Question about Whirlpool 24 in. GU3200XTP Built-in Dishwasher
Whirlpool Gold flashing 'NORMAL' light, will not reset or work
The 'NORMAL' mode light continues to flash but the dishwasher will not work. No other modes light up. I've tried the reset procedures and it will not reset, nor will it display any error codes. I've checked the wires to the solenoid and motor. They are secure.There is water in the bottom as if it quit working in the middle of operation. Has anyone encountered this particular problem?
  • Anonymous Apr 07, 2009
    Exact same problem...Some times if I shut off the breaker, and wait a little while, I can run it again for another load. In the mean time, I don't think it will get better, I gave in and called the repair man.
  • 38 Answers
Could be either the keypad is faulty or the control board is bad.
Posted on Feb 23, 2009
How do I reset a flashing green start button
Blinking start button usually means a bad door switch cannot reset the control does not see the door as closed
Aug 14, 2014 | Whirlpool Gold 24 in. Built-In Dishwasher...
We washed the dishes and now the clean light is flashing. When we hit cancel it runs for 2 minutes and continues flashing, why?
Hello & Welcome to FixYa
Flashing clean light is reset by pressing two buttons in sequence 3-4 times, to reset your kenmore press these buttons in sequence:
High temp wash-heated dry-high temp wash-heated dry
Please get back to me if you have any other questions.
Kevin
Mar 08, 2011 | Whirlpool Gold 24 in. Built-In Dishwasher...
My dishwashers normal light keeps flashing and wont do anything
Your dishwasher will do this as a safety in case the element is broken and feeding electrical current into the water. Sometimes just a false reading.
Reset your console by pressing: high temp wash, heated dry, high temp wash, heated dry
When all the lights are on you are set in diagnostic mode. Just hit cancel a you will be able to run your dishwasher as normal.
If this same light appears again then you have a bad element or thermostat.
Dec 07, 2010 | Whirlpool Gold 24 in. Built-In Dishwasher...
Control clean light keeps blinking and dishwasher will not function
Dec 06, 2010 | Whirlpool Gold 24 in. Built-In Dishwasher...
Whirlpool Gold Quiet Partner Model # GU980SCGQ2 The dishwasher normal light flashes on and off continually. The dishwasher won't stop cycling now, everything seems to work normally other than it won't...
Dlc737, We apologize for your concerns with your Dishwasher. If you have tried to reset from the breaker and it has not fixed the problem then we would recommend scheduling service. We would be happy to assist you further. Can you please email us your address, phone number, the model and serial number, the website you were contacted on, Fixya, your review ID, and date of purchase to Whirlpool_Digital@whirlpool.com?We would be happy to assist you further.
Jun 09, 2017 | Whirlpool 24 in. GU980SCG Built-in...
Whirlpool gold dishwasher will not work the clean light flashing 7 times what does that mean?
When the dishwasher doesn't sense a water temperature increase, it stops working and locks the functions (clean light flashes 7 times, all buttons are non responsive). It does this as a safety in case the element is broken and feeding electrical current into the water.
To resolve this you will have to reset the console. Do this by closing the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
...all the lights will turn on briefly and the machine will start a diagnostic cycle. You can press cancel or let the diagnostic cyle finish (1-2 minutes).
You should now be able to run the dishwasher as normal.
If the issue returns, you could have a problem with the heating circuit (ie. element, thermostat or wiring).
It rarely happens but it could also be the door switch not engaging properly when the door is closed (slightly bend the door latch down making sure it doesn't hit the door when you close it).
Apr 03, 2009 | Whirlpool Gold 24 in. Built-In Dishwasher...
"Normal" light flashes
You need a new control bd. #W10084141. If the diagnostic mode will not work then the board will have to be replaced.
Mar 06, 2009 | KitchenAid 24 in. KUDI02IRBS Stainless...
GU1200xtks0 Blinking Lights
Try pressing heated dry, normal, heated dry, normal keys within 6 seconds. All lights should come on and the machine should enter diagnostic mode. If this does not work remove the 2 screws that hold the toe panel on at the bottom front of the dishwasher, attached inside you will find a tech sheet that tells you how to enter the diagnostic mode. Once you get it in diagnostic mode let it do it's thing, will take about 20 minutes total. At the end the control will be reset. If the fault comes back then troubleshoot according to the tech sheet, or call for service.
Feb 20, 2009 | Whirlpool 24 in. GU1200XT Built-in...
Whirlpool 24 in. DU1055XTP Built-in Dishwasher
I don't know if your dishwasher is the same as mine, but this solution may be what you need. For electronic panel dishwashers made by whirlpool (mine is a whirlpool but with a kenmore name on it), some of them can be reset by pushing in sequence the Heated-Dry button followed by the Normal-Wash button, several times in a row. that is... Push Heated-Dry, then Normal-Wash, Then Heated-Dry, then Normal-Wash... Repeat until all lights light up. When all lights light up you can stop. The washer will then take 5-10 minutes to go through a diagnostics cycle, which is about 18-25 steps or so. You can bypass one step at a time by pushing the STart button. This may not apply to your washer, but is pure gold if it does. Good Luck!
May 26, 2007 | Whirlpool 24 in. DU1055XTP Built-in...
Whirlpool 24 in. GU3200XTP Built-in Dishwasher Logo
664 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
