Hotpoint washing machine WF321 loading door is locked despite red light going out, wonder if you have any suggestions to open, thanks Tracey.
Unable to open the door, despite the door lock going out.
SOURCE: Door won't open
My Zanussi has an outlet filter that is accessible by a little door at the front. It gets clogged if not cleaned for a month or two. Then the machine can't drain and the door won't open. Removing and cleaning the filter should correct the problem. You'll need some sort of container to catch the water that will pour out after you remove the filter.
Posted on Feb 11, 2007
SOURCE: Hotpoint Aquarius WF440 Washing m/c - Door Lock light
You have probably knocked of the connector or the catch (and on these it is very fragile as I have changed the catch 3 times on mine) is broken
Posted on Jan 22, 2009
  • 1294 Answers
SOURCE: washing machine door locked indesit WD12X
Try buttons "dry" & "spin" together for a few seconds. This is the child lock display.
Or press "end of cycle" for over 5 seconds.
Or press "options & select" till the light goes off.
Works for other machines..............And please rate me if helped
Posted on Apr 02, 2009
TheMobilian
  • 8220 Answers
SOURCE: HOTPOINT WF541 WASHING MACHINE DOOR CATCH
Check this out
Posted on Mar 19, 2010
SOURCE: door will not open on hotpoint wd420 washing
Turn off the power and isolate the water supply, Move the machine in to the middle of a room - you need some space. If you then rock the washing machine backwards, there is a door release. It's extremely hard to reach, about level with the lock, so make sure the machine is both stable and that someone is with you to ensure the machine doesn't fall and crush you to death!
It basically looks like an little electronic panel, in the middle of which you can see a steel knoble. Press with some force, and the catch will release.
This just happened to ours, and the actual lock is broken, so that was why we couldn't open the door. Yours might have a similar fault. The mechanism is partially plastic and it looks like the plastic sheared off and then the electric release no longer pulls the catch in to the position where it will release.
Posted on Dec 08, 2010
My washer dryer was on baby cycle wash and although the green light has come on to indicate it has finished, red lock key is also on and I am unable to open the door.
Martha, Try running another cycle, for some reason I think machine is sensing it still has water in it. If after running another cycle dose'nt do it, check links below to see (2nd link) how to open door manually with out damaging machine. press the helpful button
How to fix washing machine door lock in Hotpoint washing machine
Opening locked washing machine door
Feb 10, 2016 | Hotpoint Aquarius WD640 Front Load...
Hotpoint Aquarius WD63 door won't open
on some hotpoint models you can remove the front kickplate and on there will be a yellow or green plastic pull toggle, pull this and it will bypass your door lock, if your appliance does not have this then you will need to unplug and leave unplugged for 10-15 mins to reset the door lock, you will however more than likely need a new door lock
Apr 07, 2014 | Hotpoint Aquarius WD63 Front Load...
Door will not open have wash cycle
Switch off, put in spin/drain cycle and switch back on; check water is fully drained and then check filter. If not all drained, lower hose to ground level and drain to a bowl.
Apr 28, 2012 | Hotpoint Washing Machines
Red light continues to flash to say that the door is open. Door is actually closed,but will not go onto program as the machine thinks the door is open.
There is likely to be a problem with either the door solenoid/lock or the 'door closed' sensor requiring a service engineer's attention I suggest. Sorry ;-0(
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
Aug 16, 2011 | Hotpoint WMA32 Front Load Washer
Hotpoint aquarius wf321 when turn on all red light fleshing Problem nothing happenes.
half way through the cycle all the lights start flashing then it makes a loud noise when spinning
Jan 17, 2010 | Hotpoint Aquarius WF000 Front Load Washer
I've got a hotpoint wf220 wshing machine which is not spinning the pump is working and the on/off lights and mini load lights are flashing
i have a hotpoint wf321 water comes in and pumps out have flashing mini load light on and start light, but drum does not go round,
Jun 06, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Door locked light flashing when door is closed
push on the door where the lock is... it may not be fully locked.
Feb 22, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Door lock
Switch off. Try some WD40 on the machine lock (not on door) and open & close door many times, to ease out the lock.
Jan 28, 2009 | Hotpoint WMA54 Front Load Washer
Hotpoint WT741 Front Load- unable to open door.
hi julie,
is there an error message on your display?
can you provide me with the complete model #?
Jul 05, 2008 | Whirlpool AWM6120 Front Load Washer
Washing Machines Logo
52 people viewed this question
Top Washing Machines Experts
