Question about Whirlpool Duet GHW9150P Front Load Washer
Door Latch has broken plastic tab
I need to reset the door latch back into the door lock assembly or just buy the $50 replacement lock assembly. Or can anyone suggest any other solutions? I am having trouble resetting the spring-loaded latch back into the lock assembly. I am not sure where it should be rotated (positioned) to before the pin is slid back in. Apparently the plastic side tab that is broken off of the white plastic latch is why it rotated out of place to begin with. Does anyone have a picture or a diagram of what it should look like reinstalled correctly? Where should the wire spring be touching? If the side tab is essential, can I purchase just the white plastic latch piece from anyone instead of the whole $50 assembly?
  • Anonymous Mar 23, 2014
    Door hinge is broken
  • 5,911 Answers
The door latch assembly comes as one piece. It would actually be much simpler to purchase the new latch and replace the whole assembly instead of trying to put pieces and parts back inside a latch that may or may not work after all your hard effort. If you decide to replace the latch, follow these steps: 1. Unplug the machine. 2. Remove the lower kick plate panel if you like (this can help you reach the latch from a couple of different angles). 3. Open door and feel around the rubber door boot for a wire hoop. At the bottom of the door open is a tension spring. Pull the spring apart and remove the wire hoop from the groove. 4. Gently lift the rubber boot from the groove around the door opening and push inside the machine so you can access the inside of the casing. 5. The door latch assembly is located inside the case on the right-hand side. There should be a couple of wire connectors going to it (remember how they come off). Be careful with the wires, they are small and can break. 6. Unplug the wire connectors and remove the three screws holding the latch in place from the outside of the casing. 7. There should also be a plastic retainer holding the latch in place. Remove latch from retainer. 8. Install new door latch by placing it in the plastic retainer, first. 9. Plug wires connectors in. 10. Re-install the three door latch screws. 11. Re-install rubber door boot around the door opening. Make sure it is properly seated in the groove. 12. Reinsert wire hoop. starting at the top of the door opening, carefully push the wire hoop into the groove and work your way all the way around the bottom where the tension spring would be. (A second set of hands to hold the wire hoop in replace would be handy at this point). 13. Pull tension spring apart and snap into groove. Done. Hopefully this will take care of your problems. Of course, you may not like the idea of having to purchase a whole new door latch assembly, or the effort required to remove and replace. But, it sure beats trying to rebuild the old one. I hope this helps.
Posted on Jun 11, 2007
These whirlpool piles of **** are just that **** but great for the repair parts business. I guess the old washer that lasts for a year is now gone replaced by cheap ****, heck the whirlpool Duet Sport is giving **** a bad name.....Don't buy whirlshit anymore they **** asss
Posted on Feb 19, 2009
Mazda 1996 lx prestige passenger door lock dose not work ether with key button our buy pushING down on
Need to take inside door panel off and look at inside door latch. The locking rod probably broke at door latch. Or it lucky unhooked. To find whice rod it is. You may need to cut hole in platinum sheet near door latch. Then move one left to right. One will lock it and one will open door. Then check to make sure both ends are connected on the lock rod. Almost sure it is the small plastic piece broken of door latch. And when taking inner door panel off. Make sure all screws are out. And use flat screw driver next to plastic tabs to pop them out. If careful everything will go back together easy.
Jul 11, 2016 | Mazda Cars & Trucks
How do i refit the main oven door lock, i need a step by step guide or something?
Oven Door Latch (part #9761013) - How To Replace ...
? 4:32
https://www.youtube.com/watch?v=rbMZ8NgiKm8
Oct 31, 2012 - Uploaded by AppliancePartsPros
Buy the new Oven Door Latch 9761013 ... How to replace yourcooker hinges. - Duration: 8:50. how-2-repair.com 84,238 views. 8:50.
How To ReInstall Your Oven Door - YouTube
? 2:12
https://www.youtube.com/watch?v=EBhJk85mc1Q
Dec 28, 2010 - Uploaded by HavillFiles
Did you remove your oven door and now you can't get it back on? The manufacturers forget to tell you about locking the latches first! ... Oven Door Hinge (part #W10347466)-How To Replace - Duration: 9:25. ... Hygena / Whirlpool / Electrolux / Phillips ovencooker door removal (others with same hinge) ...
How To Replace an Oven Door Lock Assembly ' Repair ...
www.searspartsdirect.com/repair.../how-to-replace-an-oven-door-lock-as...
Main Menu; Recently Viewed ... This step-by-step range repair guide shows how toreplace the oven door lock motor assembly for a self-cleaning oven. The door lockmotor assembly locks the latch to keep the oven door shut during the ...
Jan 08, 2016 | Ovens
Door will not lock .what do I need to replace .?
If the door won't latch, the door latch assembly might be defective. These are normally made of plastic and cannot be repaired. If the door won't latch and the door latch is broken, replace it.
It can also be a defective main control board, but this is not common.
Feb 20, 2015 | LG Washing Machines
How do I get the Whirlpool washer door to close all the way? I think the door lock is jammed
The lock/latch on your door is electromechanical, incorporating a electrical safety catch. See if a reboot (unplug for 10 minutes, then plug it back in.) does anything for you. It could be a latch, wiring, motherboard, door closed safety circuit or something in the pause circuit.
