I can't get my tv to zoom out! I've tried changing the zoo ratio but it's still zoomed!
    Problem Solver:
  • 5 Answers
On the remote, press SWAP. It works on mine.
Posted on Dec 10, 2012
SOURCE: Zoom Function and Verizon Fios TV
On the verizon FIOS tv box, turn the FIOS STB on, and turn on the tv, tap the following buttons on the Verizon FIOS STB )in this order) 1-Power, then Select, then Menu. This will bring up the FIOS STB HD options. Arrow down to 4:3 Bypass and set the bypass option to 480P. Hit power 2 times, once to turn off, second time to turn STB back on. This should on standard channels give you the zoom feature back. This worked on my Samsunf 5053 TV model.
Posted on May 06, 2008
TekSpotCoUK
  • 31 Answers
SOURCE: my tv is zoomed in, how do I change the aspect
what make and model is your tv. e.g. sony wdxxxx
thanks
TekSpotDotCoDotUK
Posted on Aug 27, 2009
SOURCE: The picture is to big to fit on the TV screen.
It was the on the HD cable remote. the aspect ratio had to be changed backed to a 720
Posted on Sep 22, 2009
  • 290 Answers
SOURCE: LCD tv zoomed in. can't un-zoom it.
Are you connected to a cable box with its own remote control, if so, some systems have a zoom control on the cable box remote. Check to see if it is setup to "Movie" mode or similar.
Posted on Dec 27, 2009
  • 864 Answers
SOURCE: HD TV screen is zoomed to far out. How do
Use the Picture, Zoom, or Aspect button on the TV remote to cycle through the available screen sizes. You may also be able to set screen size in a Setup-Picture (or Video) menu.
Posted on Jan 18, 2010
How do i fix a too wide picture on my sony kdl40ex500?
Why are you using 4:3 letterbox? It might be the default aspect ratio but widescreen tvs should be set to 16:9 aspect ratio.
Aug 22, 2014 | Sony KDL40EX500 40 in. HD-Ready TV
Zooming
did you tried to change the aspect ratio, tried with 4:3 option to change the picture settings.
Jul 18, 2012 | JVC Televison & Video
My tv screen is zoomed in how to zoom out
  1. Check the TV to see if it has a ZOOM / WIDE option or control for adjusting the aspect ratio; if so, try setting it toNORMAL .
  2. NOTES:
    • If there is a SCREEN MODE button on the TV remote control, you can press this button until NORMAL is selected.
  3. If using a cable/satellite set-top box, DVD player or digital video recorder, check the device for aspect ratio controls and try selecting a different display option.
Jan 16, 2011 | Sony FD Trinitron WEGA KV-34XBR800 34" TV
The left side of the LG 42" plasma TV has no
try to check the aspect ratio and input source to make sure they are correct. for the aspect ratio, make sure it is set either at 16:9 ratio or try the zoom options. if it is set at zoom, you can move the screen left to right or up or down through the zoom settings. make sure you are also using the correct cable. hope this helps
Nov 25, 2010 | LG 42PC3D 42 in. Plasma Television
TV zoomed in
Look at your remote or On-screen menus for ratio settings. The remote might say zoom or ratio. The menus will probably have it under video and then Aspect Ratio. You'll probably need to hit go through several settings to get to the correct ratio. (some choices are 4:3, 16:9, Full-screen - the best choice depends on the set and the source video)
I hope this helps.
(my remote (slightly different TV) has the zoom just above mute so I hit the wrong button often.)
Apr 24, 2010 | RCA 36V550T 36" TV
How do I change the aspect ratio
Aspect Ratio–Selects the screen aspect ratio: Normal, Wide, Zoom, or
Cinema. You can also press the ZOOM button to select the aspect ratio.
Aug 16, 2009 | Insignia NS-L32Q-10A 32 in. HD-Ready LCD...
My picture is zoomed in, the picture is too big for the screen. I've tried a hard reset, and I have the factory remote, but I can't seem to even find the zoom option. how can i un-zoom my tv?
there may not be a zoom option but there should be a ratio setting i.e 16x9,4.3 letter box i had that problem and found it in my display settings my screen resolution was changed to 16x9 zoom
May 26, 2009 | Televison & Video
Aspect ratio problems on Samsung LN-S2651D Flat Panel TV
The aspect ratio (zoom) button on the cable remote had been changed. On Brighthouse the # button toggles through the zoom settings. It's not a tv issue, it's a cable fix.
May 29, 2008 | Televison & Video
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
