My computer has gone into safe mode and i can not get it off
One day its working fine the next day its gone into safemode plus my mini notebook does not have the F buttons on it
  • 7,627 Answers
In safe mode open, RUN, type msconfig, General tab, click on Normal Startup, click OK, restart computer. Here's a example: http://www.netsquirrel.com/msconfig/msconfig_xp.html
Posted on Dec 10, 2012
jesselohse
  • 128 Answers
SOURCE: My Acer aspire one wont start into normal windows, only safemode
Did your system come with any software? I know when I bought my aspireone it did not. However, You can purchase a thumbdrive with at least 4 gb of space and if you have a copy of windows xp of the same version as that which is loaded on your aspireone (should be windows xp home edition) and you can use a program like magicISO to create a copy of the windows xp cd onto the thumbdrive.
Hope this helps, and I would be more than happy to give you more specific support as needed.
Good Luck!
Jesse
Posted on Jan 06, 2010
SOURCE: My acer notebook laptop won't start up widows at all.
An application programming interface (API) is an interface implemented by a software program to enable interaction with other software, much in the same way that a user interface facilitates interaction between humans and computers. APIs are implemented by applications, libraries and operating systems to determine the vocabulary and calling conventions the programmer should employ to use their services. It may include specifications for routines, data structures, object classes and protocols used to communicate between the consumer and implementer of the API.
Your system is infected by Boot sector Virus or trojans or Malware or Rootkit trojans. You need to scan it.But as you can't boot your system,you won't be able to perform a normal scan.
Download "Hiren's Boot CD" below is the link
http://hirens.longcomputerservices.com/Hirens.BootCD.10.1.zip
Download the file and extract it with winzip or Winrar.
Burn the ISO image and boot the system using "Hiren's Boot CD" (Set the BIOS to Boot from CD-ROM).
This CD has preinstalled Anti-virus,try to scan the system and rootkit revealer to remove Rootkit trojans.
and check.
if the problem still persists, you can used this CD and backup all your important data by selecting "Start Mini Windows XP"
Good Luck.
Posted on Jan 16, 2010
SYSTEM ONE
  • 85 Answers
SOURCE: latop d620 worked ine but now screen is lack unless in safe mode
Now I don’t know how unplugging it or moving it would cause that problem but it does sound like you might have an issue with the refresh rate and or screen resolution at a setting that is to high for the screen to display (safe mode only loads windows core components and minimal set of drivers like basic vga driver for display which is why it probably works in safe mode)
If you are running windows XP then try the following:
Ok try hitting F8 key before XP logo appears for boot menu then select "enable vga mode" then after you get to a desktop go to display settings and lower the screen resolution and refresh rate setting
(refresh rate should be at 60hz) resolution could be different depending on which screen you have there... but try 1024x768 just to be safe then reboot into normal mode and see if it works and if it does then you can adjust the resolution to what it was before problem occurred
If you are running Windows Vista then boot from the Vista CD and select “repair my computer” and then “fix startup problems” and it should do it for you
Posted on Feb 06, 2010
  • 266 Answers
SOURCE: when I turn on my computer it goes to either choosing safe mode,
There are many reason for a system goes to safe mode directly.here is the solution to solve the issue
Follow the steps:
Immediately begin tapping the "F8" key when the reboot sequence begins (make sure your "F Lock" key is activated.) Once the black "safe mode" screen appears, then first try selecting the option "Start Windows Normally" using your mouse or keyboard up and down keys. Allow Windows to boot, log into your profile and wait for the program to fully configure. Once that is completed, go to the "Start" button and select "reboot." If all is well, the "safe mode" will not reappear.
If that fails, then repeat the reboot sequence -- tapping the "F8" key repeatedly -- and when "safe mode" reappears, choose the "Last Known Good Configuration" selection and allow it to go through the same sequence as in the above paragraph.
If the above does not work and your system continues to first boot into "safe mode" it is possible that a setting in the boot configuration file is checked.
For that go to start -> RUN and Type in "msconfig" in the provided box and hit "enter." The "System Configuration Utility" will appear. Using your mouse or right arrow key, select the "BOOT.INI" tab. Look for the "boot options" section and the "SAFEBOOT" selection box. If it is checked, uncheck it, select the "Apply" button and then "OK."
