Question about Exercise & Fitness
Power is ON but unable to start program
Problem with Treadmills I Have 10 years old treadmill from Sportop (MT6000). recently this treadmill cannot start even the power is already ON. all Led are on. it's unable to display program on board, so it wouldn't start the motor. I already checked the cabling and also component from bottom to top. and unable to find any broken/burn component. please help
  • teguh susilo Dec 13, 2012
    May I Know where is REED switch usually located, and what is it looks like? it might help if you can show me the picture of REED switrch. Thanks
  • ernesto cuadra
    ernesto cuadra Dec 13, 2012
    you must see your instr. manual if you do not have it download free go www. fitness.manualsonline.com and proceed . God bless you
    Top Expert:
  • 12,223 Answers
1) You must have the deck belt is WORN, to due the lack of maintenance , however LUBE the deck belt with 100% of silicone or wax
2) Lube the rollers bearing with wd-40
3) Test the drive belt motor and replace if necessary
4) Test the input voltage motor, if there are the motor need repair.see my personal TIPS for motor help
5) Test the output voltage board, for input voltage motor, if there are NOT the board is faulty. see the block diagram
God bless you
Power is ON but unable to start program - 12_10_2012_9_57_26_pm.gif12_10_2012_9_58_34_pm.gif
Posted on Dec 10, 2012
  • 1 more comment
  • teguh susilo Dec 12, 2012
    Thanks for your answer, there's something that confusing me is, sometimes if i'm lucky this treadmill running smooth. but after I turn it off. it's not easy to turn it back on the program on display board. what is the possibility component that needs to be replace on main motor board or display board. thanks
  • ernesto cuadra
    ernesto cuadra Dec 12, 2012
    adjust the REED switch, test it for open or faulty, clean it, and tight the plug very well. God bless you
  • 2336 Answers
SOURCE: Manual Treadmills vs. Motorized Treadmills
Treadmills come in two basic varieties, just like lawnmowers: manual and motorized. But, unlike a lawnmower, you will generally get a better workout from a motorized treadmill. Manual Treadmills - Getting Going On a manual treadmill, the action of your feet against the deck moves the belt. Pros * You provide all of the motive power and exercise your lower body. Cons * It can be difficult to get the belt moving intially. That straining against the belt can stress your joints. * You may have to raise the incline of the treadmill significantly to make it easy enough to get the belt moving. * Once the belt is moving, however, you would have to stop and get off to change the incline, so you are stuck with one incline level during each workout. Motorized Treadmill Advantages * The belt is moved by the motor, you don't have to strain to start it. * On many treadmills, you can adjust the speed and incline while you are still walking or running. On others, you may have to get off and adjust the incline manually, but you just have to turn on the treadmill to start the belt again. Manual Treadmills - Speed With a manual treadmill, you go only as fast as you push yourself. If you slow, it slows. If you stop, it stops. Motorized Treadmill Speed and Workouts The speed is adjustable and many motorized treadmills have workout programs that adjust the speed to give you a varied workout. This pushes you to go faster. The constantly moving belt of a motorized treadmill motivates you to keep up. Costs Manual treadmills are relatively inexpensive, in the $100-200 US range. Motorized treadmills for home use cost from $750-$5000, and generally the more you pay, the better you get. Most motorized treadmills under $1000 have underpowered motors and are less sturdy and have fewer options for adjusting the incline, programmed workouts, etc.
Posted on Dec 01, 2008
maxtreadmill
  • 832 Answers
SOURCE: my true 500hrc treeadmill has no power to display.
