My Duplo DP 21-S II won't make a new master but shows no error message. How do i fix this?
I have checked all of the connections and all seems in order. I can't seem to print a new master but i can manually copy one. How do i fix this???
SOURCE: Error Message: Check SPF/RSPF START to Resume
I just fixed this problem on my sharp all in one. The white rollers on the underside of the copier cover were not rolling well. I took an alcohol prep pad and started cleaning them, rolling as I went. A large piece of lint fell out. I put the documents in the document feeder and they fed through like a charm. Hope this helps.
Posted on Jan 07, 2009
SOURCE: ''my duplo dp43s have an error display as seen in the drum connot
Ich brauche Softwere fuer meinen Flat bed Scaner CRIST/ Koennen Sie mir helfen?
Danke.
Gerd Rosien
Posted on Apr 03, 2009
M2Tech1
  • 313 Answers
SOURCE: A05-304 error & Top section of page cutting off
the thing might be down to an old master stuck to the drum this could cause the faint copies and the missing print.. pull the drum out check under the master.this would also cause the paper to jam on exit. the error is for no master eject check the calmp is free where it grips the master and also the path for the master eject to the waste bin
Posted on Jun 12, 2009
  • 5 Answers
SOURCE: Got error code e104 duplo DP-460H
We AEBO is professional manufacturer of compatible duplicator ink and master for Riso ,Ricoh,Gestetner,Duplo.
For Risograph : RZ/GR/RA/KS/CR/RN/RP/RZ/TR/FR /GRHD/RPHD
For Ricoh: VT/JP-6/JP-12/JP-500/JP-10
For Gestetner: CPI2/CPI7/Stencil ink 217 /CP15/18
For Duplo: 504/51F4/544/744/ND 24
With high quality at economical price . We have been awarded USA SGS certificate and China Excellent Brand.
AEBO packing ,neutral and your customized packagings are all available.
Sincerely hope a pleasant cooperation with you .
meachell@chinaaebo.com
Posted on Sep 02, 2009
JackHeath
  • 1049 Answers
SOURCE: E02-02 - what does this error mean for a DP-C213?
E2-02 means there is an error with the lifting motor assembly for tray #2. You will not be able to use your tray #2 until it's fixed. You can check it, sometimes there's just paper clogged at the rear of the paper tray. Remove your 2nd tray to see if there is a paper clogged inside.
Otherwise the cover/case of the lifting motor is damaged and you will need a service technician to fix and replace it.
Posted on May 07, 2010
Testimonial: "Thank you. You'd think you'd be able to search for this answer on Panasonic's Industrial site, but I couldn't even find the model number let alone the error code. Thanks for your help. "
Duplo dp-205A scanner open problem
duplo dp-203 problem scanner open
Feb 25, 2013 | Office Equipment & Supplies
I have a Duplo DP 43s which is displaying "paper jam at the ejection end" error message. Can't find anything at all stuck in the machine but the sheet passes just past the drum and then stops, so causing...
i don't know if duplo is same as the gestetner type of digital duplicator. try to look if the exit sensor is clean or in good condition and if the paper coming out in a normally manner what i meant is if it is flowing normally.
Nov 29, 2009 | Duplo Office Equipment & Supplies
Hi, how do i find out what the usage of my dp21s is (total copies & masters. alec
No error on the display but when i press on plate making sometimes nothing happens.DP-21s
Aug 27, 2009 | Duplo Office Equipment & Supplies
MY Duplo copy machine is DP-24SII.my problem is the ink con`t run out from the drum surface or the ink con`t transfer to my clothes
Mar 19, 2009 | Duplo DP21L Copier
Jan 08, 2009 | Duplo DP460H Copier
jasbo
jasbo
