Question about Zanussi ZX99 / 5 Bottom Freezer Refrigerator
Removing air grid on zanussi fridge freezer znb 323w
  • 236 Answers
SOURCE: Zanussi fridge freezer
sounds like the freezer evaporator has iced /frosted up and you will not get cold airflow through it. try a 24 hour defrost to clear it. then check fridge cooling.
Posted on Jun 04, 2007
eagle338
  • 4889 Answers
SOURCE: Zanussi fridge freezer - fridge not working
The defrost cycle is not happening like it should, that's what causes the block of ice (and poor air flow). If you have all that defrosted look at the defrost bi-metal, it usually is a small round disk with a couple wires coming out of it and it's clipped on the coils. When it's cold enough, it passes electricity to the heat elements, when it gets hot enough it "opens" and kills power to the heat elements. If that is bad (swollen cracked or bloated) and not passing electricity to the elements that's the problem. Another item would be the defrost timer itself, if it doesn't work (no clock motor turning) then it will never go into defrost. And the last and usually least expected failure would be the heat element themselves not working
Posted on Oct 09, 2007
SOURCE: fridge doesn't work but freezer does
i have had the same problem, it was the fan which needed to be replaced.
Posted on Oct 07, 2008
woodchuck789
  • 4059 Answers
SOURCE: zanussi fridge compartment has stopped cooling but freezer is ok
How to check everything
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp .
OR.
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
Posted on Aug 24, 2009
  • 4793 Answers
SOURCE: i have a zanussi fridge freezer model no zx56/4w.
you need to totally defrost the fridge/freezer and start as if it were new and dry.allow 24 hours for the unit to settle to the correct temp.
please leave feed back
Posted on Sep 16, 2010
How do I change the door from one side to the other on my Zanussi ZNB 38 NDX?
The door comes off a set of hinges. You may have to remove the front fascia at the top, and access the screws holding the top hinge on to the frame. Unscrew these and remove the door by lifting off the bottom hinge. With the door off you will be able to remove the screws holding the bottom hinge. If you are lucky, they will reverse fit to the other side as they are. If not, use what was the top hinge as the new bottom hinge, fit the door and use the bottom hinge as the new top hinge.
Jun 09, 2012 | Zanussi Refrigerators
Zanussi fridge compartment has stopped cooling but freezer is ok
OR.
Aug 24, 2009 | Zanussi ZI918 / 12K Bottom Freezer...
How do I replace the blower fan motor in the freezer section of my Zanussi ZNB 343 W Fridge-Freezer?
unplug unit
use screw drivers, 1/4 & 5/16 nut drivers , to remove panel and any trim required, usually not required. remove braket with either nutdriver, replace and reassemble , simple.
Aug 23, 2009 | Refrigerators
Fan is rattling on zanussi fridge freezer how can i get at it or ny suggestions as to what the problem is
might be ice on the fan.....when its completely frozen your fridge part will stop working.
Feb 28, 2009 | Zanussi ZX99 / 5 Bottom Freezer...
Zanussi refrigerator/freezer model ZX99/5
I had the same problem...it was a defrost problem in the freezer....mad i know...fridge doesnt work but freezer does...so its the freezer problem right!!!
This is how i solved it....there is fan behind the freezer compartment....you need to remove all the freezer draws then the plate at the back of the freezer compartment(everything is accessible from inside the freezer only) once removed you can put your hand up inside the gap(make sure power is off and unplugged) just in reach is the fan which you should be able to rotate with your fingers...mine was covered in ice and not able to move as a result the cold air couldnt be blown up into the fridge(the only thing controlling the air into the fridge is a flap and depending upon what fridge setting you have this determines how much cold air its letting in.)
If the fan has been frosted up you need to defrost the freezer....and source a new defrost sensor.
hope it helps.
Feb 24, 2009 | Zanussi ZX99 / 5 Bottom Freezer...
Fridge doesn't work but freezer does
Aug 30, 2008 | Zanussi ZEBF277W Bottom Freezer...
The freezer is working but the the fridge
same here. have the znb 4051s refridgerator. freezer works fine but fridge does not. there is no sound eminating from the fridge either...any ideas? its 1 year old!
Apr 13, 2008 | Zanussi ZEBF277W Bottom Freezer...
I have a zanussu fridge
Re. Zanussi ZK87/46EFS Fridge Freezer
The same symptom occurred in our fridge freezer. The fridge compartment warmed up whilst the freezer compartment continued to keep temperature.
The cause of our problem was diagnosed as a frozen sensor that controls a flap, that controls the flow of cold air from the freezer compartment up into the fridge compartment. We were advised to power off the fridge freezer (removing all food and trays from the freezer unit first), and to leave it to defrost for 24hrs. We needed to place a few towels on the floor of the freezer compartment to soak up the melt water. After 24hrs we followed the power up instructions in the manual (versions are available online if you have lost yours). Within a few minutes it was obvious that the fridge compartment was being cooled – Problem solved :)
Apr 13, 2008 | Zanussi Refrigerators
Zanussi ZNB 3450S Fridge Freezer not cold enough
it is going into defrost,not enough frozen items in freezer to hold temperature down. if you bought it july last year.it should still be under waranty
Feb 27, 2008 | Refrigerators
Jun 03, 2007 | Zanussi ZEBF250W Bottom Freezer...
Zanussi ZX99 / 5 Bottom Freezer Refrigerator Logo
91 people viewed this question
Top Zanussi Refrigerators Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Jason Harris
Jason Harris
Are you a Zanussi Refrigerator Expert? Answer questions, earn points and help others
