Question about Vacuums
Burning smell on first use - Vacuums
    Top Expert:
  • Vacuums Master
  • 14,553 Answers
Either the belt is slipping for the brush( a look where it connects to roller or spindle that drives it will show black residue in excess. It is also possible to be at the motor itself which is less common as most units if get that hot at the motor will trip a thermal breaker in the unit.
Posted on Dec 17, 2012
Vax troubleshooting
Burning smell from a vacuum usually comes from the belt....check
for any objects caught between the belt and the brush roll. Is the
surface selector at the correct setting?
Aug 16, 2014 | Vacuums
Burning smell Kenmore 50558
If the burning smell is an electrical smell it could be motor or wiring problems which are best handled by a professional. If it smells like burning rubber it is probably the belt. If it smells like burnt wood it could be the belt slipping on the brush roll, if the brush roll is made of wood. Dust and debris can also accumulate behind the end caps of the brush roll causing friction which can cause a burning wood smell.
Mar 30, 2014 | Kenmore 5055, 50557 and 50558...
Work well but smell like a burning belt
If it smells like burning rubber, the belt is probably worn and slipping. If it's another burning smell, your motor windings are probably shorting and will burn out soon
Oct 12, 2010 | Rainbow E series Canister Wet/Dry Vacuum
Vacuum smells like something is burning
Ok...Check the brush roll is free not sticky..Next is the belt okay, not jamming on the brush roll making the burning smell...You could take off the roll and run motor on its own ..finding out if its the motor..
Apr 13, 2010 | Bissell Healthy Home HEPA Bagless Upright...
My vacuum cleaner is giving off a burning smell.
if its a rubber burning smell check the belt and the brushroll. if its an electrical burning smell then dont use it. the motor is overheating and will eventually get hot enough to catch fire.
Jan 02, 2010 | Vacuums
Our vacuum smells like burning rubber. Does it
Burning rubber smell means the brush belt need attention. Make sure the brush is turning freely and replace the belt
Jul 05, 2009 | Eureka Vacuums
Burning rubber smell when the vacuum is on.
it sounds like the belt may be burning like the roller bar is stuck maybe or the belt is stretched and is burning itself off
Jan 11, 2009 | Kirby Ultimate G Bagged Upright Vacuum
Hoover mach 4 burning smell
There are two reason you could be smelling a burning smell-
1. The belt is too stretched out and needs to be replaced. This causes it to slip when the vacuum is on and will create that type smell. You can avoid stretching and having to replace the belt to often by releasing the belt after each vacuum.
2. There may be hair or other debris stuck around the rod that the belt is attached to. Can be avoided by checking after vacuuming.
Hope this helps
Nov 12, 2008 | Hoover Vacuums
Sebo x1.1 - burning smell
Try replacing the belt. My vacuum cleaner had the same problem and once the belt was changed the burning smell was gone.
Jun 10, 2008 | Sebo Automatic X1 Bagged Upright Vacuum
My bissel 7901 won't spray water out of the bottom or hose to clean the carpet. I did smell a burning smell and shut it off. Is the pump gone?
Depends, if the the smell was like rubber, then it may be the pump belt. If it is ok, then the pump could be bad, altho the pump wouldn't have had a burning smell. The main motor would if it was an electrical smell.
Apr 14, 2008 | Vacuums
Vacuums Logo
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
