TDX250i idock CD Hi-Fi power is on but unit is only showing the clock and does not switch on
I unplugged and moved my TEAC TDX250i idock CD Hi-Fi now although the power is on, LED lit on woofer and clock on unit, it will not switch on and a function cannot be selected. I have tried all the connections etc but still getting the same problem. Anyone with any idea what could be the problem?
  • Audio Player... Master
  • 1,267 Answers
The unit needs service- the control chip may have been upset with the plugging in of the device again. Unplug for a while and then try again.
There can be a defective capacitor in the unit as well. I could only tell you what the problem is after I fix it.
Posted on Dec 11, 2012
  • 277 Answers
SOURCE: Teac X-10 connections to a dbx 224
connect the x10 outputs to the dbx 224 line in connect the dbx 224 outputs to the cd recorder anlog line in windman
Posted on Jan 31, 2006
SOURCE: aiwa nsx k570
i need the circuit diagram for the CD player in NSX K 570 Aiwa 3 CD changer music system . I am Located in mumbai colaba. 9819890987
Posted on Apr 15, 2008
SOURCE: trying to set the clock on my TEAC CD-X60i - when
You have to set the clock with the unit in standby mode.
Posted on Dec 30, 2009
micromatikal
  • 2777 Answers
SOURCE: I have a Sony Mini
It is not possible to cheaply fix the problem, that is for sure. It is mechanical failure on the part of the mechanism. Have you tried unplugging it for a good 10 minutes, then replugging it in? As soon as you plug it back in immediately try to eject the cds. If this does not do it you will be forced to basically break open the cd player to get them out :(.
I'm so sorry about the bad news there, hopefully a "reboot" will at least let you eject them out of there
Tim
Posted on Oct 04, 2010
  • 99 Answers
SOURCE: Marantz CD48 - CD spins backwards
Check the small signal transistors BC338 and BC328, they're under the transport mech and will be near where the spindle motor plugs in to the PCB.
One of the transistors acts as a brake which momentarily puts the motor in reverse polarity to stop the CD rotating during 'stop' or 'open tray' modes. The reason the CD is spinning backwards is that the transistor which drives the spindle motor forwards during playback is faulty and is triggering the braking transistor hence spinning backwards.
The transistors should be 'BC328-25' / 'BC338-25' (25v)
Replace these and all should be well.
Hope this helps
Posted on Sep 01, 2012
I have a Teac Mc-dx50i Shelf System and it won't turn on. I was moving it from one room(playing fine) to another. Set it up, plugged it into the wall socket, turned it on and it will not power up. The...
First checked the outlet if it is live by plugging another unit to confirm if there was voltage coming that outlet. Let me know if it has a power.
Jdvillanueva
Mar 26, 2011 | Teac Audio Players & Recorders
Volume control does not turn volume down. Lost remote control CD Receiver LT-1
I have opened the same unit up. The volume control knob moves a plastic paddle against a right & left micro switches. The paddle is connected to the knob by a very thin piece of plastic which breaks very easily. I tried to glue a different piece of plastic on , but it only worked for a little while. It was a pain to assemble & reassemble the unit. I do not recommend trying it. Just buy another remote (about $35.00)!
Good Luck
Dec 07, 2009 | Teac LT-1 Clock Radio
My teac micro hi-fi system CD-X10i doesnt work
many units have a fuse inside the back cover near where the power cable comes in. be careful to replace it with the same size fuse as the problem that blew the fuse might still be there and could potentially cause a fire.
I have the same unit and i am looking for help because the cd will not run (wont spin the cd), but the door works. also the FM reception sucks.
Larry
Jun 15, 2009 | Teac CD-X10i Docking Station for Apple...
I cannot set the clock on my Teac MC-DX50i
put the system in standby then use your forward and revese buttons to set the time.
May 31, 2009 | Teac Hi-Fi Radio w/ iPod Dock BLACK...
I've found that I can only set the clock using the remote. Press and hold the 'time set' button on the remote, and using the forward and back buttons on either side of the play button, you can change your clock to a 12 hr or 24 hr time setting. Once that is set, press the 'time set' button and that will switch you to the hour, and using the same forward and back buttons, set that. Repeat the process to set the minutes. Press the 'time set' button again to exit out of if, and you're all set!
Mar 23, 2009 | Teac Hi-Fi Radio w/ iPod Dock BLACK...
TEAC SL-D80 POWER SWITCH
Try the reset button.
it's a tiny recessed button under the cd cover on the right side
Nov 09, 2008 | Teac SL-D80 Clock Radio
No sound whatever
when you switch the unit on make sure that you hear two clicks, this will tell you whether the protection relay is working. Should you hear the two clicks this will indicate that the audio ic`s are working. There are fuses inside the main component box, four on the transformer. Let me know the outcome
craig:)
Jan 20, 2008 | JVC MX-J900 CD Shelf System
System is lit with no display does not turn on
your set needs to be repaired have a tech look at your set, the power supply is defected along with the audio output.good luck
Jun 03, 2007 | Teac CD-X8 CD Shelf System
60 people viewed this question
 Grubhead
Grubhead
