Question about Sansui Televison & Video
Sansui power cord falls out
The cord doesn't push into the back of the tv all the way and falls out if tv is moved.
  • 1,238 Answers
Just replace your power cord.
Posted on Dec 10, 2012
3 Suggested Answers
caroldon
  • 17130 Answers
SOURCE: LG 55lh40 tv will not turn on. I REPLACED THE
Only a probe with a voltage trace can figure to the possible SHORT in the circuit board. You need to look for possible signs of heating which can be an indicator to a short . Also check for the secondary +B to the circuit, check the path that leads to the drive and see if there is high potential drop, if so check the drop to get an idea of the short. The list of probabilities can be more and so ONLY a good voltage check can pinpoint the case. Take consensus but do not replace board at high cost with just assumptions.
Posted on Oct 24, 2011
gopakumarg43
  • 75571 Answers
SOURCE: vizio tv volume up & down doesn't work
Check and replace its main system memory IC.
Posted on Oct 06, 2012
No picture no power kids pushed it off the dresser
Ouch. If you are lucky unplug double check cord connection at back. No help? Wire at plug end may have torn in the fall. Wiggle wire at the plug end if you get something the cord needs to be replaced. Otherwise, you may have major damage. A lightly used replacement may be less than a repair.
Mar 06, 2015 | Sansui HDLCD1908 19 in. LCD TV
I have a Phillips 46WB2K3RA tv and the power cord got cut accidentally while moving it. I spliced it and put it back together and now can't get the tv to come on, any suggestions as this is the only...
On the cors itself one side has either a white line or is ribbed. Just match up the correct lines and splice it back together. If you have them reversed, polarity is backwards and TV won't operate. If that doesn't solve your problem it's more than likely the fuse inside the TV where the cord enters the back.
Sep 04, 2011 | Philips Televison & Video
Sansui tv doesn't read USB video
The USB port on HDLCD4212 is only for servicing the tv. It will not read video.
Jun 13, 2011 | Sansui HDLCD-4212 LCD TV
I only get 3 channels--and none of them I want! Does this TV only work with a cable attached? Which doesn't make it portable!
If you live in the US and the TV doesn't have the newer ATSC (digital) tuner, you're lucky to get 3 channels! The only analog broadcasts left in the US are "low power" & "translator" stations. The old NTSC analog tuners in TV's from just a few years back have little to tune since broadcasters have been moved and changed from analog to digital as directed by the FCC in 2009.
I hope this helps & good luck. Please rate my reply. Thank you.
Jun 01, 2011 | Axion Televison & Video
I relocated to another state and I have a Sansui HDLCD1908 tv, I have this extra power cord I'm assuming it connects to the tv, all the other cords to all the other electronics are accounted for and...
It will connect in the back of the TV. You will see a female socket under the lip of the RCA connections and RF connectors. This power cord is just like the computer power cord you already use! Thanks for asking and show a few hands of support!
Mar 04, 2011 | Sansui HDLCD1908 19 in. LCD TV
I moved and lost my power cord to Model HDLCD 3212A how can I get a replacement A/C power cord.?
You have lost the detachable power cord!
Just take a photo of the power socket on the TV side where the cord gets fixed.
Show the photo taken, to any computer or electrical shop. They will help you. These are all standardized fitments and mostly compatible.
Or contact SANSUI service center.
Sep 27, 2010 | Sansui 32" TV
TV broken
check power cord,making sure nothing is cracked or broken.if this problem happend after you had your incident there should be a simple remedy.
Jun 09, 2008 | Televison & Video
Televison & Video Logo
Top Sansui Televison & Video Experts
matt martin
matt martin
Are you a Sansui Televison and Video Expert? Answer questions, earn points and help others
