Question about Cobra Radio Communications
My cobra two ways were in storage for three years, they charged and worked fine before. when i unpacked them and put them on the chargre the charge lights came on like theyre charging. later i noticed
The model no. on the two way is l16050
  • 3 Answers
The charge light comes on and stays on full time, no matter the charge level of the batteries. Just put in new ones, batteries that is and start over. Be careful of the exposed metal strip on the bottom of the battery. The radio has a seperate charging circuit that must be made for the charger to work. Buy normal AA nimh and wrap a bit of tin foil over the one battery that makes the charging circuit and you should be fine. These batteries do not like long periods of non charging, so just scrap them and start again.
Posted on Jan 28, 2013
4 Suggested Answers
  • 14 Answers
SOURCE: what channel do I put the radios on to charge it
Turn the radios off when you are charging them. The charger may not have the current flow to effectively charge the radios when they are on. If you need to monitor a channel, try charging them one at a time.
Regards,
Longshorts.
Posted on Jul 24, 2009
eradiostore
  • 1654 Answers
SOURCE: my charger will not charge
1) Clean the battery contacts on the radio, battery and charger with a pencil eraser.
2) Test the charger by turning the radio on while attached to the charger (do NOT transmit, as this may cause damage to the unit). If the light on the charger comes on while the radio is turned on, you have a good charger, and a bad battery.
3) If the above test detects a bad battery, replace the battery.
4) Not sure if the battery is bad? Trade the battery out of a known good unit into this one to see if it solves the problem.
Posted on Mar 11, 2010
SOURCE: I have the cobra CXT275
Just went to their site and this is what it said:
This may simply be a matter of misinterpreting the low-battery indicator. We use two different types of battery indicators:
  1. Battery Level Indicator: This battery indicator is always visible, and has several segments. When all the segments are lit, the batteries are full. When only the last segment is lit, the batteries are almost exhausted.
  2. Low Battery Indicator: This type is usually NOT visible. It only appears when the batteries are low, at which time it flashes on the display to warn you of a low battery condition.
Please note that when you turn on your radio it first performs a display test. Everything on the display will light up for a few seconds, including the Low Battery Indicator. This does not mean that the batteries are low. After a few seconds the display test will end, at which time the Low Battery Indicator should go away.
Posted on Feb 01, 2011
I put new batteries in my Cobra 2-way radios and charged them for 24 hours. Still shows "low battery" when I turn them on.
Check your charger and battery contacts. Cleaning battery contacts on the radio and charger with a pencil eraser will remove dust, dirt, debris, and hand oil which may cause the battery to charge poorly. Secondly, you might want to check that your charger itself is working properly. If you have a second known good radio you might try charging it on the same charger.
Best regards.
Sep 28, 2014 | Cobra Radio Communications
My crx700 cobra micro talker won't charging
Will one of them charge? If so, use it to check the other side of the charger. If both sides will charge the good radio then take the battery out of the good one and put it in the one that won't charge. If it now charges, then the battery was bad. If you have a radio that won't charge in either side or on either battery then the power is not getting to the on switch. Check for corrosion. You can use a volt meter to check the charger terminals and see if they are putting out juice. Both sides should read about the same.
Oct 05, 2013 | Cobra Electronics microTALK® CXR700 Two...
I lost my cobra cxt227 manuals but I need to charge them. Do I charge them with the units on or off? How do I know they are charging?
You're best to charge them powered off. It's healthier for the batteries. Just put them on the charger and give them about 12 hours of uninterupted charging time.
Apr 29, 2012 | Cobra Electronics Microtalk Cxt225 -...
Cobra pr 3850wx bought new NiMh 800mAh 1.2v rechargable batteries now the base charger lights won't come on when i put the radios in it
  • A Cobra 3850wx Radio requires 4x600mAh NiMH 1.2V AAA Part # GA-3ANH rechargeable batteries.
  • Not just any AAA rechargeable battery will charge in the unit.
  • All will work in the radio but not all will charge inside the radio. It has to be a specific battery.
  • This is an example of what you need. GA-3ANH batteries which will charge inside your radio. http://www.tomsawyer2wayradios.com/catalog/item/3823249/5076887.htm
Regards, Tony
May 22, 2011 | Cobra Microtalk 100 FRS Walkie Talkie...
I just put new batteries in my Cobra microtalk PR 3500 DX battery charger. How long will it take to charge them? Should the Radio's be in the on or off position. Thank You mjbarry42@comcast.net Mike...
The radios will work fine while being charged, but they will charge faster if turned off. Normal charging time is 8-10 hours, but I would recommend an overnight charge - they won't overcharge or be damaged by the longer charge time.
Bill B.
Nov 05, 2010 | Cobra microTALK PR 3500-2 DX VP 2-Way...
Charging batteries
the cobras are meant to work with alkaline cells. You bought nicads which are a lower voltage per cell (1.2 to 1.38). Alkalines are about 1.55-1.58
That is why your rechargeables only show a quarter charge, because their terminal voltage is lower and the radio thinks they are not fully-charged.
May 28, 2009 | Cobra Microtalk 100 FRS Walkie Talkie...
Battery seam like it is not charging
Some automatic battery chargers will not charge a REALLY low battery. You really need a volt/ohmmeter to check charging rate.
Should be 13.5--14.4 volts while charging, 12.5 volts for fully charged battery.
Apr 05, 2009 | Craftsman Garden
Microtalks don't seem to charge, even charged many hours
When you say they worked fine for a long time, do you mean a long time as in "hours", or for many months or years? If hours, then remove the batteries and be sure they are in correctly and plug the charger into a different electrical outlet. If the radios have not been used for many months or longer, you probably need to replace the rechargeable battery.
Feb 06, 2009 | Cobra Microtalk 100 FRS Walkie Talkie...
Nintendo 64 game cartridges no longer work ??????
have you tried cleaning the cartridge with a cotton swab w/rubbing alcohol on it?
Oct 25, 2007 | Nintendo 64 Console
Radio Communications Logo
156 people viewed this question
Top Cobra Radio Communications Experts
AnyMHz.com
AnyMHz.com
Steve
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
