Question about Gaskets for Mitsubishi 3000GT
How will i check a damage gasket - Gaskets for Mitsubishi 3000GT
  • 32,281 Answers
A cylinder compression test may show up a leaking head gasket or bubbles in the radiator water.
Posted on Dec 10, 2012
Is there any way to visually check to see if the intake manifold gasket and head gasket on the 2000 Chevy venture or messed up
Spray carb cleaner or starting fluid around suspected area with engine running to see if the rpm increases.
Aug 02, 2016 | Cars & Trucks
Water in the oil
Radiator coolant in the engine oil is normally an indication of a failed cylinder head gasket or a crack in the cylinder head or both.
Running the engine in an overheated condition will cause head gasket failure and often a crack in the cylinder head.
The problem you have is coolant is escaping into the engine's lubrication passages via the failed head gasket or head crack and contaminating the engine oil. If not fixed you will cause further damage to the engine as oil contaminated with radiator coolant cannot adequately lubricate the engine.
Running a leak down test on each cylinder will confirm the leak. In this case you are going to need to have the cylinder head removed and thoroughly checked for cracks and any warpage as well as a new cylinder head gasket fitted. The condition the engine block surface will also need to be checked.
Jun 14, 2016 | Cars & Trucks
Car is dumping oil at front making a sqealing noise like its an oil pump
first check fluid levels --power steering--oil--transmission --if power steering low or out pump will sequel look for blown hose or seal----if oil is low or empty than look under around oil filter [hole damaged or blown gasket ] spraying on belt causing sequel if not filter than trace oil leak possible oil pan damaged or gasket crack or head or valve gasket-----if trans low or empty look at pan- gasket ,or damaged check trans cooling lines to radiator-----these are your leak areas under hood your oil pump is internal in oil pan and you usually dont hear it
May 16, 2014 | 1997 Oldsmobile Cutlass Supreme
My cadillac catera has oil licking from the bottom of the oil pan
HI. This will normally be the result of a failed oil pan gasket. With that said, I will list other areas of concern below. Have theses areas checked for faults asap.
1. Loose or improperly secured oil outlet screw.
2. Failed oil plug screw ring gasket.
3. Failed head gasket
4. Damaged or overly secured oil filter device.
5. Damaged or deteriorating oil pan gasket.
6. Damaged or breached oil pan.
Oct 26, 2011 | 1998 Cadillac Catera
I have a 2003 Honda 919. I was low on anti-freeze and rode the bike pretty hard. The next morning there was white smoke coming out of the exhaust. it will start after driving the bike for a min. What is...
That would be my guess. Could also be a warped head. White smoke usually means that you are getting water (coolant) into the combustion chamber, so steam (water vapor) is coming out the exhaust.
I would pull the head, examine the gasket for signs of damage, have the head checked for cracks and flatness (no warp). If the head is damaged, repair or replace it. If there is no visible damage to the head or gasket, check the block carefully. If no damage, then put a new gasket in it and put it all back together.
Sep 20, 2010 | Honda CB 900 Hornet Motorcycles
ANTIFREEZE DISAPPEARING - NO VISIBLE LEAKS
HI. This issue has many causes. i will list the most common causes below.
Coolant consumption::: Possible causes______
1. Check the head gaskets. The gasket may be leaking.
2. Check The Intake Manifold Gasket. This gasket may be leaking, worn, or damaged
3. Check the cylinder head for worn or scorn cylinder block.(This will require total breakdown of the engine)
4. Check the water pump seal for leaks as well.
Now that we have covered the basic check points for coolant consumption, i would advise to concentrate on the head gaskets if there are no apparent leaks on or around the engine itself. If the head gaskets are worn, the leak can be introduced to the engine internally, causing the engine to burn off the coolant. this is noticeable by removing the oil cap, after a hard drive. you Will notice steam that will escape the head as soon as you remove the cap. If this is the case, your problem will be with a failed head gasket.
IN a severe case, you will notice white plums of smoke escaping from the tail pipe during acceleration.
Jan 04, 2010 | 1989 GMC Sierra
What does dE flashing on the LG intellowasher WD1050FHB mean?
It is an indication of door error. The door is either not shutting, locking or opening.
  1. Turn off the unit and unplug it for 5 minutes then replug and turn it on. If the problem persists, proceed below.
  2. Check the door latch
  3. Check if there is something that is caught in the door and prevent it to shut properly.Remove any stuck items that might push the door latch up or down during operation.
  4. Check if the door or gasket is damaged. Damaged door or gasket will prevent the door from latching or locking properly. Replace damaged gasket. Dis-aligned door prevents the door latch to lock properly.
  5. Check the door latch for any damage. Replace if defective.
Nov 04, 2009 | LG Washing Machines
Every 30 days or 1000 miles my coolant disappears I don't see a leak under the car.
There are four problem spots that you should check the address this issue. replace one or all the below components that fail the inspection.
CHECK LIST--
1. Check the Head Gasket(s). Check for leaking or damaged head gaskets. if you are seeing any white smoke coming from the tail pipe, this will be a sign for coolant leaks inside the engine.
2. Check the intake manifold gasket(s). Check the gasket for damage and worn corners as well.
3. Check the water pump. Make sure that the water pump is functioning properly and, make sure there are no leaks around the housing.
4. Check the Engine Cylinder Block for ware or scorn cylinder block.
5. flush the radiator to check for sludge build up as well. replace the radiator if metal fragments are noticed during the flushing procedure.
Jun 10, 2009 | 2002 Chrysler Sebring
Check eng light
1 Inspect Oil Pan Gasket - Performance Ruptured, cracked or leaking radiator hose. grey_line.gif 2 Inspect Hose (Bypass) Ruptured, cracked or leaking bypass hose. grey_line.gif 3 Inspect Hose (Heater) Ruptured, cracked or leaking heater hose. grey_line.gif 4 Inspect Radiator Cap Worn or damaged radiator cap grey_line.gif 5 Inspect Heater Core Heater core may be leaking antifreeze/coolant into the vehicle`s floor area. grey_line.gif 6 Inspect Heater Control Valve Leaking or defective heater control valve. grey_line.gif 7 Inspect Radiator Drain Plug Loose, damaged, or faulty radiator drain plug. grey_line.gif 8 Inspect Radiator Rusted, corroded, or damaged radiator may be leaking antifreeze/coolant grey_line.gif 9 Inspect Water Pump Damaged, worn or leaking water pump. grey_line.gif 10 Inspect Cooling System Mix Coolant level low or flow is restricted. grey_line.gif 11 Inspect Head Gasket - Performance Blown head gasket grey_line.gif 12 Inspect Hood Brace Leaking, worn, or damaged intake manifold gasket grey_line.gif 13 Inspect Freeze Plug Freeze plugs are cracked or leaking.
Dec 02, 2008 | 2003 Jaguar Vanden Plas
Gaskets for Mitsubishi 3000GT Logo
35 people viewed this question
Top Mitsubishi Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Navin Sharma
Navin Sharma
Are you a Mitsubishi Vehicle Part and Accessory Expert? Answer questions, earn points and help others
