Question about Canon i350 InkJet Printer
Paper Feed The paper jams on one side of my printer.  It continues to print but the paper gets stuck before it can feed through to be printed on. It seems to be a problem on the right hand side facing the printer. What should I do? It doesn't seem like a jam and this just started after I have not used it for a couple of months. I did install this printer onto a new computer but I wouldnt think that would have anything to do with it right?
I had what sounds like the same problem. I had been using my printer earlier and then it started pulling the paper to one side (same side as yours). After trying the basic stuff ...I turned the printer upside down ...and out fell an almond. How it got in there I don't know..(I think my neighbours' little girl was eating them and must have dropped it in when she was visiting. ) I'm not sure if there was more to the problem than this ..and that seems almost too simple, but after the almond was out the printer started working just like before. I don't know if your problem might be similar but I hope maybe this can help.
Posted on Jan 28, 2009
Paper feeder stuck
If the paper feeder stuck, do the following:
  1. Gently pull any jammed paper out from the output tray or sheet feeder.
  2. If paper is stuck inside, open the printer cover and remove the jammed paper, including any torn pieces. Then close the printer cover.
  3. If paper remains near the sheet feeder, press the paper feed roller lever inside the paper feeder to release the jammed paper, then carefully pull it out.
  4. Load the paper correctly.
  5. Press the cp_button_14.gif stop button to resume printing.
  • If the printer continues to jam or misfeed paper, and you are certain that there are no foreign objects lodged down inside the paper feed area, your printer may require service. Please call Epson technical support for further assistance.
  • Jan 29, 2011 | Epson Office Equipment & Supplies
    OKI C9600 paper jam problems: Paper jams continually, either on first attempt to printing or if it prints a page the 2nd page inevitably jams. Printer has only done 1500 pages since new ,and i have removed...
    Wow! That's quite the printer you have there. The C9600 does have a feed roller in the front; and it's not uncommon for paper to still get stuck. Does your paper "fan" when it goes through; or simply, go through and jam? It's possible a paper feed sensor is bad too. Another thing you might want to check is the paper tray; and that the paper is set to the proper size.
    Also be aware, the OKI 9600 had a recall a year or so ago for some potential "shock issues" I would advise you to check with OKI directly to determine if this printer is part of that issue too.
    Jan 04, 2011 | Office Equipment & Supplies
    Paper feed problem
    Hi
    This is happening due to paper jam on the gear or roller of the paper feed mechanism. Check for any small bits of paper or sheet stuck. To check lift up the top plastic lid of the Canon printer. Check to see if a jammed sheet of paper is visible inside the printer. Remove the cartridges and check for any small paper bits stuck under the print head. Pull the paper out gently through the bottom end of the printer(if any). Close the top plastic lid. Power On the printer and check.
    If it doesn't work then power off the printer, wait 10 seconds and power it back on. try once again to print. If it doesn't work then Open the Canon printer software. Click "Options" and then select the "Clean Print Heads" button.
    Daniel Scott
    Jun 14, 2010 | Canon PIXMA MP210 Photo All-In-One Printer
    Lexmark z2300 printer won't pull in paper
    1. Turn the printer off and open the access cover.
    2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
    3. Turn the printer on, load some paper, and press the Form Feed button. (On the X83, press the Select button.)
    4. Watch the paper as it feeds through and try to determine where the jam is occurring.
    5. Check to see if all the rollers are turning.
    If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
    If not, there is probably a feed motor or a gear problem and the printer may require service.
    6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
    7. Turn the printer off.
    8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
    9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
    Jan 03, 2009 | Lexmark Color JetPrinter Z23 InkJet
    My Printer won't print
    If the problem repeats then there is the problem with rollers you may need get it replaced if its within warranty or get it serviced .......
    Good luck...
    Nov 25, 2008 | Lexmark X5495 Printer
    Canon MP470 - Paper starts to feed and twists then jams
    i had the same problem, mine went into the printer fine and started to tilt. all i did was check the paper input slot and there was a necklace stuck in it, it was an easy fix after all, just had to pull it out. too bad there are more problems than it is worth tho, right now mine wont feed lol
    Nov 11, 2008 | Canon imageCLASS D880 All-In-One Laser...
    Paper jams consistely and then continues to feed, even if only printing one page
    check your paper size setting on your print menu. i had this problem when i set the paper size smaller than the printer is able to handle (3x5 card) ... i just switched to 4x6 and don't have any problems.
    Oct 24, 2008 | OKI C5100n Laser Printer
    I replaced ink and paper..paper keeps jamming when printing and copying. after the replaced inl and paper, i was able to print with no problem however without warning iunable to print or copy without...
    Oct 20, 2008 | Lexmark Office Equipment & Supplies
    Printer malfunction
    The samsung printer have three paper jam sensors. First (paper jam 0) after the feed rollers. Second (paper jam 1) at the left of the feed rollers and third (paper jam 2) at the fuser unit where it is hot. You can see the actuator between the two white rollers. Paper jam 2 is mainly cause by the scrappers out of position on the side of the upper heat rollers.You will have to clean it and put it back into position.
    Dec 19, 2007 | Samsung ML-2150 Laser Printer
    Paper will not feed into printer
    Oct 17, 2007 | Lexmark X83 All-In-One InkJet Printer
    Canon i350 InkJet Printer Logo
    150 people viewed this question
    old marine
    old marine
