Yamaha radio receiver RX 395 switches off seconds after switching on.
Unit powers up for only a few seconds before switching off again.
5 Suggested Answers
SOURCE: Yamaha RX-V1 Power
Got the same problem and did some searching.
Strange thing is that next day the amp works fine.
This is what I found on http://www.forums.hcsd.com.au/Blah.pl?m-1210733289/s-8/
SYMPTOM: The power cannot be turned on, or the protection circuit is activated to turn off the power.
CAUSE: Fluid leakage occurs from the backup capacitor C633 0.047F 5.5V (C662 in the case of RX-V3000/DSP-AX2) on the Function PCB and causes a short with the adjacent components and between patterns, resulting in operation of the protection circuit. Fluid leakage tends to occur with this capacitor particularly with high internal cabinet temperatures, with or without the power on. Often, the leakage is only visible with very careful inspection.
SOLUTION: Two types of backup capacitors are now available with a longer expected service life. When servicing, thoroughly clean the leaked fluid from the PCB and from under any nearby components before replacing the capacitor. There are models other than those mentioned above that use the subject backup capacitor. Check them for fluid leakage and replace the capacitor as needed.
PART(S): Old
Ref. No. Part No. Description Remarks
C633 or
C662
VT740700
V3860300 ELECTROLYTIC CAP 0.047F/5.5V Vertical type
* VU545000 ELECTROLYTIC CAP 0.047F/5.5V
Horizontal type
New
C633 or
C662 WD294400 ELECTROLYTIC CAP 0.047F/5.5V Vertical type
* WD292000 ELECTROLYTIC CAP 0.047F/5.5V Horizontal type
Posted on Jun 24, 2008
SOURCE: yamaha rx-1500 av receiver
some times the speaker cables are touching, double check, I had this with my amp and it kept turning itself off
Posted on Jun 25, 2008
  • 125 Answers
SOURCE: Yamaha RX-V995 receiver turns on & then powers off 2 seconds late
I suggest you run self diag.  press [FM/AM] key + [Input mode] key and press the [power/standby] switch.
ps prt = power supply problem
dc prt = shorted output or leakly cap in channel
tmp prt means to hot on heatsink
you'll likely have to measure the resistances of the output FETs to find a short,
Posted on Feb 03, 2009
  • 127 Answers
SOURCE: Yamaha rx-v456 av receiver, shut down with optica cable
Does it work without PS3 attached?
When receiver turns off, it is usually due to badly connected/configured speakers. Try powering on the receiver without speakers.
Posted on Mar 02, 2010
HP Officejet 1175c powers down after 30 seconds, say, then will not switch bck on until 60 seconds have elapsed.
Hi, I have a similar problem with power on of my HP Officejet 1175c as it does not turn on, when I press the turn on bottom. But if I wait some minutes it might power up for a few seconds and then turn off again. I have tried then to press the "Menu bottom" for a second, and it then sometimes power up and once it is up and warmed up it might print for hours, if you keep it busy. But if you leave it for a while, it normally turns off again and goes back to the "turn off / turn on" switching mode.
I cannot turn off the printer, but has to let it fall into "sleeping mode" and then takes the power from the source.
Does any body have a better more permanent solution, I would really like to have it. Could you replace the power on switch or unit?
Best regards Dan
Oct 06, 2010 | HP OfficeJet Pro 1175c InkJet Printer
I have a tom tom 340s xl. we were on a trip and the tom tom died. it will not come back on. what can I do?
