Question about HP Compaq nc6220 Notebook
My hp compaq nc6220 is not able to boot to the OS. What could be done to resolve it?
Screen powers on and only shows the Hp invent with the F10=ROM Based setup. Stays this way and is unable to boot to the OS.
  • mr_yebvican
    mr_yebvican Dec 10, 2012
    now its does not show this screen anymore but rather beeps twwice after powering on and tells 164 memory size error. then a blue screen that says DriveLock Multibay password?
  • HP Master
  • 32,281 Answers
First - re-seat the hard disk and reboot the computer. If the computer does not boot up then reboot and go into the BIOS configuration to see if the BIOS detects the hard drive. If it doesn't detect the hard drive then it could be faulty.
Then the hard drive needs to be replaced in the computer/laptop, Windows installed and the computer or laptop's device drivers plus your programs etc. to get a functioning computer/laptop again.
Posted on Dec 10, 2012
  • mr_yebvican
3 Suggested Answers
  • 26 Answers
SOURCE: will not boot, sticks at HP invent screen with F10
press f10
Posted on Nov 07, 2009
sandrew
  • 2961 Answers
SOURCE: laptop boots to the F10 and F12
this is as if you haven't got an installed operating system and requires it to be installed, but you have to enable your cdrom as the first boot device. Put your O.S disc in and reboot; then press enter to boot up from disc.
Posted on Dec 17, 2006
Hp Compaq nc6220 Laptop. there begin booting one msg "163-time & Date not set". how to resolve this problem.
go to your BIOS setting
There set the current date and time
[while starting the computer , there will be screen showing options keys for bios setting (it will probably be esc or f12 or f2 or f11)]
Jul 19, 2011 | HP Compaq nc6220 Notebook
Hi, I'm installing widows xp in HP Compaq nc6220, but after setup loading files the mesaage (bottom of setup screen) "Setup is starting windows", then it did'nt contiue the installation,...
1 many times the the CD cant load as the files in the CD are corrupt or the CD is not read by the drive corectly...so get a new WinXP CD
2 try an external CD drive if your BIOS alows to boot from USB drive....(connect the external CD drive to the USB and make necessary changes to the BIOS boot seq in the BIOS screen...
BIOS screen can be enabled by pressing the F1, or F2 or the Del key as on as you start the PC
3 once in BIOS screen look for boot seq and change the boot drive to the foll
1st boot device - USB CD / DVD rom drive
2nd boot device - internal CD rom drive
and so on
if you can do the above then try the WinXP installation using the external CD rom drive....
else there is a little complicated method of using a pen drive thru USB (will discuss that later) provided your BIOS alows booting from USB
for more PC related issues visit my website
reg
kris
suresh_krishnan1961@yahoo.com
www.sureshayyar.110mb.com
May 18, 2011 | HP Compaq nc6220 Notebook
I am Ravichandran, using HP Compaq nx6100 Model Laptop. My laptop did't boot and not even entering into Bios. Only HP Invent Embalam will appear and press F10 Rom Setup. If I press F10, F9, F1 there is...
If you are unable to "F-10" at power up, try 1}. unplug your laptop from AC adapter.
2}. press and hold power button until the computer powers up and powers off.
3} remove battery.
4). press and hold power button 10 seconds then release, replace battery.
5}. power up and press F10
If you are still unable to access BIOS you will need to obtain a system restore disk from HP
Apr 26, 2011 | HP Compaq nx6110 Notebook
I have hp nc6220, if often hangs and is always unpredictable, but when i press its touchpad from downward and keep it pressed it works, when i release that it hangs again
I had this problem (hanging on the screen with F10 = ROM based setup) for a while on my HP nc6220 laptop. Was taking several attempts to boot. Replaced the hard drive. Ran virus and malware detection, all clean. Stumbled on to the posting where someone wrote about applying pressure by the touch pad seemed to help. It did. Then the problem gradually got worse. Thought maybe there was something loose. Downloaded the disassembly procedure from hp.com. I found the 2 ground contacts under the touch pad had oxidation on them. Cleaned them with a pencil eraser. Reassembled the laptop and have not hung once. Everything runs faster as well. This is not for the novice, but someone with a little experience should be able to get through the process. Hope this helps someone.
Dec 24, 2010 | HP Compaq nc6220 Notebook
HP Compaq nc6220 PC Notebook Boot sequence
1) Turn the laptop on
2) AS SOON as you see > F10 = ROM Based Setup, in the lower left corner of your LCD screen, press the F10 key.
3) You will see the headings > Main, Advanced, Security, and Tools.
Use the appropriate Arrow key to highlight Advanced. (Look at the Navigation guide to see the proper key to use)
Press the Enter key.
4) Use the appropriate navigation key to highlight > Boot Order
Press the Enter key
This will show you the Boot Order Sequence.
What you are doing now is just looking around. You haven't changed any settings yet.
If you need to change the Boot Order Sequence, you have to use the appropriate navigation key, and highlight Multiboot, and then press the Enter key. Disable Multiboot.
Save changes.
If you do Not save the changes, it will be like you have done nothing at all.
[The navigation guide shows you the key/s to press to navigate around in BIOS Setup.
You may see,
Page up/Page Down, or -/+
Left Side Arrow key, or Right Side Arrow key.
Enter key ]
If this is not what you had in mind, please post in a Comment.
Nov 25, 2010 | HP Compaq nc6220 Notebook
How do I change the administrative password for my Compaq nc6220
  1. Press the Power button to start the computer.
    NOTE: Pressing F10 opens the BIOS of Compaq Presario desktops 2001 and earlier.Pressing F1 opens the BIOS of the S3000 series, 6400 series, and 2002 models of Presario desktop computers.
  2. Immediately press the F10 or F1 key repeatedly on the keyboard when the logo screen displays.
Oct 24, 2010 | HP Compaq nc6220 Notebook
HP Compaq NC6220 won't boot
I'm running into the exact same issue. Were you able to resolve the situation?
Fatima
May 16, 2009 | HP Compaq nc6220 Notebook
My compaq laptop freezes after 30 minutes
It sounds like an overheating problem. When it is booted, does it run ok other than just being slow? Check your cooling fan and make sure it is running and not stopped up. That is a number one symtom of overheating is freezing and rebooting by itself. Have you expierenced that problem also? There is a free program called "Motherboard Monitor 5" that will monitor the temp for you and set off an alarm when it is getting to hot. Check that problem first. Hopes this helps!
Nov 27, 2007 | HP Compaq nx6110 PC Laptop
Laptop boots to the F10 and F12
Dec 17, 2006 | HP Compaq nx6125 Notebook
HP Compaq nc6220 Notebook Logo
307 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