Jul 21, 2014 | Whirlpool Duet GHW9150P Front Load Washer
My Bosch Dishwasher door sticks shut at the end of the cycle. I can open and close it with ease during the cycle, but once it finishes I have to pull really hard to open it.
see all this steps and fix it. God bless you
Door or Lid Latch Assembly
If the door won't latch, the latch assembly might be defective. Inspect the latch assembly to see if it is cracked or worn out. The latch assembly is normally replaced all as one part.
Enter your model number to see parts for your dishwasher.
Help me find my model number
Door Hinge
If the door won't latch, one or more of the door hinges might be bent or broken. If the door hinges are not working properly the door won't close squarely and then the door won't latch.
Door Catch
If the door won't latch, the door catch might be out of alignment or broken. If it appears to be OK, reposition it as needed. If appears broken it should be replaced.
Door Lock
If the door won't latch, the door lock assembly might be defective. These are normally made of plastic and cannot be repaired. If the door won't latch and the door lock is broken, replace it.
Door Latch
Door Strike
If the door won't latch, the door strike might be defective. These are normally made of plastic or metal and cannot be repaired. If the door won't latch and the door strike is broken, replace it.
Apr 05, 2013 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Door wont shut
Door Hinge
Door Catch
Door Lock
Door Latch
Door Strike
Apr 05, 2013 | Miele Dishwashers
The locker (latch) on my microwave broke. We just got the replacement part in the mail. Sears says we should be able to replace it ourselves. I see no screws to get inside the door. Does the plastic flange...
If there are no screws to hold the inside door cover in place then they are probably using snap or lock in tabs around the edges to hold it
in place. You will have to disassemble the door to replace the door latch. ----------
Its a latch spring assembly.-------- Click this link below and follow the door lock latch replacing procedure:---- http://technoanswers.blogspot.com/2011/07/how-to-replace-door-lock-latch-on.html ------------------- This will help.Thanks.Helpmech.
Jul 14, 2011 | Microwave Ovens
My door lock has locked with the door open , how do i get it to unlock ?
There is a manual unlocking tab located at the bottom of the door lock and switch assembly. Disconnect power to the washer before accessing it.
Remove the three screws attaching the toe panel to the cabinet then pull the panel down and off the cabinet. Prop up the bottom front edge of the washer or cushion and lean it against the wall for an easy access of the screws.
Reach up along the inside of the front panel and locate the bottom of the door lock and switch assembly on the right side.
Locate the tear-drop shaped tab then gently pull it down until a click is heard, and then open the door.
The door lock and switch assembly may need to be replaced if the problem persists. Disconnect power to the washer and open the door. Remove the door gasket retaining hoop by stretching apart the retaining spring at the bottom of the door opening.
Gently peel the part of the door gasket near the door lock/latch assembly off the lip of the right side of the door opening. Remove enough of the door gasket to access the door lock/latch assembly behind the front panel.
Remove the three screws securing the door lock/latch assembly to the front panel and slightly lift it then pull it back off the front panel.
Pull the door lock/latch assembly out of the washer and disconnect the wiring harness.
Connect the wiring harness to the new door lock/latch assembly and install it back in place behind the front panel.
Secure the door lock/latch assembly and put the eased part of the door gasket back into position over the lip of the door opening.
Check that the door gasket is properly seated before putting back and securing the retaining hoop around the lip of the door opening and the door gasket.
Jul 03, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Back door latch broke cant open back door where can i buy the part and the name of the part
I just bought the part last week for 61.76 from the dealership. It takes about two hours to unscrew the strap from the inside, remove trim from the inside starting at the top, sides and bottom. Remove the license plate from the outside of the hatch. Next remove the 8 bolts (10mm)and 3 white plastic tabs that snap on from the large black plate and move to the side (you don't need to disconnect the wires). From here you can reach around the rear window unit and open the door by moving the latch or pulling the cable. You should remove the 4 nuts that hold on the rear window assembly and move the to reach two nuts which holds the center portion of the trim piece you are trying to remove. There should be a plastic piece covering the cable and latch, it just pops off by pulling it straight out. There are three plastic tabs in the corners and one screw (lock for the hatch) that holds on the license plate assembly to the rear hatch along with two white plastic tabs which are located at the bottom two holes for license plate. These plastic tabs come in from the front. Use pliers to squeeze the together and push. You will need to disconnect the license plate lamp wire connector from the left side. The license plate assembly should drop away. Two screws hold on the latch, remove and replace and reverse proceedure.
Jul 08, 2009 | 2002 Toyota Sequoia
Getting a small plastic piece out of a door
If the piece is jammed (locked) in the door latch assembly, there is a manual release that you can use to open the door latch to see if the piece will come from free. The following link advises:
http://www.fixya.com/support/r622155-kenmore_elite_whirlpool_duet_door_jammed
This may require two people. One to pull on the manual release, while the other works on retrieving the broken piece from the door latch.
Another method may be to remove the door latch assembly so you can easily manipulate it outside the machine. This link explains how to remove the door latch assembly:
http://www.fixya.com/support/r587965-door_latch_replacement_fdl_error
Now...if the piece is jammed too far inside the door latch assembly, a last resort would be to replace the latch. I hope it does not come to that, but it may be a last resort. The link provided will give you all the necessary steps to complete this repair, if required.
I hope you find this information helpful. Let me know if you require additional assistance.
Nov 08, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
798 people viewed this question
Sal De
Marvin
Marvin
Archie Ferrarini
Archie Ferrarini
