workstations services app to check if your print spooler is running?Also when you print a config page from the hp it will give you your network details.To eliminate your network grap a crossover cable and connect directly to the printer and test.Let me know.
May 22, 2009 | HP LaserJet 2200dn Printer
HP print spooler problem and error 1068. Want my printer back!!!
Just go to your Server or Desktop PC and enable the RPC service (Remote Procedure Call)
Right click in "My computer" icon, from the manu select "Manage" then go to "Services and Applications" and expand that, after that select "Services" you will find that services in the right pane, just click in "Start"
May 08, 2009 | Sony Office Equipment & Supplies
Hp laser jet 1150 have stopped printing
Check the spooler is running:
"Control panel"
"administrative tools"
"Services"
Double click "print spooler"
Check that startup type is "automatic"
Check the "service status" to see if the spooler is "started". If not select "start" (if it's already started try stopping then restarting the service"
Try to Print.
Hope this helps. Please let me know if it does, and if not, please provide the EXACT message you receive when you try to print.
Apr 28, 2009 | HP LaserJet 1150 Printer
Will not receive print message from computer, will print test pag
Hi there, try to stop and restart the print spooler (control panel/Administrative Tools/Services, scroll down until you find Print Spooler, then double click on it. Stop button and then start), and try to print again. If that didn't solve the problem, it must be a printer drivers problem. Try to roll back the old drivers under printer properties.
Good luck
Mar 30, 2009 | HP LaserJet 1300n Printer
Computers & Internet Logo
41 people viewed this question
David Payne
David Payne
