Question about Akai LCT3201TD 32 in. LCD Television
Remote code to turn akai TV/DVD combo on/off
I am trying to program a dish network remote to turn the tv on and off. Can you help me with the code for the remote.
Thank you in advance
  • hojha Jan 13, 2009
    I tried your suggestion, it did not help. Thank you for the help.
  • 362 Answers
Hi hojha, Here is the instructions from Dish Network. Please follow the steps below to program your remote control to equipment other then your DISH receiver:
Note: If you start this procedure and at any time and do not press a button within 20 seconds, the remote will end the procedure automatically. Simply start over again. Use the TV button for your TV, the VCR button for your VCR or DVD player. These Mode buttons are located at the top of your remote control.
1. With the desired equipment on, press and hold the correct Mode button until all mode button backlights illuminate, then release.
2. Press the numbers 5-0-0 on the remote control.
3. Press the Pound (#) button on the remote.
4. Press and hold the correct Mode button until all mode button backlights illuminate, then release.
5. Press and release the Power button on the remote control.
6. Press the Up button once a second while pointing the remote at the desired equipment. If the code for the equipment comes up, the equipment will power off.
7. Press the Pound (#) button. If the code entered is valid for the remote, the mode light flashes three times.
8. To verify the code works try several different functions for that equipment.
Let me know if this helps and please rate this solution. lone99star
Posted on Jan 13, 2009
Need tv codes for a memorex mltd3222 tv/dvd combo for my direct tv remote
The Dish remote like others only has about 50 possible codes in it--these combo units use odd codes so that remote may just not be able to be programmed for this unit---the remote should have a search mode that allows you to try one at a time every possible code it contains.
May 16, 2012 | Televison & Video
I have an akai 21' tv. I cannot program my dish network remote to work with the tv. None of their codes work. Do you have codes I might try
Hi my name is Mike Houston of DISH Network and I see youwant to program you're Akai TV to our DISH Network remote. There are some easysteps to allow setup to your TV and I will send the link, http://www.dishnetwork.com/SupportSection/remote-setup.Please select the receiver you have and it will take you to a help page. I willsend a link for a Power Scan and the power scan will find the remote code foryou; http://www.dishnetwork.com/SupportSection/power-scan-instructions.If you have any questions or concerns please e-mail me at michael.houston@dishnetwork.com.
Jul 29, 2011 | Akai LCT3285TA 32 in. LCD Television
Dont have the remote and need to set channel to sync with dish network
Try programming the remote to your tv this link will show you codes and instructions.
Hope this helps!!!
http://www.dishnetwork.com/downloads/pdf/user_guides_and_manuals/Remote_Codes_Web_Page.pdf
Daniel Busa
DISH Network Customer Service
Dec 25, 2010 | Sylvania SRCD227 27 in. TV/DVD Combo
TV IS AN ORION TV/VCR COMBO. THE BEDROOM TV IS IN RUNS OFF THE LIVING ROOM RECEIVER. THE TV CHANNEL IS SUPPOSED TO BE ON 60. NO REMOTE 4 TV, TO CHANGE CHANNEL TO 60. TRYING TO PROGRAM DISH REMOTE. 1 CODE 4...
zassyway
I have provided instructions on how to program the remote to your TV. I have also provided codes for your TV brand.
Remotes: Basic (Television Only)
  1. Turn the Television On
  2. Press and Hold the TV Power button for three seconds until the LED flashes
  3. Enter the three-digit code using the buttons on the number pad.
  4. Press OK. Note: The LED will flash three times.
  5. Test functionality with the TV
  6. Return to Step 2 if the remote is not able to turn the TV On/Off, change the volume and mute the television.
The codes are as follow: 720, 220, 748, 721 (694 only has a 2% success rate). I hope this helps.
Ray Calo
DISH Network
Jun 18, 2010 | DISH Network IR Remote Control
Need remote code for gpx tv/dvd combo
I have a code of 749 for it,if not ,try this,press and hold TV button until all the lights come on,press and release the POWER button,press the up button once a second while pointing the remote at the TV,when the remote has found the correct code,the TV will turn on or off,press the pound # button, if it is correct, it will blink three times. ..hope this helps..
Mar 29, 2010 | RCA RCU403 Remote Control
Cant program dish network remote to my sylvania tv/dvd combo
Not likely will your current remote ever have the capability for your newer model. The code sets are designed into the Dish remote as they were available then and don't 'learn' newer sets.
You might try to find one of the other Funai brand code sets under these names:
Funai, Symphonic, Emerson, Aventura, Durabrand, ESA, Magnavox, INSIGNIA, and Misakai
Even if you do find one that gives you some functions, I doubt you will find one set for both TV and DVD player so you will have to try individual code sets; one for TV, another for DVD.
Jul 12, 2009 | Toshiba MW27F51 27 in. TV/VCR/DVD Combo
Dish Network remote code for RCA 20F510TD TV/DVD
hello and please help.
want to know the codes and way to program this rca dish remote model RCR500SAM1 for my Toshiba tv.
ive done it a few years ago but forgot.
so i need the codes for toshiba tv and way to program this rca dish network remote.
grateful,
kay
Jul 26, 2008 | RCA 20F510TD 20 in. TV/DVD Combo
Code for trutech
dish network remotes dont work with very many tv/vcr or tv/dvd combo units
Jul 11, 2008 | DISH Network IR Remote Control
Lost remote for akai tv/vcr/dvd set
I think you should look over the Internet to buy one from places like Ebay for your brand of TV.
Apr 07, 2008 | Akai CFTD2083 20 in. TV/VCR/DVD Combo
Dish network
With the dish remote and do a code search as described in the remote manual and see if you can find it that way. If you go through the entire code search and none of them turn off the VCR/DVD combo, then there is nothing you can do, as those codes in the remote are all stored in the remote and they cannot be programed in. If you do not have a remote manual to set up the remote, to do a code search, simply go to the dishnetwork web site and search for it.
Sep 27, 2006 | Emerson EWD2004
Akai LCT3201TD 32 in. LCD Television Logo
429 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
