Question about Beko Washing Machines
My beko washing machine made a screeching noise when on spin cycle then blew the elctrics in the house ,i tarted it up on the spin cycle again but now its sparking while the drum is spinning somewher inside the washer (motor maybe)
catriver
  • 878 Answers
SOURCE: "howling" noise during spin cycle (still there after changing burned off belt)
Travioso, there was two service flashes out on this model concerning the seal and bearing which means they had an issue with this washer. The howling noise you are hearing is the bearing and will need the new designed triple seal and bearing kit. This should be covered under your warranty, I believe it is 5 years. The numbers for the service flashes are TDL-0048A-B. Call Maytag and inquire about these service flashes, these should be covered. Catriver.
Posted on Jul 25, 2006
  • 121 Answers
SOURCE: My washing machine has stopped spinning.
it sound like your belt has come off if not wait till its dark put it on spin turn the light off if you can see flashes coming from under the machine it your brushes that need replaced on the motor
Posted on Mar 03, 2008
SOURCE: Kenmore spin cycle thumping noises
I just went through the same issue with my Kenmore front loading washing machine. I assumed (and a Sears repairman also told me) that it is the bearings. After I took the drum assembly out, I saw the rear drum broken and the inner tub hitting the outer tub. I ordered the outer drum assembly and only when I took the inner drum assembly out I realized the the "Spider" attached to the inner drum (and spindle) was broken. Entire drum assembly cost $417 + shipping and it may be cheaper in the long run to buy a new washer. I like the front loaders because they save water and good for the environment, but the US manufacturers have not yet perfected the technology like European manufacturers (or they don't want the machines to last too long just like cars). Anyway, I am looking into welding the spider tomorrow. If not will return the outer tub assembly and buy a top loading washer for $300!
Posted on Mar 07, 2008
  • 7 Answers
SOURCE: loud noise during spin cycle
this is my experience repairing the maytag washer Atlantis mav series 9750 aww, I had to replace the spin bearing since it was making a jet engine noise when it was spinning out the water. its not an easy job for my 1st time taking this machine apart, you literally take it all apart to get to this bearing, but now I can show how to do it with pictures making it easier for you to do it. even if you have to replace something other than the spin bearing, this how to tutorial will show you how to get to most of the parts in this machine
tutorial located here tutorial located here https://sites.google.com/site/maytagwasherrepair/maytag-washer-repair
Posted on Apr 08, 2008
docjohn174
  • 943 Answers
SOURCE: frigidaire affinity front loading washer won't drain
HI .THANKS FOR YOUR QUESTION. THE PROBLEM IS WITH THE WATER PUMP.REMOVE 2 SCREWS AT BOTTOM OF FRONT PANEL . PUMP ON RIGHT .REMOVE HOSES AND CLEAN OUT THANKS THE APPLIANCE DOC.
Posted on Oct 04, 2008
Beko washing machine seems to go straight into a spin cycle,bangs around too.I did the test program, it didn't turn clockwise gently or anticlockwise gently it just spun really fast then blew the fuse
Hello!
It sounds like the triac, which drives the motor is in short, you can recognize from the heatsink, on Beko usually is riveted, not fixed with screw, but you can drill'em off, its an BTB12 ( or 16 ) Triac, replace, thermal grease under and back.
Rarely this problem could be caused by tacho circuit error, but ususally Beko just stops and do nothing when tacho error
Aug 31, 2016 | Beko Washing Machines
Screeching noise during operation of machine
If it only screeches when the drain pump is running you can spray some crc or wd40 in to the bearing on the drain pump. That usually helps. You will have to turn power off at wall, tip machine back against a wall and get at the pump underneath on the right side at the front.
Jun 24, 2017 | Fisher and Paykel Washing Machines
Electrolux screaching noise on spin cycle
Hello friend, thank you for your inquiry!
Based off the information you have provided you are hearing a loud screeching noise during the spin cycle on your Electrolux washer. You will hear a certain amount of motor whine during the spin cycle this is a normal operation of your appliance. -Matt
Aug 23, 2014 | Electrolux EWFLS70JRR Energy Star Front...
Loud screeching noise when the wash and spin cycle ends
You either have something caught between the tub and basket or a bearing bad.
Eric
Jun 29, 2009 | Maytag Washing Machines
Loud screeching noise when spin cycle is on
Good morning! Possibly the noise was due to improper placement of load into the spinner which should be within its capacity load. best regards.
May 02, 2009 | Washing Machines
Loud screeching noise on spin cycle
I have the same problem...during SPIN it make a LOUD SCREECHING sound.
Apr 20, 2009 | Maytag PAV2300 Top Load Washer
High pitched screeching noise when in spin cycle
Sounds like the belt is worn and might need to be replaced. Let me know if I can do anything else. thankyou for asking.
Mar 03, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Loud noise in final spin cycle
Check the motor on the machine, make sure that the motor is not grinding on itself. If that is not it then check the tub and make sure when that spins that it is not hitting the side of the housing
Feb 08, 2009 | Kenmore 24032\24036 Top Load Washer
My washing machine is tripping the circuit breaker
sorry to hear about the problem it will be your motor or module try online for recon both these parts are prone to go on bekos
Jun 14, 2008 | Washing Machines
Washing Machines Logo
35 people viewed this question
Top Beko Washing Machines Experts
Tom Chichester
J D Wright
 Russ Hill
Russ Hill
Are you a Beko Washing Machine Expert? Answer questions, earn points and help others
