Question about Radio Communications
My whb003 headset doesnt charge
Why doesnt my whb003 headset charge
It doesnt take charge and its not coming on
Have you manged to solve this problem? I too have this headset (P590E) and eventhough it switches on, the batteries have drained and will not charge, when plugged in no lights appear.
Thanks
Apr 17, 2011 | Plantronics Pulsar 590A Wireless Headset
Headset doesnt turn on, no red light while charging?
It is possible that the internal battery in the Plantronics Explorer 320 is just worn out, it is an older headset and has been out there for years. The Plantronics M20 would be a good replacement to check out.
Plantronics M20 Headset
Good luck from Headsets Direct!
Jan 11, 2011 | Plantronics Explorer 320 Wireless Headset
I have a madcatz headset, Well The Headset still working in the ps3, but today when i put it to charge doesnt want to charge anymore, and the USB cable looks perfect, i didnt dmged it or moved it. is weird
Seems you should order another cable from madcatz because your charging cable might of become faulty or you might want to change usb ports on the computer you are using.
Jun 12, 2010 | Mad Catz Bluetooth Headset for PS3
H550 doesnt do anything
If it won't charge at all, it is defective and you need to return it for a replacement.
Jan 23, 2008 | Motorola Mobility Bluetooth Hands Free...
Wep210
There's a small power jack under a tab at the base of the unit. I found it only charges if you plug it into the transformer travel charger. For some reason plugging it in the PC USB port doesnt work.
If the unit is being charged a red LED will light up, turns blue after 2/3 hours when its fully powered up.
Jan 21, 2008 | Samsung BLUETOOTH? WEP210 MONO HEADSET...
Charging
Jan 08, 2008 | Samsung BLUETOOTH? WEP210 MONO HEADSET...
Radio Communications Logo
100 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
