Question about Zanussi Washing Machines
Zanussi aquacycle 1400 end light flashing
When selecting a programme all that happens is the end light keeps flashing and making a beeping noise
  • 1462 Answers
SOURCE: zanussi electrolux aquacycle 1400 xc 6 fx1465 w
assuming you had correct value fuse, fuse blowing may have been caused by a machine fault.after power outage, cycle should resume.
Posted on Mar 21, 2007
i have a problem with my zanussi aquacycle 1400 xtra capacity. some times it works ans some times not like there is a problem with the power the alternater? should i change this part? please help as my wife is driving me crazy.
Posted on May 31, 2007
SOURCE: Zanussi FX1465W aquacycle, beeps 5 times and end light flashes
I have the same trouble with my washing machine did you find a solution i have been told the PCB or motor drive system
Posted on Jun 16, 2007
faggly
  • 74 Answers
SOURCE: zanussi aquacycle 1400 fle 1416w
Hiya Cheap6... more than likely the brushes.. which are easily checked to see if they are worn down.. otherwise its a new or RE-con motor.
Regards Faggly
Posted on Mar 21, 2008
SOURCE: i need instructions for zanussi aquacycle 1400 XC
My washing machine dials won't light up and strait but the power is switched on
Posted on Mar 13, 2011
Zanussi zdt 6053 usually will not run full cycle (on any cycle) but stops with constant error beeps. But it is draining ok and sometimes goes full cycle (not often) Any ideas?
Could be anything!
If you suspect that there is a fault then it will be displayed by blinking LED "END OF CYCLE". As the display of failure in hexadecimal code it can flash up to max. 15 times than short pause and after that repeat fault code. You must to count the number of times the LED "END OF CYCLE" flash up.
Example from user manual: Anti-flood device is activated.
- continuous flashing of the indicator light of the running programme
- 3 intermittent audible signals
- 3 flashes of the END OF CYCLE indicator light
(which means "i30" fault code, the cycle is interrupted and the
drain pump switches on).
Possible causes:
Water leakage from the tub - sump and various connections
(pump, upper spray arm duct etc.); floating sensor blocked
mechanically; microswitch faulty; fill solenoid blocked
mechanically; circuit board faulty (solenoid triac short-circuited);
wiring faulty.
26226179-aipk5px1bmfkdpsmrgevaqwn-3-1.jpg Could be also:
To cancel a washing programme in progress:
- Open the dishwasher's door.
- Press the programme selection/cancel button for about 3 seconds,
until the indicator light of the running programme turns off and the
END OF CYCLE indicator light flashes, indicating that the running
programme has been cancelled and that the machine has
returned to setting mode. It is now possible to select another
washing programme. If a new washing programme will be
selected, check that there is detergent in the detergent dispenser.
NOTE: only during the drying phase, if the dishwasher's door will be opened and remains open for more then 30 seconds, the running programme will be automatically cancelled and the machine will return to setting mode. This will happen, always only during the drying phase, also when the machine is switched off by pressing the
On/Off button and remains switched off for more then 30 seconds.
Dado
Jun 26, 2016 | Zanussi Dishwashers
I have a bosch logicxx 7 washing machine. I've
Suggestion: Keep the beep button pressed or keep pressing till the beep indicates 'off'.
Mar 24, 2013 | Washing Machines
Zanussi TCE 7127 W, lights on, makes normal noise to start with, then no drum rotation, does this 3 times then buzzing (5 buzzes then a delay) starts, and 'end of programme' light comes on and stays...
5 beeps on the programme finished light means the motors knackered apparently, found that info elsewhere on the web. Done this to me today (and it's done it before as well, so i bought an extended warranty when the chance came fortunately). Time to get your guarantee or your wallet out i'm afraid.
Aug 19, 2010 | Zanussi TD4112W Electric Dryer
Zanussi fle1416w aquacycle 1400 xc , on some cycles it does not take in any water into the drum although water goes into the draw, clothes are totally dry at the end. Some times it keeps pausing and...
Check drain hose has not dropped down. that the height of the waste pipe is at least 50 cm high and the waste hose has not been pushed a long way down the stand pipe. all these things can cause the machine to syphon out all the water it has taken in. it more **** to happen on delicate programs with higher water level the beeping would happen after 5mins. comment back if this not the case
Jul 31, 2010 | Zanussi FLE1416W Front Load Washer
Zanussi TCE 7276W Condensor Dryer - no red lights but won't go!
Hello, have you cleaned the condensor stack just recently if so check that the stack etc is fitted correctly and the door is closed fully.
Hope this helps.
May 14, 2010 | Dryers
Has the condenser been cleaned lately if it is not put back in correctly then sometimes the micro switch on the door does not click in,check this door where the condenser sits.
Hope this helps.
Mar 25, 2010 | Dryers
My zanussi 1600 aquacycle will was but not drain
it sounds like have a bad water pump
Feb 24, 2010 | Washing Machines
I need instructions for zanussi aquacycle 1400 XC
Jul 03, 2009 | Zanussi F1245W Front Load Washer
Washing Machines Logo
49 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
