Question about Air Tools & Compressors
Spraytech sw 419
I was trying to clean all the inlet parts,because it wasn't drawing paint ,i put it back together and all i got was a hum,took the fuse out,put it back in now i get no power!
SOURCE: putting back together the trimmer
I Need to kno a answer to this as well
Posted on Apr 25, 2008
SOURCE: pump hums then blows circuit
Start capacitor is probably bad
Posted on May 26, 2009
  • 202 Answers
SOURCE: putting the dremel back together
here is a link to a 215 should be similar in design.
http://www.ereplacementparts.com/dremel-215-f013027506-corded-multitool-parts-c-15440_15456_15457.html
Posted on Jul 09, 2009
SOURCE: How to put back together a smith & wesson air soft rifle
ooof i know how to put i back together and can teach you but its a doozi over the net. hows your experiance with airsoft internals also wat type of gun is it (spring gas aeg etc shotgun assault rifle pistol etc. email me @ levis_lalancette@yahoo.ca i can help you further with that info
Posted on Aug 04, 2009
SOURCE: can't get my bassinet to stay up
1. hook/snap the loose arms into the bottom of the bassinet 2. slip hooked end through a small **** in the fabric on top side where the round metal tubing. 3. feel with fingers for the small hole in the tubing on the inside and fit the hook into there
... stupid design... took me hours to figure it out
Posted on Mar 15, 2010
Why did I have a sudden loss of power?
HI, let me see if I can't help you with this problem-
You are say no power as in it won't turn on and It's new, right?
Lets troubleshoot a few things right now and see if there is a simple problem that may be causing "no power"-
1-turn the power control knob all the way while you pull the trigger
2-don't use an extension cord and try a different wall outlet
3- do you a GFI wall plug (ground fault interrupter) that needs to be reset
4- look at the power cord and check if you have any obvious damage to the cord that might be causing the problem ok
Thanks,
Perry Tradesman @ Tradesman Painting & Decorating Lic.778435
Feb 25, 2015 | Wagner SprayTech Paint Sprayer. Flexio 590...
Will not suck the paint just air is coming out
Hello I just saw this in my inbox, let me see if I can help you-
NOTE: Whenever you are going to spray with any HVLP or cup-gun
strain paint through either a strainer bag or an Automotive strainer cone to remove any kind of debris from the paint that can clog the delivery tube that sucks the paint up from the "cup" and into the fluid needle.
yes even though "Wagner" says the Flexio will spray un-thinned Latex-
However by thinning your paint 10% to 15% you will get better coverage and the paint will move through the gun better
If you have no paint coming out try adjusting the fluid material knob on top-
Also try holding a piece of card in front of the the Tip and try all your Adjustments and you should start seeing the paint spraying onto the piece of cardboard or wall.
Thanks,
Feb 15, 2015 | Wagner SprayTech Paint Sprayer. Flexio 590...
Unit won't prime,
YOU HAVE A STUCK INLET BALL
Have the unit in water, pressure relief valve turn the machine on and tap with a hammer at the inlet ball, This frees it up 90 of the time.
Otherwise the machine need to be disassemble
Jan 29, 2014 | Wagner SprayTech Wagner Airless Paint...
Will not prime
Most of the time when a unit will not prime it is because of a stuck inlet ball, I would put the intake in water turn the machine on to bleed. Then tap the machine where the paint comes in. 90% of the time this will get it going. Sometime you can stick a screw driver into the inlet ball and free it up. If this doe not work you need to take the machine apart and cleanor you have worn out packing.
Joe
Jan 23, 2014 | Wagner SprayTech Wagner Airless Paint...
Getting lots of air pressure but no paint comes out
You have old paint that is plugging the pick-up line. you need to clean your sprayer very well each time you use it. I hope this helps you out some.
Jan 12, 2014 | Wagner SprayTech Wagner W665 Wall Perfect...
My sprayer has power and blows air but no paint comes out
you have old paint that is pluging the pick-up line. you need to clean your sprayer very well each time you use it. I hope this helps you out some.
Aug 14, 2013 | Wagner SprayTech Paint Sprayer. Flexio 590...
My spraytech 1620 wont stay primed,and it's not the ball..what do i need to do or buy for it ????
It was probably from Home Depot,was it a refurbished unit as Home Depot will just do a basic flush and lube the fittings/seals..try getting a repack kit from them.
Oct 19, 2012 | 1620
What is hot water and what is cold water hook up on back of washer?
The hot water inlet is normally in some way marked red, either with a red plastic 'washer' or by red paint. The cold one is either white or left blank ;-0)
Now a bit of value adding!
You will probably find that each inlet 'port' has a fine filter inside it . If you start suffering from water inlet problems like 'slow fill' turn the water supplies off, remove both hoses from the washer then clean these fine filters before replacing everything.
I hope this clarifies the situation for you and if it has please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Aug 13, 2011 | Maytag Neptune MAH5500B Front Load Washer
Have a Wagner Paint Crew and it started out fine and then after a half hour or so, it gradually lost pressure to a small stream, I was using new paint and I cleaned the hose, screean, intake valve, and...
hello ald... use a fine piece of wire and clean the opening that the paint comes out through. It has a tendency to fill in as you spray. Joe
Jun 28, 2011 | Wagner Plumbing
I have a titan 400 i paint sprayer, won't prime.. any suggestions ? Thanks, can't get anything through it... motor is running and all. Shawn
sometimes the ballbearing in the shaft where you dip into the paint gets stuck .if you unscrew the end of the shaft and clean the ballbearing.then put back together and try prime again.
Apr 23, 2009 | Titan Air Tools & Compressors
Air Tools & Compressors Logo
398 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
