Question about HP Computers & Internet
HP Pavilion dv8 not starting up
Power switch just flashes once and then nothing
    Novelist:
    Champion:
  • 233 Answers
For this kind of issue, please follow up the following steps to check:
1.confirm the battery and ac adapter connect the laptop normally.Maybe the bad connect lead to this problem. If there are no lights when you turn on laptop, one of possible reason is that your adapter is malfunction.
2.the second possible cause is laptop dc jack failure. If the dc jack is broken or loose, you are required to replace it or repair it.
3.Another possible reason is that there is something wrong with laptop motherboard. For this situation, it includs two kinds of possibility,a failure in an electronic circuit and BGA malfunction.
For more detailed reasons and solutions, please have a look at the following article:http://www.ifitjams.com/lappower.htm
If you verify your laptop adapter is dead and you plan to order a new one, I recommend one for you on the basis of your laptop model:
http://www.chargerbuy.com/replacement-hp-pavilion-dv8000-ac-adapter-18-5v-4-9a.html
Posted on Dec 13, 2012
3 Suggested Answers
cpenzes
  • 1102 Answers
SOURCE: Hp Pavilion dv6000 Won't start
If you have'nt done any upgrades like windows or memory
I think you just need a new fan
possibly power supply
if you take it to a small pc shop they will test power and fan for you usually on the spot at little or no cost
please don't forget to rate me
Posted on Feb 04, 2009
  • 20 Answers
SOURCE: my hp pavilion dv8 laptop keyboard wont work.this
Here are some great source where will will get any kinds of HP,ACER,DELL and COMPAQ laptop Solution and any kinds of Driver download.
» Hp Laptop's Solution
» Compaq Laptop's Solution
» Acer Laptop's Solution
» Dell Laptop's Solution
» Toshiba Laptop's Solution
» Asus Laptop's Solution
» Hp Driver's Download
» Compaq Driver's Download
» Acer Driver's Download
» Dell Driver's Download
» Toshiba Driver's Download
» Asus Driver's Download
hoyagese84
Posted on Jan 03, 2010
Can a hp pavilion dv5-1127cl power port work in a
Hi there
I think in this particular case it might not be wise. The power blocks for these two appear to be different wattages (65 & 90 respectively) and also the connector to the laptop does not look to be the same, in which case damage to the power inlet socket of one or the other laptop could occur if you tried to fit it too energetically. I did find this eBay seller who gave quite a list of compatible laptop models for the power supply he was selling, but although the DV7 series is there, the DV8 series isn't.
AC Adapter Charger for HP Pavilion DV5 1127CL DV5 1128CA Power Supply
I think you would be better to get a power supply that exactly matches to prevent potential future problems.
Perhaps not the advice you were hoping for, but I would get a new one for whichever machine you need it for, and make sure that compatibility with your machine is specifically stated.
Cheers
Nov 10, 2014 | Computers & Internet
Hp pavillion dv8 wifi control problem
do you mean it disconnects or it actually turns off. if it turns off, it's probably a problem with the card. if it disconnects it may be an issue with the access point.
Dec 05, 2013 | HP Pavilion dv9000z Notebook
Ya know........Pavilion dv8 is a Series of Notebook PC's.
Encompasses a LOT of models in the series.
Have no idea of which LED in front you are referring to.
Do know;
1) Test the AC adapter (Charger) with an economical multimeter.
Average cost is $5 to $12.
Set to DC Voltage, and check the output voltage of the AC adapter.
As far as I can tell the DV8 series uses 18.5 to 19 Volts. (DC)
Use an AC adapter that is rated at 90 Watts, NOT 65 Watts; if using a replacement AC adapter.
The port on the laptop that the AC adapter plugs into is a DC Power Jack. (DC_IN)
The plug end on the power cable from the AC adapter, and plugs into the DC Power Jack, has a Center Hole, and an outside cylindrical metal shell.
The Center Hole is the Positive connection. This is where the Positive (Red) probe lead of the multimeter goes.
The outside cylindrical metal shell is the Negative connection. This is where the Negative (Black) probe lead of the multimeter touches.
Also have an assistant gently wiggle the power cord TO AC adapter; and power cable FROM AC adapter to laptop.
Intermittent reading indicates a broken wire, or wires.
DC Power Jack LED lights up? Means nothing to me. I want to know the FULL DC Voltage is getting TO the laptop, and there are no breaks in the wires of the power cable, or power cord of AC adapter.
THEN AC adapter checks out.
2) AC adapter checks out?
What condition is the DC Power Jack in?
Battery removed, use the eraser end of a No.2 pencil, and GENTLY see if you can wiggle the Center Pin around.
