Question about HP Officejet 4355 All-In-One InkJet Printer
Set up driver - HP Officejet 4355 All-In-One InkJet Printer
  • HP Master
  • 32,281 Answers
You can download the HP printer drivers from their support WEB site. Please click on this link and select your model printer to download :- http://welcome.hp.com/country/us/en/support.html
Posted on Dec 10, 2012
Zm400 media darkness settings get reset after printings lable from SAP
The printer driver settings override the printer settings unless you tell the driver to use the printer settings. You can tell by setting the printer setting and saving it permanently. Print a configuration label. Send a label to the printer. Print another configuration label. Compare the config labels and If it changed, then the driver changed it. Set the driver as above and it will not change when you print.
Jan 18, 2013 | Zebra ZM400 Direct Thermal-Thermal...
Settings keeps changing. Using WinXP and supplied drivers for KR403.
Use the Zebra driver and set the printer driver to use printer settings. Otherwise the driver will override and change the printer settings to match settings in the driver.
Oct 29, 2012 | Zebra KR403 Printer
Hello, I lost my Umax astra 5800 Scanner driversCD. how to download free drivers.
Windows xp driver:
http://www.umaxindia.in/drivers/Astra5800-drivers.zip
Windows 7 driver:
http://www.umaxindia.in/drivers/Astra%205800%20Web%20Driver_2009.12.25%20for%20Win%207.rar
Hope that helps
Aug 22, 2011 | Computers & Internet
Hi , I have a problem with zebra 105sl printer , everytime i print somthing i have to make changes to the settings , eg. make it darker .When i save the settings permenent next time i go tto print i have...
The settings in the printer driver are overriding the saved printer settings.
Do this:
1. Correct the printer settings and save them permanently.
2. Print saved configuration for future reference and to see if it changes.(Power on while holding cancel)
3. Print a label from computer.
4. Print configuration again (Power on while holding cancel).
5. Compare the 1st and 2nd printouts. If they are different then the printer driver is changing the printer settings. In other words the printer settings and the driver are different and the driver settings will override the printer settings before printing.
6. Change the driver settings and this won't happen. Increase the darkness setting in the driver.
Aug 13, 2011 | Zebra 105SL Thermal Label Printer
How do i set the keyboard back to default settings ?
control panel keyboard you can change your settings there
or you might have uninstall the keyboard then reinstall it and its drivers
control panel keyboard hardware then properties you hould see driver details,update driver,roll back driver,uninstall
make sure you have the driver for the keyboard before uninstalling the driver
diconnect the keyboard then reconnect it then reinstall the driver
hope this helps
Nov 09, 2010 | ASUS Eee PC 1000H Laptop
Prints only high quality , was printing a few pictures but cant get it back to normal setting
The settings in the printer driver over-ride settings selected from the printer. Drill down in the driver to find the setting you want and change it from there.
Apr 13, 2010 | HP Designjet Z6100 InkJet Printer
I want to riformate my pc but i haven't the disk drivers.From Internet I have download those drivers: Driver - Storage,driver audio,driver chipset,driver network,Driver - Modem,Driver - Printer,Driver -...
You do not need to format the hard drive, you can restore the computer to the factory setting factory settings means your computer would go to a state as it was on very first day of purchase.
If you want to restore the computer to factory settings and you have window vista, start tapping F11 at the startup of your computer and your computer would be restored to factory settings. If you have window XP use F10 at the startup.
However, if you want to format the hard drive, you can format it and you have already downloaded all of the drivers.After formatting, first install network drivers and then remaining others. Also, I would suggest you not to install the drivers for BIOS.
Apr 03, 2010 | HP Compaq 6830s Laptop
I cant find a driver to the motheboard i have
Here is a link to your motherboard. They don't have the Windows 7 drivers but you might be able to set the driver compatibility to XP. I'm not sure but its worth a try.
Normal 0 false false false MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} How to change driver compatibility (this example uses Vista)
1. Right click on the driver setup executable file and select the Compatibility tab. Set compatibility settings to Windows XP (Service Pack 2), and set the program's Privilege Level to run as administrator.
2. Install the device drivers and reboot the computer.
3. Right click My Computer, select “Manage” in the new window select Device Manager. Select the unknown item on the list. Right click on the unknown and select Properties, and then select the Driver tab. Select the Update Driver button and let it search for the drivers. A warning will appear regarding the lack of a digital signature. Tell Windows to install the driver anyway.
4. Reboot computer.
5. Search for your xx.exe or open an Explorer window and drill down to c:\windows\wher driver installed
6. Right click on the exe and select the Compatibility tab. Set compatibility settings on the exe to Windows XP SP2 and make sure the executable can run as an administrator
Hope this helps. At least until they come out with the proper drivers.
Nov 08, 2009 | MSI MS-6702E Motherboard
Change driver seat settings and set
on drivers door there is i keypad that says 1&2 set and exit. put drivers seat into positition using controls on side of seat press set 1 put drivers seat into exit position using controls on side of seat and press exit 1. driving position and exit positins are now set.
Apr 03, 2009 | 2001 Cadillac DeVille
Driver seat settings
1. Set seats to position you want retained in memory
2. Press set button on drivers door
3. Press which memory location to be stored to, 1 or 2
Dec 15, 2008 | 1998 Jeep Grand Cherokee
HP Officejet 4355 All-In-One InkJet Printer Logo
12 people viewed this question
Seeker5211
Seeker5211
