Question about De Dietrich Dishwashers
De dietrich dishwasher dvf300 not cleaning properly
3 Suggested Answers
BIKER T
  • 909 Answers
SOURCE: Dishwasher not cleaning properly, and not stopping
Your fault is not the normal complaint. Question is, "are you sure it doesn't just keep on running during the heating cycle"?. My thoughts are the heating element is possibly not functioning which will disrupt the continuing of the cycle.. Check element for a resistance reading,(approx. 23ohms). Check for a thermal cut out (sometimes a little reset button found on an item with wires attached). Press until click is heard.Retry. If all this heating does happen, then there is definitely an issue with the timer being it electronic or mechanical. Please let me know if not the solution. Thanks.
Posted on Sep 26, 2009
Daniel S
  • 4323 Answers
SOURCE: De Dietrich DVF121J Dishwasher needs
Hi
If the dishwasher won't start cycle and the control seems to be working fine then this is because of either of these two things.....when the dishwasher fills however, won't start then the first thing that should be checked is the motor...if the motor is bad it should be replaced. If the unit won't fill and won't start cycle then the door latch mechanism should be checked and if bad replaced. If you get this repaired by a professional then the cost to repair it will be around $200. Hope this helps...please post back for further assistance.
Daniel
Posted on Jan 26, 2011
Where is the flood switch on die dietrich dishwasher dvh640ju1
these are normally in the bottom of the dish washer
micro switch controlled by a float
Feb 15, 2014 | De Dietrich DVH610JU1 24 in. Built-in...
I have a De Dietrich dishwasher (VZ9996U1)with a broken plastic loop which holds the side door spring. Can I get a new plastic loop? This loop is also attached to a length of cord. Alison
Same thing happened to mine - I simply took some nylon cord, about the thickness of a shoe lace and made a slip knot loop around the remaining cord. (the plastic bit was still attached and the knot pulled up against this). this has been working fine ever since.
Dec 30, 2009 | De Dietrich Dishwashers
Why does my De Dietrich oven trip the RCD fuse?
You need to replace the oven element, as this is what is causing the prob.
Please rate my solution.
Thanks.
Nov 06, 2009 | De Dietrich DOC310 Electric Single Oven
It does not rinse properly, leaving a film on
Pump worn out, using too much soap and depending on where you live there may be a more concentrated amount of minerals in the water. Florida residents are having that problem in spades due to our drought.
Oct 10, 2009 | De Dietrich 18 in. VZ9456 Built-In...
Washer starts program but sound much noisier than
Suggest you check the water pressure out the pipe, then clean the inner sieve which is usually in the valve inlet. if all is clean and still little water enters, i would replace valve.Also, chech the pressure switch line an make sure it is not partially filled with water.
Sep 21, 2009 | De Dietrich 24 in. DVF120J Built-in...
Leak from a De Dietrich Integrated Dishwasher has caused 3 red lights on the left of the Control Panel to flash and also a Blue Light on the right hand side of the Control Panel to flash. On resetting...
Pull the built in unit out and tilt towards the rear right leg and the water will drain on to the floor. The Dishwasher then restarts but the anti flood sensor will reactivate after 2-3 more washes. Do not know final fix yet.
Oct 05, 2008 | De Dietrich Dishwashers
Built in De Dietrich dishwasher
I suggest you get all your staff to search tirelessly for an answer, ChrissyJ!
Oct 02, 2007 | De Dietrich 24 in. DVF120J Built-in...
Dishwashers Logo
Top De Dietrich Dishwashers Experts
richie46
Are you a De Dietrich Dishwasher Expert? Answer questions, earn points and help others