ANY perceptible movement of the Center Pin, means replacement of the DC Power Jack.
Fortunately for this series the DC Power Jack is connected to a cable with wires, and they end in a plug connector. Which plugs into the motherboard.
It is now a DC Power Harness.
HP calls it a Power Connector Cable.
http://www.amazon.com/PAVILION-Series-DC-IN-POWER-HARNESS/dp/B005WMWMMU
3) Next in line are the Power MOSFET's, in the power circuit section, on the motherboard.
!O_O!
MOSFET;
http://en.wikipedia.org/wiki/MOSFET
Power MOSFET;
http://en.wikipedia.org/wiki/Power_MOSFET
Should be on the motherboard, near where the Power Connector Cable plugs in.
Rectangular shaped with 8 'legs'. ('Legs' are J-Leads)
Believe one or more to be the problem.
Typed the rest above because it is a power flowchart, and when diagnosing always go through the steps.
Would s-uck to replace a motherboard, when the problem was an AC adapter, it's power cord, or the DC Power Harness.
This is more on the subject, by using the HP pavilion dv6000 series, and Pavilion dv9000 series of Notebook PC's; as examples,
http://mayohardware.blogspot.com/2010/04/important-parts-on-dv6000-and-dv9000.html
Further this is to show the availability of the Fairchild Semiconductor - FDS6679 - Power MOSFET, and Alpha & Omega Semiconductor - AO4407 - Power MOSFET,
http://www.mouser.com/Search/Refine.aspx?Keyword=FDS6679
Scroll down.
http://www.mouser.com/Search/Refine.aspx?Keyword=AO4407
AO4407 has been phased out. Let's look at one of the cross-reference examples given,
http://www.mouser.com/ProductDetail/Diodes-Inc/DMP3020LSS-13/?qs=%2fha2pyFadujguNNSgppBRqXbOxXLwzGsZm9SWxz1EqWpzoSJOpHpWA%3d%3d
That is correct. $1.01 USD for a FDS6679, and 78 cents for a substitute AO4407.
http://www.youtube.com/watch?v=5uiroWBkdFY
http://www.youtube.com/watch?v=RjpNbuOrOuw
Also check the MLCC's (They are also SMD. Surface Mount Device)
Multi-Layer Ceramic Capacitor
Here are examples. Not correct values, Capacitance, (MicroFarad's), and Voltage,
http://www.mouser.com/Passive-Components/Capacitors/Ceramic-Capacitors/Multilayer-Ceramic-Capacitors-MLCC-SMD-SMT/_/N-b2cj?P=1z0wrjcZ1z0x565
Scroll down.
These will be close to the Power MOSFET's.
See if any are burned, or blistered.
HP Support > Pavilion dv8-1100 using for an example > Manuals download page,
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?cc=us&dlc=en&lang=en&lc=en&product=4100035&
Scroll down.
HP Pavilion DV8 Entertainment PC - Maintenance and Service Guide; in blue.
This is a free Service Manual.
Remove ALL Power. Remove the AC adapter, and Battery.
USE an ESD wrist strap, and have it's alligator clip attached to a good ground source.
For additional questions please post in a Comment.
Regards,
joecoolvette
Regards,
joecoolvette
Dec 10, 2012 | Computers & Internet
My HP dv4 1120us laptop will not power on. When I insert the power cord the led for power bolt comes on and when I press the power button the power LED flashes once and then nothing happens. The power bolt...
Sounds light a power switch short, but lets try to take the memory out of the laptop and power on the laptop. Does it boot up? if so lets try 1 memory stick at a time.
Nov 29, 2010 | HP Pavilion dv4-1120us Notebook
My HP Pavilion Dv6700 turns on but nothing on the screen as in its black, BIOS do not show. Please help!
Looks like the post itself fails on the system from what you have told here. Its easy to reset the bios. Download the actual bios flash program on a completely formated usb drive. Fix the usb on your laptop and keep fn+esc keys pressed and switch on the laptop. It will rewrite the bios and once rebooted the system should work. Good Luck.
May 05, 2010 | HP Pavilion DV6700Z Notebook
The audio driver on my computer went out.. and ive gone online to download the audio driver.. but it doesnt work at all.. like, i can download it.. but then it wont open.. and ive tried opening it with...
Did it download as a .zip(compressed) file? If so, you will have to uncompress;unzip; or extract the file before it will work...you should get a prompt asking if you want to run,ect.
Mar 07, 2010 | HP Pavilion dv8000t Notebook
Feb 04, 2009 | HP Pavilion dv6000z Notebook
Computers & Internet Logo
70 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
