Have a DeLonghi Calor Gas fire. When I fire it up the pilot light doesn't go out. Any ideas?
  • 2871 Answers
SOURCE: hi i boght a calor gas heater in dec 09 i only use
Hi clean out pilot jet or replace thermocouple
Posted on Feb 01, 2010
Testimonial: "thanks for the advice i'll try that solution"
  • 2871 Answers
SOURCE: calor gas heater pilot going out
clean pilot and burner , if no help change thermocouple
Posted on Sep 29, 2010
  • 26 Answers
SOURCE: My Delonghi Quattro Plus Calor gas heater will not
the gas valve needs replacing
Posted on Dec 09, 2010
kebah
  • 683 Answers
SOURCE: Hi, my old Vulcan wall
Check if there is contact between the terminals of the thermostat using an ohm meter when set to a higher temp, if the reading is infinite or open, you have to replace the thermostat. Also check if the thermopile is receiving enough heat from pilot flame for it will generate a little amount of electricity to energize the main valve and fire up the burner.
Posted on May 11, 2011
SOURCE: pilot light on the gas boiler won't stay lit it's
The pilot flame must touch (burn) the tip oqef the t-couple to hold the magnet in the gas value open.make sure the pilot orifice (hole) is clear.the pilot pressure (in the tube) is factory set full open & can only be adjusted down (less). Also check the gas **** didn't get closed or turned half way.? Assuming its not the t-couple. If all is good & it still won't stay on. Replace the gas value.!
Posted on Sep 21, 2011
Kampa Calor. Why isn't it lighting?
sounds like the line from the gas bottle is air locked .keep trying to light whle holding the button down longer
Feb 11, 2016 | Heating & Cooling
How do i turn down the pilot light on a calor gas heater?
The pilot nozzle is replaceable but pilot light is not adjustable.
A big pilot light can be caused by a high gas pressure.
Mar 21, 2015 | Heating & Cooling
Portable calor gas heater ignition flame goes out when releasing no gas to heater
Clean out pilot could be too short to heat up thermocouple, try blowing it clean with a small tube
Dec 27, 2012 | Heating & Cooling
Delonghi Superser won't light there is gas getting
Clean pilot first see if it lights if not you could change thermocouple
Apr 03, 2012 | DeLonghi Heating & Cooling
How do I change the pilot light as it is not working anymore.
It won't be the pilot light, It will be the gas valve control, if the pilot light actually lights but the burners won't light,, then you need to check the thermocouple , its that little round thing that sits inside the flame of the pilot light, and has (usually) a copper tube that runs back to the actual gas valve, If its gone bad, the signal to the gas valve is lost so the gas never gets released so nothing lights
Jul 07, 2011 | DeLonghi DEFSGG36-SS Gas Kitchen Range
My pool heater doesn't come on. The pilot is lit, and the valve to the ON position. I turn the front knub to heat but when I turn the switch on the front panel to ON it doesn't fire on (...
If your pilot light is lit, then you do have some gas flow, so it is probably the thermocoupler (the part heated by the pilot light) that is not telling the gas valve to open the main line. Sometimes it is just a case of residue on the thermocoupler that is not letting it get up to temperature and sometimes it has been knocked out of alignment and the pilot light is not putting direct heat on it.
A cleaning with steel wool (don't overdo it) would take care of the residue, and you can GENTLY move the thermocoupler back over the pilot flame. If neither of that helps then replace the thermocoupler.
Jul 01, 2011 | Hayward 250 1 Millivolt Propane Pool...
Heating & Cooling Logo
69 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
