Question about Grundig Televison & Video
On/off switch shorting out
On/off switch crackling and not turning tele on
  • 1,238 Answers
Just replace your on/off switch
Posted on Dec 10, 2012
On at the mains cant switch on the tele
Are there any lights on anywhere on the tele? Also what make and model is it ?
Feb 20, 2015 | LG 42LC2D 42 in. LCD HDTV
C352 fax not working
check the phone line is it digital if so no go has to be analog or old phone line, is the fax cable plug into line jack on copier not tele? have phone check line have you called you fax line any noise or crackling on the line, get the fax noise.
Mar 12, 2014 | Konica Minolta bizhub C351 All-In-One...
Hitachi 32ld8600 keeps blowing fuses
There should be a short circuit at the main power supply regulator board. Check all the rectifier diodes and other components. Check the switching device for short. To get more details, http://electronicshelponline.blogspot.com/
Nov 14, 2013 | Televison & Video
Crackling noise in light switch
Replace light switch.
Switch has a short.
http://waterheatertimer.org/How-to-wire-switches.html
Take photo of switch and wiring before removing wires, so it is easy to re-identify what wire went to which terminal.
Oct 22, 2012 | Leviton Electrical Supplies
Amp crackling noise
Sounds like you could have a blown amp/speaker or you've got a short in your speaker lead. Typically, when there's not enough resistance on a wire is when you start getting the crackling noises.
Aug 06, 2012 | Televison & Video
Crackle Then Stop
Check the firmware on the tv. I would imagine youre connected with hdmi, and some tv's (lg, vizio mainly) have had firmware issues. check teh lg website for updates.
Jul 01, 2012 | LG 32LG30 32 in. LCD HDTV
I have a sony amp model str de475 - one speaker (rf) crackles when its turn pass 3 on the volume scale
The problem is in the audio driver and audio output stages, check speaker wires for shorts, if okay! you will need a technician because of the complexity involved.
Mar 21, 2012 | Sony STR-DE475 Receiver
First of all, sorry for the mix up on model the model #. I was viewing a problem regarding LG LCD TVs and found your link. My problem is with an LG 42LGX LCD HDTV. It has worked fine without any issues...
welcome to fixya and thank you choosing my service..
OK,that is the most and common problem of all LCD TV...
Usually dim and totally have no back-light is cause of bad inverter board.One of the inverter board is shorted that cause dim light and crackling sounds..
This are the sample images of inverter board.
to make sure that the problem is on the inverter board kindly try to disconnect/unplug it from your TV and power ON then observe if the crackling sounds remain or not..If the crackling sounds gone replaced the inverter board..Also I need to how many inverter board you have? if 2 or more disconnect it one by one to determine if where is the specific faulty inverter board..
Example:
I disconnect #1 inverter still have crackling sounds..next disconnect #2 inverter and reconnect the #1 inverter until you found the faulty one..Note when you doing this make it sure you power off the TV before you unplug or disconnect inverter board because its high voltage..
I need the picture your TV screen..just send it to chesterpendilton@yahoo.com
Regards.
Chester
Jan 20, 2012 | LG 42LC2D 42 in. LCD HDTV
Car speakers turn on and off randomly and make crackling sound?
The answer is: "Yes." If your speaker wiring is such that they all share a common ground wire, and that ground wire is shorting out, it can cause all speakers to go silent when it is grounded (shorted). I would check the wiring, and replace any cracked wiring, and if the wiring looks like the shielding is worn, replace all the speaker wiring. Monster cable is the best, but any heavy copper wiring works fine. I often use 110V. appliance wiring to install car stereos.
Dec 18, 2007 | Audio Players & Recorders
Tv
I had the same problem with my new TH-50PX60B. I turned the tele on then after 5seconds it would switch off. The standby light would then blink on and off 11 times, pause for a second then flash 11 times. This would continue until the power wasturned off. Note the TV would not turn on for more than 5 seconds.
I solved this problem by turning the tele on and checking the fans at the back. My tele had 3 fans. If one of the fans is not turning, this will be the cause of the problem and the tele will shut down under the Emergency Shutdown System. To clear the fan try blowing on it to free up any dust etc. If that still doesn't work try using a thin instrument (tie wrap etc) to manually turn the fan and free it. Then power off the tele and turn it back on. The tv should work perfectly.
Sep 02, 2007 | Panasonic TH-42PD50U 42 in. Plasma EDTV
Televison & Video Logo
27 people viewed this question
Top Grundig Televison & Video Experts
Henry  Thomas
Henry Thomas
Raj Patel
Are you a Grundig Televison and Video Expert? Answer questions, earn points and help others