CHECK YOUR RIBBON CONNECTOR THAT GOES UP TO YOU DISPLAY PANEL FOR CONTINUITY AND ON THE MOTOR CONTROL BOARD I BELIEVE ONE OF THOSE LEDS ARE 11V POWER TO UPPER DISPLAY THEIR ARE LABELED WOULD NEED A GOOD LIGHT TO SEE THEM
Posted on Mar 01, 2010
SOURCE: I have a Lifefitness Treadmill model TR 9100,
Ive just had lifefitness out to diagnose the same problem, its the Console PCB £413.74 all in from them to fit yourself Cant do anything else, save yourself the callout I was charged Good luck Adrian Webb 07780 993877
Posted on Jan 12, 2011
maxtreadmill
  • 832 Answers
SOURCE: My New Balance 1400 treadmill
It sound like either the wire harness that goes to upper console is bad or the Motor Control Board that has the 5v or 12v is missing. Here is the bad news New Balance is out of the Treadmill business and do not carry these items anymore. Their might be one other thing you might try is that if this unit was not maintain as owner's manual suggests, then the fuse may have open up. You must open the motor shroud locate motor control board find the fuse, if you have a multi meter check continuity of the fuse if open replace it with the same value ( maybe 15amps). Plug unit in if the display returns then proceed to do the prescribe maintenance in owner's hopefully that the belt and deck was not damaged when it went dead.
Good Luck!!
Max
Posted on May 09, 2011
ercupa190
  • 12223 Answers
SOURCE: I have two cardio zone
Dear Sir:
I will help you.
Please in all this check in, use The Vom digital:
1. NoPower
o 1 Make sure that the surge protector being used isproperly grounded and turned on. Check that the treadmill power cord isproperly plugged into the surge protector. o 2 Check to see that the key is inserted in theconsole. o 3 Check the circuit breaker on the frame near thepower cord. If the reset/off circuit breaker has tripped, wait 5 minutes andthen reset the breaker by pressing the switch in.
4)Check the circuit breaker from the main panel( wall) and Measure the Voltage for properly 115VAC. if there .
Hoping help you, contac me if there are something extra.
blessing.
E.CUADRA Managua, Nicaragua.C.A.
Posted on Sep 13, 2011
I have a ct83 horizon treadmill, recently there is a bubble in the walking belt that makes noise
Because of the continues usage, It will get spark and make noise. This can be prevent by painting or just put some oil to the engine.
Sep 01, 2016 | Horizon Ct 83 Treadmill Walking Belt
My f63 powers up and shows display, programming options, but will not start. is it my control board? Is it worth fixing a 5 yr old treadmill?
Start switch is bad most likely. Remove rear panel on console swap the stop and start switch connections.
Feb 18, 2015 | Sole Fitness F63 Treadmill
Operators manual for Sportop MT600 treadmill
NEED A BOARD FOR THE SPORTOP ST
1670
Dec 31, 2011 | Exercise & Fitness
Loud squeaking on my Reebok 9500 ES (three years old) from under the hood when the foot hits the treadmills - at various speeds and inclines.
HI,
Its time to lubricate your treadmill.
You must obtain the proper lubricant for your treadmill. There are several different types. Contact your manufacturer for what type is needed. Using the manufacturer provided allen wrench, loosen the walking belt approximately 10 full turns on each side of the rear roller. Apply approximately 1/2 ounce of lubricant directly in the middle of the walk area underneath the walking belt upon the deck. Retighten the rear roller 10 turns on each side. Run the treadmill at 6.0 mph for 2-3 minutes to spread the lubricant evenly. Wipe excess lube from the sides of the belt. Walk on treadmill to check for proper tension on belt.
for make it easy for you I have added a video. ok
Aug 27, 2011 | Reebok Exercise & Fitness
We have an L7 or L8 treadmill. About 2 years old.
Unplug unit remove motor shroud then plug in unit hit start it and listen to where the sound is originating could be the drive belt or if you are walking on it then it could be the running deck post needs to be lubricated
Apr 16, 2010 | Exercise & Fitness
I have a Nortic track exp 1000 about 4 to 5 years old. It has recently started to speed up on it's own. It happens only occasional.
Check speed sensor and make sure belt is lubricated. If this two are fine than motor control board may need to be repaired or replaced.
Feb 20, 2010 | NordicTrack Exercise & Fitness
Our EXP1000 treadmill is about 10 years old and we have not had any problems with it. The belt recently has been going slower than before. for Example, we used to walk at a speed rate of 4.5, now it...
If belt hasn't been replaced that's your poblem. If that's more than you want to put in a 10 year old treadmill, try lubricating it. That may bandaid the problem for a while. This will progressively get worse over time.
Nov 16, 2009 | Nordic Track NordicTrack Treadmill, A2550
Dec 01, 2008 | Endurance TF3i Folding Treadmill
Exercise & Fitness Logo
122 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
