Question about Palm Treo 750 Smartphone
How do I change the clock on the today screen to digital
Hold the stylus on the clock icon in the start bar for 1-2 seconds
Posted on Feb 12, 2009
Digital Clock on 2002 Jetta keeps changing time constantly.
your clock is broken, the only fix is replacement
Nov 26, 2012 | 2002 Volkswagen Jetta TDI
I don`t know how to change the date and time of my sony dsc-t200
Hello there. You can do it this way:
1 Select (Clock Settings) from (Settings) on the HOME screen. 2 Touch [Clock Settings]. 3 Touch the desired date display format, then touch [t]. The clock settings screen appears. 4 Touch each item, then set its numeric value by touching v/V. 5 Touch [OK]. To cancel the clock setting Touch [Cancel] or [BACK] in step 5.
Sincerely, Steve TM
May 28, 2011 | Sony Cybershot DSC-T200 Digital Camera
Skyscan digital wall clock just quit showing outside temperature
you probably need to 'pair' the outdoor sensor with the main base: look for a 'channel' button, as these units usually can get information from several sensors and differentiate them by a channel number.
May 10, 2010 | SkyScan 86742 Digital Atomic Wall Clock
How to display time
Click on Main Menu, then Settings, then Personalize, then Home Screen, Hit down arrow to Clock: then hit Change Select Digital then hit Select Again, the Screen will then confirm Clock Changed. Now go Back to your home Screen and you should see the clock display in the upper right corner just under the Battery Icon...
May 02, 2009 | Motorola Mobility MOTORIZR Z3 Cellular...
I can't change the time of the clock on the Hyundai 50645P CD player/AM FM clock. There is no information in the Sante Fe manual. Any advice?
Try this, put the key in the ignition and let it be on the first turn right marked "ACC" or you can turn off the stereo and you will notice that only the Digital Clock screen will show. Turn the Volume/Audio/Sel knob and press on the "DISP" button simultaneously for about 4 seconds then release the "DISP" button. The digital clock will start blinking, and then use the Tune/Seek arrows pointing up and down to change the time. If the hour digit is blinking change the hour and after you have changed it press "DISP" then the minute digit will start to blink change it using the arrows, when you are done press "DISP" again or leave the clock for between 4 to 8 seconds the clock will start working normally.
I hope this works for you.
Aquinas
Apr 19, 2009 | 2004 Hyundai Santa Fe
How do i change the clock on a sts 2008 cadillac w/navigation sys
Had the same problem...hit CONFIG...then Vehicle on the left side...when the Vehicle screen
shows all the info on languages....hold your finger on the clock in top right corner. The clock
adjust screen should appear. I could never get the clock adjust screen because I was just
touching the time...you have to keep your finger on it until the screen comes up. Hope this helps.
Gary
Virginia
Mar 20, 2009 | 2008 Cadillac STS
30 gig zune frozen on "ZUne screen"
Theres a note on the zune website about this issue today... Looks like its microsofts fault! At least I feel better knowing I didn't break my zune!
Dec 31, 2008 | Microsoft Zune 2nd Generation Digital...
T-Mobile Wing Time Display
on the today menu press and hold the time and change it to digital
Jun 25, 2008 | T-Mobile Wing™ Smartphone
Palm Treo 750 Smartphone Logo
35 people viewed this question
Top Palm Computers & Internet Experts
Michael Vincent Cruz
ray gallant
Raj Patel
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
