Question about Whirlpool WTW6400SW Top Load Washer
Washer out of balance in the spin mode - Whirlpool WTW6400SW Top Load Washer
    Top Expert:
  • Whirlpool Master
  • 9,472 Answers
You will need to open the cabinet and check the suspension springs.
Posted on Dec 10, 2012
Washer stuck in drain and spin mode
Hello. I need the model number to help you accurately. When the unit drains, can you verify water *is* actually being pumped out? This is important because no washer will spin if it can't pump all the water out--modern electronic washers have to balance the load and water is an unknown, shifting quantity. I need the model number to assist you in initiating the diagnostic mode and explaining the possible error code(s) you might be getting. I hope I helped you!
Sep 15, 2015 | Kenmore Washing Machines
Tub is off balance
The tub is out of balance. When it starts hitting the sides, stop the washer and move your clothes around inside the tub to balance the tub. Now start it to spin again. This should stop the tub from hitting the sides.
Feb 14, 2012 | GE Washing Machines
After having frozen pipes, and thawing out we have noticed that the spin mode is a lot loader than it used to be
If it's not an out of balance problem (the tub), then there could be something wrong with the clutch or the transmission pulley. Make sure you don't overload your washer. Open the lid while it is in spin cycle and see if the clothes are balanced out.
http://www.appliancepartspros.com/
Feb 09, 2011 | Kenmore Elite Oasis 27052 Top Load Washer
Frigidaire washer ftf2140es3 will not spin in any mode
I am having the same problem! I cleaned out the coin trap, shifted the loads for balance, still will not go into a full spin!!!! Does anyone have a solution??
Oct 28, 2010 | Frigidaire ATF6000ES Front Load Washer
Spins out of balance even emty
http://www.askmehelpdesk.com/plumbing/whirlpool-out-balance-spin-cycle-18991.html
http://fixitnow.com/sbrvrs/washers.htm
http://www.repairclinic.com/Washing-Machine-Troubleshooting
This model of washer does not have an out of balance cut off switch. If the load is not balanced properly the tub could hit the cabinet sides. If the unit spins evenly while empty & out of balance while loaded, I recommend checking & balancing the load. If the basket spins out of balance while empty, I recommend having the suspension springs & balance ring checked. Be sure not to wash light fabric with heavy fabric clothes. Also ensure that the adjustable feet are level, that's most important.
Aug 01, 2010 | Kenmore 24032\24036 Top Load Washer
Water in the washer
That water is in the balance ring and is perfectly normal. It balances the basket in the high spin mode.
Mar 15, 2010 | Maytag Neptune MAH5500B Front Load Washer
My washer creates a thumping when it goes into spin mode and sometimes it won't spin at all can it be a belt slipping?
Could be belt uneven load/ suspension legs or loose counterweight...Lump of concrete....on top..not spinning could be out of balance load.....hope this is some help
Sep 29, 2009 | Kenmore Elite 45986 Front Load Washer
Out of balance condition
I had a Fridadaire model and had the same problem. It could be 3 things. 1- the weight came loose that balances the drum. 2- the bracket that is attached to the drum could have cracked. 3. the bearings to the drum have worn out. All of these problems involve taking the washer completely apart. This is big process, but if you have time and patience it worth it.
Is this model belt driven?
Jun 01, 2009 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
check the drain pump in the bottom of the unit and verify its not clogged, verify unit is level, also check the support struts/springs for the tub.
May 26, 2009 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Drum out of balance after repair on 20722 kenmore washer
THESE WASHERS SIT ON A SKATE PLATE PICK UP ON THE TUB A TURN IT A BIT AND TRY IT ONCE IT IS BACK ON THE SKATE PLATE WILL OPERATE PROPERLY
Apr 27, 2009 | Kenmore 24032\24036 Top Load Washer
Whirlpool WTW6400SW Top Load Washer Logo
21 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
