Question about Sony FD Trinitron WEGA KV-32FS120 32" TV
Yolk? Thank you for your suggestion. Could you please tell me what the yolk is?
    Problem Solver:
  • 12 Answers
Yolk is what controls the direction of the beam ion inside the picture tube.this controls the horizontal and vertical beams
Posted on Jan 13, 2009
How long does it take hair to grow in a month?
1-2 inches
If you leave egg yolk and massage it through your head it will grow faster. Or you can use olive oil. Some sugests that maybe you should just brush it 100 times before you go to bead. Don't ever brush it wet.
Apr 13, 2016 | Health & Beauty
How do I remove the shift lever yolk triumph spitfire 1500
Wow you have the old english car those are fantastic automobiles I have never had the honor to ever work on one. I would suggest research it online or if you know of some people that have intimate knowledge about this machine help you. wish you luck friend
Aug 30, 2014 | Cars & Trucks
Chevy diagram
If it is a clunk noise/feel then see that topic already discussed. Output shaft yolk to driveline issue. Replace output shaft yolk with nickel plated yolk. Chevy dealer will know the part you need.
Nov 27, 2013 | Chevrolet Blazer Cars & Trucks
Have 1990 kaw mule 2010 4x4 KAF540C1 bought about three months ago found out that I am missing front shaft and Diff yolk and spline someone tell me how do I found parts please help
I would be contacting a shop that specialises in the manufacture of tail shaft and drive lines for the front shaft / yokes and splines
Sep 28, 2013 | Cars & Trucks
I want to replace my pinion seal and i need the procedure to set the crush collar ,ive done many rears in the past , i just forgot. mostly 9 in fords and 12 bolt chevy. do u do 05 ram 1500 the same
It would be hard for me to tell you exactly, but I can tell you what will work. Being everything is all together and in the vehicle, you will need to do this by feel. With the wheels off the ground, the brakes can't be dragging, you have the seal installed, put the yolk and nut on, preferably with a half inch drive impact, run the nut up until it barley starts to get tight. Then take both hands and turn the pinion yolk, you need to tighten the pinion nut a little at a time until it starts to get a little hard to turn using both hands, If the brakes are rubbing, you wont get the right feel. If you can't turn that yolk with both hands, it is to tight.
Mar 08, 2011 | 2005 Dodge Ram
Hello i have a 1993 ford f350 4x4 with the 7.3L non turbo diesel and 5 speed manual transmission. my front driveshaft just gave out on me at this wierd looking end where it meets the transfer case. what is...
I work in an automotive recycling yard. I can only think of either the yolk, or the universal (u) joint. There's usually a slip yolk in the middle of the shaft to compensate for the front end travel (up and down). In any event, you can Google images to clarify what part you're referring to. You can also look for the shaft, or front yolk near you by searching Car-Part.com. If it's just the universal joint and the yolk isn't damaged, you can replace just the u-joint. I hope I've helped. If so please rate my assistance and leave a testimonial. There's only just so much information I can offer without direct communication. Thank you for using Fixya.
Jan 27, 2011 | 1993 Ford F350
Manual ford f-150 stuck in first and will not shift into any other gear please help !!!!!!!!!!!!!!!!
will try to help. what year of the truck? this matters!! is clutch working? inother words, can you see the clutch on transmission,yolk, or arm, moving in and out? try pumping the clutch several times, depending on what year model, it may only be low on fluid. it matters whether it's a hydraulic clutch or a manual clutch. i suggest you repost your question with as much information about your truck,year, make model,engine size,as possible. this helps us determine where and as most information as possible to relay to you!! as always, thank you,for choosing, fixya.com
Nov 26, 2010 | Ford F-150 Cars & Trucks
Dead Mitsubishi VS-5006R.
The most common problem with this set in the start up circuit of the power supply. There is a resistor, a 270k, R903, and even if it checks or looks good replace C920. Also there are small resistors off the flyback transformer that will open up because of bad capacitors feeding those circuits. Also any capacitor that has a swollen top or body, replace. Double check and make sure the B+ fuse is not blown. If it is, before you replace it, check to see if the horizontal output transistor is shorted. If it is, replace the transistor, BUT intall a 100 watt light bulb across the blown fuse. If , when you turn on the TV set, the light bulb glows bright, one of the deflection yolks is probably shorted. Unplug the set, and pull out one of the yolk plugs. tun back on the set. If the light now glows dim you have the bad yolk. If it does not and is atill bright, unplug the set, replug in the yolk, and take another yolk plug out. Do in this order and replug back in the tested yolk and make sure you unplug the set each time you do this or you will cause more problems. goos Luck. Please do not forget to rate this thread.
Dec 11, 2006 | Mitsubishi VS-50605 50" Rear Projection...
Sony FD Trinitron WEGA KV-32FS120 32" TV Logo
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
