Question about Beats By Dr Dre Beats Executive Over Ear Headphones Black
Right speaker is not working
After used for 1 month only...suddenly the right side of my beats executive cant come out any sound ,but if i pushed it a little tip of it,the sound come n the goes out again
2 Suggested Answers
SOURCE: only 1 side of my dr dre detox is working
THE INTERNAL WIRE CONNECTING BOTH HEADPHONES IS BROKEN. THIS PROBABLY HAPPENED WHEN TWISTING ONE OF THE HEADPHONES TO HEAR ONLY THROUGH ONE OF THEM. TRY FEEDING EEACH HEADPHONE INDEPENDENTLY WITH ITS OWN CABLE USING ONE OF THOSE PLUGS TO SHARE MUSIC FROM SAME SOURCE.
Posted on Jul 31, 2012
Only 1 side of my dr dre detox is working
Jun 22, 2012 | Beats By Dr Dre Beats By Dre Detox
The right speakers logitech Z 5500 do not work
try buying a new optical cable or change some settings on your tv.
Feb 04, 2010 | Logitech Z-5500 Computer Speakers
One of my DJ turntables = only left side stereo sound
need to narrow it down, using 1 turn table ONLY with the mixer on channel 1 (the chanel that is working) to test reciever is working properly and sound working on both side of the speakers, this eliminate the first turn table. Next, disconnect the working turn table (1) and connect your second turn table to the same chanel and see if you getting the sound coming chanel 1 just as your first turn table did. If you getting sound coming out from turn table on ch1 than is not the turn table issue. It will be you mixer having problems. You cant solve the problems having everything connected. Testing one turn table at a time using working chanel on the mixer to see if both turn table working properly. If you use the same chanel testing both turn table and the second one does not work than it will be one of your turn table is faulty. Note: if you find and test both of your turn table is working properly than it will be your mixer. good luck and hope that help..
Aug 06, 2009 | Technics SL-1200MK2 Turntable
My speakers wont work suddenly unless I am using my headphones
Make sure in the volume mixer that it is using the right sound device. You most likely have it set to the wrong device output. When you plugged in the headphones in kinda automatically switches, but to use the speakers again you have to do it manually. Just hook up a cheap av receiver to your computer and use this headphone input instead. a 100$ 5.1 av receiver beats any pc speaker system.
Aug 01, 2009 | Toshiba (4CH-VOUT) Sound Card
Left speaker suddenly stopped working correctly.
check the plugin going into the back of the computer. it might be loose and only sending the audio to the right channel. Otherwise, check the connections in the back of the speaker.
Jul 11, 2009 | Insignia 2.1 Speaker System (3-Piece)
Left speaker port shorted out
I found that the part is called a speaker input and I was able to find one and am having it replaced. Thanks.
Feb 17, 2009 | Philips Magnavox 42MF521D/37 Television
Sudden crackles in the right surround speaker!
Your speaker is busted. You will need to get another one. It really can not be repaired and if it can, it will cost more than a new speaker.
Sep 12, 2008 | Logitech X-540 Computer Speakers
My JL subs just dont beat like the ONES IVE HAD before as well as the ones my friends have had
sounds like they have your sub amp in mono but they put the speakers in series which totally cancels the benefit of running your amp in mono. you will probably be happier if you just hook the left speaker to left plus and minus and the right to right plus and minus. Cuz even though subs aren't directional they do pass some higher frequencies that are and that dilutes the stereo effect.
Jan 19, 2008 | Jl Audio 500/1 Car Audio Amplifier
Transmitter not working
You can 'pump up' the circuit on the transmitter by pumping the power connector in and out of of the back of the tranmitter to the beat of Beethoven's 5th: da duh duh duh, da duh duh duh, da Duh Duh.
It is a little awkward the first few times you try. You have to get the power connector in far enough each pump that the unit gets a pulse of power. It has to be pumped at the right pace, not too fast, not too slow, the beat of Beethoven's 5th is pretty quick and just right.
I have been powering our WSP155 transmitter unit on at work this way for several months. We originally had 4 sets of these, only using 1 transmitter at a time. 1 transmitter, 8 speakers. Over the course of a year or two, all of the tranmitters went bad the same way and now that I discovered how, I can make them all power on using this method, so I am pretty sure yours will power on this way too.
Nov 22, 2007 | RCA WSP155 Main / Stereo Speaker
Sound not coming from left side surround sound speaker or my right side front speaker
it is highly likely that you're TV is outputting mono sound, hence the left channel only. check your physical connections to the TV and the balance / channel volume on the television as well.
May 01, 2007 | Onkyo HTR500 Receiver
Beats By Dr Dre Beats Executive Over Ear Headphones Black Logo
278 people viewed this question
Top Beats By Dr Dre Audio Players & Recorders Experts
 Grubhead
Grubhead
Mike
Tom Chichester
Are you a Beats By Dr Dre Audio Player and Recorder Expert? Answer questions, earn points and help others