Go to the "Start" button and select "reboot" and your machine should now boot directly into Windows.
Posted on Mar 17, 2010
  • 127 Answers
SOURCE: Veryface on Lenovo Notebook preventing Login, Vista basic
well i think you should download latest cam driver it will solve your problem.it happens because your cam driver does not working properly with your system
Posted on Mar 31, 2010
Windows won't start with safe mode
Download a new safemode for dell. my safemode wouldn't work too.
Apr 13, 2013 | Dell Latitude D520 Battery PC Notebook
Cannot remove safemode on my hp mini notebook
You to roll back is System Restore, or uninstall whatever has caused it to load into safe mode.
Dec 10, 2012 | Computers & Internet
Trying to boot up, but can't.
Hi Good day!! try to boot from safemode tap f8 while your computer is booting process w8 until safemode option appear. choose safemode and see if the uhnit will boot from safe mode.. if successful restart the unit.. please reply if this method did not work
May 06, 2012 | Computers & Internet
Hallo how to safe mode my hp pavilion dv4 1120us pc?
Hi kemisha, to get to the "Safe Mode" program.
You have to "retstart the computer."
Once you "hear to computer - Hard Drive {Hum}, and the "Fan" spinning!"
"This is the (Time you want to 'press the F8 button) several times quickly.
"It is important to do this before the "Prompt Screen" show up.
The {Prompt Screen} gives you the 'option' to go to the BIOS / CMOS setup.
The 'message at the bottom of the screen will read:
Press F2... or Press F12... for?
"Press the [F8] before this 'screen' appear!"
If you do this; the "window below will be 'present."
"Use the {Arrow Keys} to move, and "hightlight" the [Advance Options].
Once you have selected the "Safe Mode" option; press the "Enter" tab.
Now, the computer will "Boot into Safe Mode!"
!Important: "Take a 'moment to rate the help', so I can get 'credit' for the work.
Thank you!" - paul7of9
Mar 16, 2011 | HP Pavilion dv4-1120us Notebook
After the computer turns on I get a blue screen with a box in the center that reads Warning! Spyware detected on your computer! Install an antivirus or spyware remover to clean your...
restart the system and keep tapping F8
check whether you are able to take the system into safemode.
if it comes in safemode then download and run programs named as malwarebytes and trojan remover.
if you are not able to get into safemode then try safemode with commandprompt and try a system restore from there.
Jan 03, 2011 | Dell Inspiron E1505 Notebook
Acer Aspire one mini notebook is stuck in safemode
you need to look someone having an external dvd rom,to reformat your computer,,because your computer is infected of virus
Jan 30, 2010 | Acer Aspire One AOA150-1635 Notebook
Touchpad won't work: due to virus?
go to the HP website and redown load the driver for the mini1000 notebook touch pad. chances are the driver is just corrupt.
safe mode uses just generic drivers.
Jan 03, 2010 | HP Mini 1000 Netbook
New laptop delivered yesterday,hp dv6000 it will let me get into the password window but after that nothing!
Hello Homecontrols,
Sometimes this issue occurs when there are many startup items.
However try the following steps if you are able to login into safemode:
Here are the steps to login into safemode:
1. Restart the computer. Keep tapping F8 key at the Compaq Logo repeatedly.
2. You should see a menu, choose Safe Mode from the Advanced options menu, and press Enter.
3. You should see Windows Entering into Safe Mode, with Safe Mode written on all four corners of the Screen.
After loging into safe mode perform the following steps:
1. Hold the windows key and press 'R' -> Type msconfig -> Click Ok
2. Click on Services tab, check the box next to "Hide all Micrsoft services" then clickon disable all.
3. After that click on Startup tab and click on disable all.
4. Click on apply and ok. Then restart the notebook into normal mode.
Let me know after trying the above steps.
Sep 10, 2008 | HP Computers & Internet
Desktop
If the squares are gone in safe mode it's safe bet that it's your graphics card driver. Uninstall drivers in add/remove programmes and re-boot your pc and see if the correct driver is re-installed. If at all possible it's best to use the driver from your notebook's manufacturer web site.
Dec 11, 2006 | Dell Inspiron 1300 Notebook
Computers & Internet Logo
19 people viewed this question
David Payne
David Payne