if the battery went flat and the device switched itself off, plug into power supply and press and HOLD the power button for a few seconds until the unit powers up again. Can take 3 - 4 seconds
Oct 05, 2010 | Tomtom GO 300 GPS Receiver
Monitor turns off after a few seconds. Have to
my_secret_mb, Stop pressing the ON/OFF switch! It's broke!!! The unit's internal power supply will need some work done on it. Unit will need to be evaluated first!! This is a common problem for ALL LCD monitors. If unit out of warranty period, then you will need to do some intense speed reading of my higher page number responses in my fixya profile to understand the problem your cold-cathode-fluorescent-lamp back-lit lcd monitor has and the options that you have. You will also need to base your decision on the age and total number of "ON" hours unit has seen during it's lifetime. Do not dispair or feel sad about what has happened to your monitor. A low side guess would be 50 units/day fail world-wide. Your unit may have failed filter capacitors or possible failed solder joint on printed circuit board. (thermally intermittant) I hope this helps you. 12fixlouie north of "Windy City" USA
Apr 02, 2010 | Dell E176FPB 17" TFT LCD Flat Panel...
Somenon put a power on password on a hp desktop DC7900 PC
Turn the unit off. If you open the unit there will be a jumper to clear the CMOS and a battery. Remove the battery and then switch the jumper as silkscreened on the board. usually there are 3 pins currently crossed are 1 and 2. switch it to 2 and 3, press the power button then hold for a few seconds. unpress the button and remove the pwoer cord. press and hold the power button again for a few seconds to clear all power. reconnect the jumper to 1 and 2. put battery in and plug and boot. password should be gone.
in some units there is a "clear password" or "cmos password" jumper. crossing this will remove the password in those units.
Feb 17, 2010 | HP Compaq DC7900 PC Desktop
1) I turn on the power and place a prerecorded
If it is not a bad soldering joint somewhere, it could be the mode switch. They can sometimes be cleaned with Servisol Video 40, but you might have to replace it.
Dec 21, 2009 | Panasonic AG-1980 S-VHS VCR
The printer switches on and then cuts out a few seconds later. It can be switched on again after a few minutes but it cuts out again
This would be due to a power supply issue inside not the cable outside but inside the unit. now this would be kinda hard to repair or replace as its built into the logistics of the unit you might want to contact HP if you have a warrenty if not I would concider scraping it for another is this is a relitive expensive repair.
Nov 06, 2009 | HP PSC 1110 All-In-One Thermal Printer
Unit does not turn on. There is power at plug . Slide switch left and right, no power, no screen
hook it up to the usb cable to your computer for a few hours, then try again. if that fails, press and hold the lower right corner of the screen, while pressing on the lower right corner, slide the switch to the on position for a few seconds, then follow the on screen dirrections.
bill
Oct 29, 2009 | Garmin Nuvi 760 Handheld GPS Receiver
Powering up and staying on to use????
1. If the unit stays on after you pressed the on button you may have an on/off switch on the back of the unit to trun it off.
2. If you switch on/off the PC with a "press on press off switch, the switch may be faulty.
3. If you have Windows XP and you have tried to "shutdown" this is due to a program running and has not completed it task.
4.Unplug the PC from the power for a few seconds ( 10 at the most) and then power up again and restart.
Aug 24, 2009 | Computers & Internet
Philips 765 CDR - twin deck
Remove the 765's casing. If you don't have a star shapped screwdriver use a flat head which sits tight in the screwheads diagonals. Once removed, observe the 765's driver chip which sits behind the recording deck mechanism of the left hand deck. With the power cord disconected carefully remove this chip by gently working a flathead driver between the chip and it's base (the chip is not soldered to it's base but take care not to bend the pins) Once removed, power up the unit for a few seconds making sure that you do not touch the live internal workings. Remove the power cord again and switch the power button on for a few seconds(with no power chord attached) to allow the units capacitors to discharge fully . Gently replace the driver chip. Replace the cover and switch the unit on again. The unit should reboot and the gremlins should be gone.
Jun 03, 2009 | Philips CDR600 CD Recorder
TV Switches off then on again.
i think problem with your SMPS power supply unit. Modern tv comes with microprocessor unit which control switch on/off functions. Check SMT transformer. Check Voltages power suplpy unit. contact service centre for further rectification
Dec 22, 2007 | Televison & Video
95 people viewed this question
 Grubhead
Grubhead
