Question about Mitsubishi WD-52525 52" Rear Projection HDTV
My mitsubish is bouncing the screen
When i turn on the tv it seams to bounce up and down . what can i do to fix my 62' diamond series
    Champion:
  • 240 Answers
I ned mr nffrmaion bouncilike wat ???
explane futher ???
Posted on Jan 13, 2009
Vizio model e321vl screen bounces up and down..like it jitterlty
Check and replace the damaged component/s at its main board. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Oct 15, 2014 | Vizio Televison & Video
Crysler 300c, i find the ride bumpy and hard ?
Struts...Shocks.....Hard hitting and wanders off on turns...push down hard on the corners hard. If it comes up sluggish or bounces....any shop should check for no charge.....get them fixed.... They\'ll loosen everything on your car and cause issues later....
Oct 12, 2014 | 2007 Chrysler 300c AWD Sedan New Cars
When I hit a bump I bounce and bounce and bounce.
If the bouncing is in the front it is probably a strut.
If the bouncing is in the rear it is probably a shock
look for the shock to be oily indicating the shock is bad. But
usually if the car is bouncing two or three time after hitting a bump
the shock has either broken or come completely loose.
Jan 15, 2014 | 2003 Buick LeSabre
Why do bright colors bounce on my lg tv?
I had this issue on a 40" Seiki TV. I turned off the 120hz setting and also the Noise Reduction settings in the Menu and it stopped.
Jan 12, 2013 | LG 47lw5300 47-inch 1080p 120hz Cinema 3d...
TV screen bouncing up and down
look for the horizontal hold.
Jan 26, 2009 | Akai PDP4206EA Television
SCREEN DISPLAY BOUNCES UP AND DOWN
Check and make sure that the speakers and any power supply (UPS) are not placed very close to the monitor.
Feb 11, 2008 | Mag Innovision LT776s 17" LCD Monitor
Horizontal lines and screen bounce
These sets have capacitors that will go bad, but without a good ERS meater that tests these in curcuit you could be spending a lot of time doing nothing, But the most common is to find the 9 volt reg on the signal board and change all within a 2 inches of that regulator
Feb 07, 2008 | Mitsubishi VS-50605 50" Rear Projection...
Bouncing Picture on WS48511 MITSUBISHI PROJECTION TV
I have seen this symptom a lot recently. There is a 9 volt regulator on the small signal board, and the output voltage on this IC has dropped down to about 8 volts, which causes that symptom. Replacing that regulator should cure your problem, and when I make a housecall for a set like that I charge $150, although I hear that the average service center charges a lot more than that. I also believe that it is never a good idea to leave a projection TV on all the time, so whoever told you that has no idea what they are talking about.
Jul 05, 2007 | Mitsubishi WS48511 48" Rear Projection...
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
