Question about Pioneer AXD1463
Having trouble turning set on
I just bought the tv and am having trouble turning the set on
    Top Expert:
  • Pioneer Master
  • 14,553 Answers
L would like to help : do you have to turn it on several times and finally it comes on and stays on or what?
Posted on Dec 10, 2012
Tv won't come on tried all the trouble shooting ideas in book but nada
hi if you brought the tv in november might best to get in contact where you got it from ask them to send a tech out, you won't have to pay as it should be covered by the warranty good luck
regards
shaun
Jan 23, 2014 | Universal 40-42 Inch Flat Screen Panel...
How do I get my control to work with my bose speakers
I have to guess on this one, so bear with me. If you have audio out connectors on the rear of the TV, connect your speakers to them, then go to setup on your remote and turn off the TV speakers. After that, you should hear TV sound only from the Bose speakers at whatever level you set
Oct 03, 2012 | Panasonic VIERA Televison & Video
TV Doesn't Function: Can turn on, but no menu or input recognition
the set like all has a hard reset which requires a four digit number code and the original Mitsubishi remote---sets almost everything in the set back to original except convergence.
also, don't buy any TV or electronics on CL as people dump their problems on someone else..
Aug 31, 2012 | Mitsubishi WS-65313 65" Rear Projection...
Toshiba model 36a43 The tv stopped responding to remote, bought univ remote does not work, but works with other tv. The menu buttons are inconsistant the volume goes up OR down when pushed, the channel...
What you're describing sounds to me like "Windex syndrome". People sometimes clean the front of their TV by spraying it with glass cleaner like it's a window (which it basically is) and wiping it off. Unfortunately the cleaner can run down onto the circuit board where it damages the switches and wiring. This might be what's happening in your TV, although the same trouble can be caused by other things as well.
The way the front panel controls are wired, a bad switch can cause all of them to act up. The remote sensor is part of the chain too, and if it goes bad odd things can happen. If the set is in an area of high humidity the same trouble can develop because of moisture. One of the switches might not be operating correctly, or another part in the button chain may have gone bad. The microcomputer in the TV may be bad. If you've had a recent severe thunderstorm with nearby lightning, this may have affected the chip.
Try unplugging the TV from the AC outlet, not just turning it off. Let it sit for 5 minutes to make sure that capacitors have had a chance to discharge. Press a couple of the front panel buttons before plugging the set back in. Then plug the TV back in and see if you still have the same trouble. This process makes sure the microcomputer inside is fully reset and often gets the set going again.
If the trouble continues, someone will need to check the front panel switches and the circuit board. That's the area where the cause will be found.
Mar 01, 2011 | Toshiba 36A43 36" TV
Why wont my tv turn on? a red light just flashes
Right now, your TV is in " Protection Mode". A damaged part has occurred inside on one of the power supply boards. The red flashing light is a trouble code for a tech to trace the trouble circuit path.
If you have electronic experience with circuit boards, you can find a Service Manual for the TV on the internet for less than $20. This Service manual will have the schematics, red light codes, circuit diagram, and part number list you need to fix the board.
Oct 11, 2009 | Philips 42PF9631D 42 in. Plasma Television
I have scrolling horizontal lines on both tv sets
Sound s like a powerpack issue poor smoothing or regulator trouble
Jul 06, 2009 | RCA F36668 36" TV
Panasonic tv volume trouble.
i have panasonic colour tv model tx28DK1 Serial No.1550327 . I lost remote control and my tv button is also broken. and i bought new Remote Control MUNRO RC81S. bUT I CAN'T set up my TV. hope you will help me
cheers
Nov 06, 2008 | Televison & Video
TV shut off will not stay on.
Sounds as though you have a video problem. It may be the convergence chips. The TV is shutting down do to a default in the circuit ( the set knows there is an error of somekind so it shuts down to protect itself). This is a problem that needs a pro trouble shooter since it could be in about any board. Sorry I couldn't help more
Ed
NC Electronic
Mills, Wyoming
Jan 07, 2008 | Mitsubishi VS-55707 TV
Trouble w/ my Phillips 50P8341 50 IN. HELP!!!
there is most likely a prob. with the keybd. switches all need to be replaced at the same time.
Aug 22, 2007 | Philips 50P8341 50" Rear Projection...
Pioneer AXD1463 Logo
23 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
